Question about Canon MultiPASS F50 All-In-One InkJet Printer
DRIVER CAN U PLZ GIV ME DA ODER DRIVER TINGY U WAS TAKIN BOUT........... PLZZZZZZZZZZZZZZZZZ
  • 667 Answers
Follow these instructions carefully. Not 100% guaranteed to work. Remember - you must have printer connected by parallel cable and use LPT1 when asked. If this works just remember you'll most likely only be able to print. I'll check to see how it turns out. Choose the printer the instructions say to choose. Except the very last dtep you can name it whatever you want. Take your time, do it right. Doesn't take long.
Use the following procedure to place the MultiPASS in Printer Mode. When finished, install an emulation driver.
  1. Press the <Menu> button on the printer's operator panel.
  2. Press the <SCAN> button.
  3. Press the <COPY> button.
  4. Press the <SET> button 2 times. The display will display [PRINTER MODE].
Note:
  • After the printer is set to PRINTER MODE and the parallel cable is connected at both ends and the computer is booted into Windows, Windows Plug and Play will detect and automatically install the Canon Inkjet S630 printer driver. If the S630 is not installed automatically, install the emulation driver manually.
  • After printing is completed, disconnect the cable from the printer and then disable PRINTER MODE.
Installing an emulation driver
The Canon Inkjet S630 emulation driver should install automatically once the F50 is set to Printer Mode, the cable is connected at both ends and the computer has booted into Windows. If not, the driver can be installed using the ‘Add a Printer’ function in the Printers window (See steps below).
  1. After setting the MultiPASS to Printer Mode and connecting the interface cable, power on the computer.
  2. If the 'Found New Hardware' window appears, cancel it.
  3. Click the 'Start' icon, DRIVER - startikon.gif , click 'Control Panel' and then click the appropriate link or icon depending on the view.
  • Using Normal Vista View :
  • Using Classic View :
  1. Click 'Add A Printer'.
  2. Select 'Add a Local Printer'.
  3. Select 'Use an existing port' and 'LPT1: (Printer Port)', then click 'Next'.
  4. Select 'Canon' as the Manufacturer and select Canon Inkjet S630.
  5. Type a name for the printer if desired, check the Set as the default printer box if you want the printer to be the default printer and then click 'Next'. The printer driver installs. If a Printer Sharing window appears, select 'Do not share' and click 'Next'.
    Above example shows Canon Bubble-Jet S400 in the Printer name field.
  6. When the installation finishes, click 'Finish' or choose 'Print a Test Page' to test the printer.
  7. After printing is completed, disconnect the cable from the printer and then disable PRINTER MODE. To print again, set the printer back to PRINTER MODE and then reconnect the cable.
Disable PRINTER MODE:
  1. Press the <Menu> button.
  3. Press the <COPY> button. The display will show [DOS PRINTING]
  4. Press the <SET> button. The bottom row on the display will show [ON].
  5. Press the left or right arrow to select OFF and then press the <SET> button.
Posted on Mar 17, 2008
  • Jeffrey Pemberton
    Jeffrey Pemberton Mar 17, 2008
    I messed up showing how the views would look as you do it. Just follow the instructions and you can do it without the views. If you can't, add a comment and I'll provide them. But you're smart, you can do it.- ( X's should be pictures but don't worry)
I changed the battery on my 97 Mercedes Benz E320 and my code came up on my stock raidio can you help
Well u need 2 go 2 Mercedes benz dealer or phone parts Giv them ur vin n they Giv u da code
Mar 05, 2014 | Cars & Trucks
Horizontal lines while takin a picture with DMC-FS42 plz do let me know da solution for diz asap.....
When that happens it is usually better to replace your camera. Image sensor is broken. You can TRY restoring your camera to factory settings.
Aug 10, 2012 | Panasonic Lumix Cameras
Cant get drill bit to stay
go bak to homie depot an git da guys in da contractor part to set da gun up for u! then have them giv u a show an tell. ifin da drill bit is in wrong nutin works right.?? so u gota go outa ur way to git-r-dun. show an tell wurks best!!
Jun 10, 2012 | Senco Corded Collated Screwdriver
Hello
You can download the Logitech WEBcam driver from their WEB site. Please click on this link and select your model WEBcam :-http://www.logitech.com/en-au/webcam_communications/webcams?wt.mc_id=usym_/quickcam_global&strf=Universal_Symlink
Jun 20, 2010 | Logitech QuickCam Connect Webcam
Ipod drowning
to be honest you need a new ipod
Feb 05, 2009 | Apple iPod nano MP3 Player
Want sound driver for my computer
HI Rashmi,
Get da drivers from da link below
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3445959&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20»
You will have to select da OS type that you have on ur comp and just navigate through da drives table n locate n install da driver u need. It will most likely will be listed as Original Realtek High Definition Audio Driver.
Cheers
Jan 20, 2009 | Agere All 56K Modems: 56K V.92 Lucent/...
Canon MultiPASS F50 All-In-One InkJet Printer Logo
117 people viewed this question
old marine
old marine
