Question about Microwave Ovens
Kenmore Elite taking long time to heat items
I Have a Kenmore Elite over the range microwave. It recently started to take long time to heat as if the power level has been decreased. I checked the power level, and it is set to high. All the items are taking very long to be heated. Can you please help me...
the model # is 721-64663300
Vishu
  • Microwave Ovens Master
  • 9,174 Answers
This is most likely a failing magnetron.
If it's less than 5 years old, Sears/Kenmore should cover the part, but you would still have to pay for a service call.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
SOURCE:
We just hooked up the hood fan and was wondering if it was normal that when you run the microwave the hood fan cuts in?
I do believe that is the normal way to get rid of the heat and any moisture while the micro is operating .
Aug 28, 2015 | Kenmore Elite Over The Range Microhood...
Kenmore elite microwave
Was it just the exhaust fan that came on? If so this is normal when cooking on the stove for long period of time without the fan running. The heat builds up under the microwave and eventually activates the fan.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Sep 05, 2014 | Microwave Ovens
What does F-7 error code on Kenmore Elite microwave mean
That's a problem with the inverter or another high voltage part.
Dec 24, 2012 | Kenmore Elite Over The Range Microhood...
Just need to re set the clock
Barbara, Google the model number with "manual" to locate (if you do not have it) the book.
Or, contact the customer service for this unit--I am sure with the recent time change they are getting a lot of calls.
Nov 08, 2012 | Kenmore Elite Over The Range Microhood...
My Kenmore Elite Microwave Model No. 721.64683300 does not seem to be heating well and will shut off and flash an F9 code. What does the F9 code mean
Oct 07, 2009 | Kenmore Microwave Ovens
Kenmore Microwave Oven Sudden Power Reduction
I would be sure to check the microwave's outlet under a load.
One good way is to use a toaster or hair dryer for about a minute to see if they run at full power and run without their heating elements dimming.
If the power at the outlet is steady, I would suggest a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it still fails to heat properly, I would say you have a failing magnetron, and it would just be a coincidence that the failure began after the new wiring was installed.
If you need to order the magnetron, Sears sells it for $73.13, but you can get it for $41.84 here.
Feb 14, 2009 | Kenmore 62622 Microwave Oven
Microwave not heating items
if it is fuse then there should be no lights or display at all. if there is, then it is not a fuse. it could be the magnetron.
the fuse is located inside the microwave. you have to bring it down and open the cover.
i hope i was able to help
pls rate me..
tnx ,
drcool
Jul 19, 2008 | Kenmore 62642 / 62644 / 62649 Microwave...
Microwave not heating unless exhaust fan is on high
check the control unit and high voltage circuit, and megnetron, high voltage diodes, wiring and high voltage fuse etc.,
Sep 26, 2007 | Samsung MW1030WA Microwave Oven
Microwave Ovens Logo
625 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
