Usb socket - Car Stereo - Not working
My wharfedale WH 180 car stereo will not recognize my philips gogear USB audio device.
I need to format the device to "level 1" or "level 2" but i have no clue how to do this!
Can anyone help?
6ya staff
SOURCE:
Anonymous
SOURCE: mp3 player will not work "usb device not recognized"
license key problem
Posted on Feb 10, 2008
Anonymous
SOURCE: Philips GOGEAR SA6045 MP3 Player doesnt register.
download windows media player 11 and i bet you it works i had the same problem
Posted on May 15, 2008
VANESSA72
SOURCE: car stereo code input protocol for blaupunkt 520 car audio system
- WHEN YOU KNOW WHAT YOUR RADIO CODE, TRY THIS: I JUST TRIED THIS ON MY 520 IN A HOLDEN VECTRA (1999) AND IT WORKS:
- HOLD DOWN THE 'AS' BUTTON UNTIL YOU HEAR A BEEP, THEN YOU GET THE FOLLOWING DISPLAY:
10 - - - -
- PRESS BUTTON NUMBER 1 UNTIL YOU GET THE FIRST DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 2 UNTIL YOU GET THE SECOND DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 3 UNTIL YOU GET THE THIRD DIGIT IN YOUR CODE
- PRESS BUTTON NUMBER 4 UNTIL YOU GET THE FOURTH DIGIT IN YOUR CODE
- HOLD DOWN THE 'AS' BUTTON UNTIL THE STEREO TURNS ON.
Posted on Jun 14, 2008
Anonymous
SOURCE: apple ipod model a1112 not working in car stereo
I have an apple A1112 model but i lost the software cd of the product, Can u help me in getting a software for the required model. I will be very grateful if you can provide or suggest me the same.
Posted on Jul 26, 2008
Anonymous
SOURCE: Philips GoGear SA6087/37 8GB won't sync songs anymore.
I had the same problem and sadly the only way to fix it is to go through and bring the mp3 player back to factory settings:\ it sucks but its the only way it will work.
Posted on Oct 22, 2008
Have a pioneer truck stereo. When I plug in my memory stick into my USB it plays a couple of songs then I get a error 19.
USB Flash Drive - Issues With Music In Car - Need to format to add ...
www.neowin.net > ... > Hardware Hangout
NeowinAug 11, 2014 - My Radio can see the USB drive and plays the music directly from it. ...drive, after that plug it in your car stereo, play a few songs randomly, disconnect, ....The index file should stick out like a sore thumb amongst your mp3 files. .... I haveripped some CDs into my computer, and then synched them to a flash ...
How to Format a USB Thumb Drive for Your Car: A Solution ...
doughaslam.com/.../formatting-a-thumb-drive-for-your-car-a-solution-to...
Nov 4, 2010 - Not being an iPod owner, I use it to connect a thumb drive that is big enough to ... There were a few obstacles to getting this just right, however, and I thought I ... I renamed the files (once copied to the USB stick, never touching my ... I could cram more info into the short car stereo display (the example in the ...
#234 - My USB flash drive shows as unsupported in my ...
? 1:19
https://www.youtube.com/watch?v=MgaZwtmbuA0
May 29, 2013 - Uploaded by hondadailytv
My USB flash drive shows as unsupported in my Honda vehicle. ... WMA or AAC when a USB flash memory device is playing. The USB .... Format USB via FAT32 file system and then Uploadsongs in mp3 format and plug into your car and .... I would haveto move/delete all my songs from the USB stick and ...
Jan 21, 2016 | Pioneer Car Audio & Video
When i put music on my pen drive it plays on my pc but not on my car stereo why ?
Chances are the music files are not in a format that your car stereo recognizes. Check the booklet that came with the stereo and look for acceptable file formats. (Something that says .mp3 or . something.). If it still doesn't work, the pen drive itself may need to be formatted for the car stereo to be able to recognize it. (Maybe FAT32 instead of NTSF). The information should be either in the book or on the manufacturers webiste.
Feb 04, 2015 | Dell OptiPlex Computers & Internet
Connect mp4 player to usb
USB ports on car stereos are not designed to be universal, regardless of what the USB acronym implies. They are typically designed for a specific product, either iPhone, Android, Blackberry, or a combination of those. They usually work with a blank flash drive (no operating system on it). That would be my recommendation: Buy a flash drive. $5-$10 invested will probably get you more storage than the GoGear and will work with USB.
The reason USB sounds better than the auxiliary input is because with auxiliary, the D-to-A (Digital to Analog) conversion is done by the GoGear, while with USB it is being done by the car stereo.
Dec 20, 2013 | JVC Car Audio & Video
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
Oct 07, 2012 | Philips GoGear ViBE SA1VBE08K MP3 Player
My volume button broke
1 Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
2 Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager." This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button. Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode. Click the "Repair" button when it appears on your computer, then follow the steps to fully recover the GoGear. Properly disconnect your GoGear from your computer and restart the device.
3 Recharge your device if your GoGear dies suddenly while playing. Connect the GoGear to your computer via the supplied USB cord. Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on. This will begin the charging process of your GoGear. If recharging doesn't work, the battery may need to be replaced. Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
Apr 17, 2012 | Philips GoGear ViBE Digital Media Player
I was charging my media player and now it is stuck in charge mode?
Hi,Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Good luck.
Mar 11, 2011 | Philips GoGear ViBE Digital Media Player
Error 23 when connecting USB hard drive to car
You must format the USB to FAT32..! Works for me!
Jul 13, 2009 | Pioneer Car Audio & Video
Brisbane sd48 doesn´t read SDHC cards
I believe the Brisbane SD48 radio can only recognize memory cards up to 2 GB. Your SDHC memory cards probably exceed this 2 GB limit.
Jun 17, 2009 | Blaupunkt Brisbane SD48 Car CD/ MP3 Player
In car usb conection wont work
It appears this stereo is compatible with a limited number of mp3 players. I had the same problem with my Ford Edge Sync option. See if you can get a list of compatible players from the manufacturer/ dealer. If not, try different mp3 players until you find one that works reliably and purchase one.
Dec 30, 2008 | Wharfedale DVD-M3 DVD Player
Sony microvault 2 gb
my laptop does not read the usb stick, when i insert it, a pop up says usb device not recognized, and has malfunctioned. I am having this problem after using this usb device in a car stereo system. please advise i need to recover my data from the device. please help me in this issue.
Apr 10, 2008 | Sony 1GB Micro Vault Ultra Mini USB 2.0...
305 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
