Question about GE WSXH208A Front Load Washer
GE Front Load Washer
My washer leaks only during the rinse fill cycle. During the first fill it doesn't leak. I opened the bottom panel and during the rinse, I saw water pouring out of the left hand side of the tub (just below the where the water pours into the tub). Any suggestions?
  • 5 more comments
  • Anonymous Apr 06, 2008
    Mine has begun to leak also. I seems to be coming from the front left corner. It is dripping on the pedestal and then onto the floor. I purchased the extended warranty but it is only about 8 months old and am told it is still under manufacturers warranty. I am still waiting on a repairman to come.
  • Christy75 Apr 22, 2008
    I have the same problem with it leaking during the rinse cycle & the repair man (still under warranty) has came out 3 times now & can't figure it out. He said to call GE for a second opinion. Ridiculous.
  • Quarath Apr 27, 2008
    I am having the same issue but mine leaks during the initial fill. Seems to be running from down the left side of the door seal from around the area where the water usually fills the tub. I have had to replace the door seal once before and I have inspected every inch of the door seal and can find no rips or tears
  • Anonymous Apr 28, 2008
    Our washer, leaks out of the right side bottom near where the foot is located.  It leaks when we do any load that has towels or anything that gets heavy when wet.
  • Quarath Apr 30, 2008
    Sorry I posted in the wrong section to update my info i still hope someone can offer a solution or point in the right direction for diagrams or schematics that will help me successfully take this apart and put it back together hopefully fixed.
  • ejwebly Sep 19, 2008
    Mine is a WCVH6600HWW GE front load. I also had water leaking from the front right. I removed the lower panel (3-screws) and found water standing in the lower tray/frame. Also, I found a shell of a ball point pen - just the shell, sitting in the tray. I opened the filter and found the remains of the pen along with pennies, lint, etc. I cleaned this out. I ran another cycle and had no observable drips etc....until the final spin (max speed) and I noticed water leaking from the BACK of the seal (at the bottom). So looking inside (from the door open)...it seems like it is coming from the seal ... behind the portion that has the three drain holes....
    So how did the pen body find it's way outside the water loop? did it get forced out - penetrating the seal in this area? If so, the leak must be somewhere in behind the three drain holes of the seal OR underneath the lip of the basket (the rear of the seal). At this point I think I am forced to call the GE folks for an expensive repair trip.
    Any other thoughts?...Thank you.
  • DCrimmins Oct 30, 2008
    After replace the "boot" (which much difficulty) I found the problem. I removed the detergent dispenser and notice a hole punched into the plastic base which holds the dispenser. That can't be replace, but I put some waterproof duck tape on it and it's working.
Removing the lower front panel (3 screws nearest floor), and opening the round, white water pump filter cap (be ready to catch about 2 gallons of water!) is the best place to start. All you need is a Phillips head screwdriver and a large, flat pan (deep turkey tray works well)!
YOU WILL NOT BELIEVE what I found in my filter housing this morning (see photo below)!
The washer is working fine now, although I may go back and remove the entire water pump so it can be dismantled, thoroughly cleaned, and reinstalled.
Posted on Sep 22, 2008
Had the same problem and did 2 things to fix. Remove the bottom panel on the washer(3 screws on bottom front). Just to the right of the center is a white plug that you can unscrew. Before you unscrew, get an 8x8 cake pan underneath to catch the water that comes out(bigger if there is water stuck in your washer). Unscrew cap and take out filter. My filter had pocket change, bandaids, tape, hairpins etc in it(kids do their own laundry and aren't vigilant about checking pockets). Screw filter back in and put panel back on.
Also, lint was drying on washer tub viewing glass where gasket hit it. Gasket wasn't making a good seal there and thats where water leaked out. Clean the dried lint off. No more leaking for me.
Posted on Aug 10, 2008
    Problem Solver:
  • 4 Answers
My model is WCVH6260.
We also realized that the last time it worked right a shirt was totally destroyed in the machine. At the time we did not realize it. I think it had to have some got hooked on the incoming water spout and was twisted over and over again until it was shredded. i think it had to have somehow broken the incoming water spout to the tub.
I have no idea how to get to it. My warranty is up and I don't have an active extended warranty. I am somewhat mechanically inclined and can follow directions but I need some guidance as to how things come apart and where to start.
Posted on Apr 27, 2008
  • 487 Answers
Please give me model number of the machine
Posted on Apr 16, 2008
  • eric bosman
    eric bosman Apr 30, 2008
    follow this link LINK
    you will see the drawings of the parts
    It will help you pull it appart
Water leaking during wash cycle. How do you get access to inside
I use a putty knife about 2" inward , between the top and the front panel on each side . Give a good hit on one side while slightly pulling the front panel forewafd . Then do the other side . The front panel tilts foreward and hinges on the bottom with tabs . Then lift to remove .
Aug 02, 2010 | GE WBSR3140DW Top Load Washer
Our washing machine started leaking lots of water during the fill and empty cycles. Water pours out of front bottom left corner. Any ideas as to what is wrong?
My Maytag Ensignia washing machine leaks large amounts of water when filling and during spin cylce. What could be wrong?
Jan 04, 2010 | GE WSXH208A Front Load Washer
Washer doesn't run all the way thru cycles. It's
Removed hose connecting to water pump at tub. Removed clog (ink pen, coins, etc). Replaced and ran washer. Ran through all cycles - no leaking, no pausing of cycles. Problem is resolved.
Oct 01, 2009 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Wbsr3140 washer leaks
looking at the washer the front panel is held on by clips, take a flashlight and a butter knife and slide the knife in the top crack of the front panel and slide to one side until it stops. this is a clip. usually in line with the washer lid seam. there is one on each side. push in and up on the clip while gently prying door forward, and wala it will open. if you can fill the washer with water alone and it doesnt leak. you probably have a soap issue which can be solved by cutting the soap usage down
May 17, 2009 | GE WBSR3140DW Top Load Washer
Leaking from bottom of washer
Do you have the little door at the bottom to collect lint and stuff that goes through the washer? I had a leaking problem once when I simply didn't tighten it enough. Check that.
May 06, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Washer leaks from bottom during rinse cycle
Take the cover off the back, and look up, next to where you put the soap in, when it's filling/rinsing. There is (like) a (white) plastic valve body, and look to see if water is dripping out of it. I haven't figured out a solution to that yet, other than to replace it.
Also check the boot, coming off the pump. You could have a bad/dry boot, or a loose hose clamp.
Mar 21, 2009 | Maytag Neptune MAH5500B Front Load Washer
WASHER LEAKING
DO YOU MEAN THE SPIN RINSE CYCLE OR FILL UP?THE FRONT COMES OFF FROM UNDER THE TOP SEAM,USE A PUTTY KNIFE ON EACH OF THE FRONT SIDES,PUSH IN ON THE CLIP AND PULL OUT ON THE FRONT PANEL,DO THIS ON BOTH FRONT SIDES,LET ME KNOW,THANKS-MIKE
Jun 23, 2008 | GE WBSR3140DW Top Load Washer
Kenore 80 top loading washer leaks
If is leaking at the front of your washer its gonna be the pump
May 04, 2008 | Kenmore 24032\24036 Top Load Washer
Agitator Not Working
check your motor coupler, lid switch
Nov 08, 2006 | Hotpoint VBXR1090D Top Load Washer
GE WSXH208A Front Load Washer Logo
585 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
