Vizio on the fritz
The part number in the set is 6870qzc004a, does the part number you supplied interchange with this one?
Question: what actually pops on this board, I looked it over and all seems ok, unless its one of the IC's under the heat sinks.
Thanks AJ
    Sergeant:
  • 395 Answers
Yes it it is the sub part. It is the IC's that pop the way to prove this is to measure the voltage to this board Vs, VE, Vsus, and Va these voltages are listed on the panel. if any are low unplug the the connector from the power suppy reapply power and check the voltages again. if they return then it is the board that was unpluged. if not replug the connector and unplug the connector that goes to the Y main board and check again. be sure to remove power each time you unplug and replug the connectors.
Posted on Mar 17, 2008
My vizio m3d650sv turns on and plays fine for any where from 5 mins or maybe even an hour. And then makes a loud popping noise and the screen goes all distorted and shuts it's self off. I can immediately...
Vizio 0500-0507-0920 (DPS-353AP) Power Supply for M3D650SV are the part numbers. The actual part number is on the board. The item is not in stock and may be obsolete.
Jul 19, 2017 | Vizio Televison & Video
My vizio 47in LCD tv is making a high pitch noise while watching the tv. The directv is conected with an hdmi cable. Any solutions or explanations. The tv is 7 months old
Actually someone would have to open set and power it up--try to locate area where sound here is coming from.
The first place would be in the power supply which will have a number of transformers (not giant ones) that can vibrate hard enough to make a high pitched buzz or sound.
If localized to a single board the board can be replaced but in our shop if we have narrowed it down to a single part--usually some hot glue on the offending part can remove the sound---issue is not usually one that will cause a failure but irritates people in the same room with the set.
Since the set will have to be opened first to see or in this case hear where the sound is coming from it may be repairable without replacing a board.
SD TECH
May 05, 2012 | Vizio Televison & Video
I have a Vizio (Model #:LP2626, Model Name:VMM26F20I) and I know the power supply board is the problem. However, I cannot find anything on the board with any sort of identifying part number. I've...
Well,Vizparts show the picture of the power supply board wright?Take ur tv aparts,take out the power supply board and compair the power supply board on the picture to ur real actual board.Try Ebay.com another website u can tries.
Oct 27, 2010 | Vizio VA26L 26 in. LCD HDTV
I have a vizio vp3222 in plasma tv. My husband would like to repair it but he/we don't see anything wrong when we open it. It turns on and then immediately off. We need a diagram as to what is what and...
Most likely, it has a failing power supply.
My experience is that the Vizio support people can provide the correct part number for a replacement power supply, and the parts they sell have been very reasonably priced in comparison to other online sources.
Once you call them and they help diagnose the problem, you can order the part. With that part in hand, identifying it in the TV is easy, and it's just a matter of installing it.
Pretty easy job, actually.
Jan 08, 2010 | Vizio VP322 32 in. Plasma TV
I am looking to purchase additional T&B breakers. I need type TBBR2020 SWD double pole 20's and 15's. Where can I find them (I think they stopped making them about 10 yrs ago...) ??
i will double check my supplier to see if they actually stopped making them but even if they did almost all breakers will interchange with other brands like a siemens and a ge will interchange etc. any electrical supply store should be able to cross reference your model number to one that will work
Sep 25, 2009 | Thomas & Betts Thomas and Betts Circuit...
Vizio vw42l, the vizio light turns from ornage to
Does LCD screen backlight come on? If so proceed....
USE:CAUTION WHEN DOING THIS....
Try this if repairing yourself...find power supply, small board with no cover over it...check voltages on output pins/plug/connectors (white plugs) three in a row...
1 Plug has 24Volt supply..1 has 12Volt supply and 1 has 5Volt supply when read to ground (screw that holds board in) if you have these voltages it's a safe bet it's the main control board...I just replaced mine and it fixed a problem like yours.
Jul 10, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio on the fritz
replace the Z sustain board part # 6871QZH044C.
Mar 16, 2008 | Televison & Video
VIZIO 50" PLASMA
Wow. This is more comon than I thought. My 50" Vizio plasma just went out as will after a loud pop noise. Power button is still lit. Sound continue to come through but no picture. I will dig into it and see if I can find a appropriate solution.
Feb 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
