I don't have any specific information on this model.... but I can tell you that the problem is the vertical deflection IC or just the solder connections on the PC side of the IC. The part number usually starts with the letters LA and then 4 numbers. Will be on a metal heat sink. And sometimes there is a 1ohm resistor that opens and even the diode may be bad in that circuit coming off of the HV transformer through the resistor and then the diode then to the vertical IC Hope this helps.
