Vizio P42HDTV10A flickering
Hello everyone,
Our plasma started "flickering". I will try to describe it. The picture is faded and blurry in the background of blinking or flickering. If I disconnect the cable box or change the input, the problem is still there. When there is no source and the tv is just on the blinking is there and the picture is a bunch of red, blue green dots, probably each pixel. I have the TV back off and ready. Any help would be much appreciated. Vizio tech support said I need a new "main" board. I do not probe much after that. Would you agree? If agreed, which baord is it? Is there a reputable place to get the part?
  • 3 more comments
  • rgood15 Mar 16, 2008
    I have seen a few similar problems within the forums with descriptions of "sparkles". I have yet to see one with a solution yet.
  • Anonymous May 04, 2008
    I have a problem with flickering on my 47" Vizio TV(Gallevia) and it is terrible. It is hard to describe because it comes in different forms and sizes. Its amazing that you don't see this type of problem on the shelf at the store. I have had the main board replace. However, the problem still persists. I have also had issues with the infamous green screen effect.
  • Anonymous Jan 27, 2009
    My TV suddenly became faded and then flickered--it's like a flashbulb going off. I can watch it, sounds fine but it's not pleasant. Very washed out, black smudge here and there and the flashbulb/lightening thing too. It's only three years old, a 50HDM Vizio. Any ideas appreciated!!!!
  • Anonymous Feb 22, 2009
    Same Problem. Any solutions, sure sounds like lots of people are having the same issue.
  • Anonymous Apr 04, 2009
    I have the same problem with my 37inch vizio tv aftert plugging it into hd
SOURCE:
  • 106 Answers
SOURCE: Bright blue pixels on left side of plasma screen
try to adjust Vs & Vsc within 5% of their spec on the power supply board when you notice the problem.
Posted on Jan 01, 2008
SOURCE: red pixels
This prob shows up often in this set. To solve , remove the 4,784 screws from the rear cover. Plug in and connect the set. Operate until red dots appear. Locate the V_SET-UP control on the Y-SUS board ( the one on the right from the rear ) . VERY CAREFULLY and SLOWLY adjust till dots dissapear and STOP. This adjustment is VERY sesitive and requires only the slightest adjustment with a small insulated screwdiver and a steady hand. BE WARNED ... there are high voltages and high peak pulses on these boards. Not all heat sinks are grounded... some are quite lively. Dont touch anything else, unplug the set and carefully replace the cover. Good Luck..
Posted on Nov 08, 2008
SOURCE: plasma tv screen has green pixelating into pictures
I had the same problem and solved it with a factory reset. hold menu button dowm for 10 seconds and it will alow you to reset all the colors.
Posted on Jan 01, 2009
  • 4 Answers
SOURCE: plasma tv has no picture but green led is on
Try unplugging the TV for a few minutes (discharges the ballast/ps) then plug in and attempt to power on. I have the 42P Vizio over two years old and ran into the same problem a few times. First thought was a power supply issue, but the unplugging trick worked. Good luck.
Posted on Apr 17, 2009
pilot210
  • 39 Answers
SOURCE: Picture problem with Maxent Plasma MX-42HPM20
Very common problem on these sets caused by bad surface mount caps. Check on ebay for a repair kit it's the only place I know where one exists.
Posted on May 18, 2009
Snow on screen with no picture.loud noise on audio
42" Vizio TV flickering strobing easy way to repair VW42L ...
? 2:49
https://www.youtube.com/watch?v=Qba7_YHnXwM
Dec 2, 2013 - Uploaded by ozzysslayer
42" Vizio TV flickering strobing easy way to repair VW42L HDTV10A LCD TV ... EASY How to Fix Samsung LCD TV Flashing Flickering Screen!Missing: vp422hdtv10a ‎snow
Vizio Replacement Boards - ecoustics.com
www.ecoustics.com > ... > Plasma & LCD TV Forum
Apr 15, 2009 - I have a vizio p42hdtv10A that just went into a black screen. .... I have a Vizio VP422 HDTV10A that will not stay on or show a picture. I removed ... Vizio vp422 hdtv10a
Dec 20, 2011
May 13, 2011
More results from www.ecoustics.com
Dec 30, 2015 | Vizio VP422HDTV10A 42 inch 720p LCD HDTV
My Vizio p42hdtv10a has no picture, can I fix this myself?
Troubleshooting to Plasma Displays is a very skilled work.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 28, 2014 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio P42hdtv10a has distorted blue and white
Very likely the power supply is failing.
Dec 01, 2009 | Vizio P42HD Television
I have picture but no sound on my 42 inch vizio p42hdtv10a got any ideas? I just replaced the main board and got the picture back but no sound.Sound worked before replacing main board.Any ideas would be...
If you received a remanufactured board it might be defective,Or did you forget to hook back up the speakers? Sounds dumb but happens alot. Speaker wires get in the way,we disconnect them to look at a board or replace one.Often gets over looked.But I have received several defective boards.Hope this helps. Toddthetvmd
Oct 26, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Loud pop and then no picture. Vizio says we need a video card. Part number/Model Number P42HDTV10A/AHPFABAG1120935. I've been told parts are not available in the U.S. ???
Tries shop in the internet,Might tries these sites.Tv Repair World.com and Shopjimmy.com.Also tries Google all the links to Vizio.
Sep 09, 2009 | Televison & Video
Vizio 42" P42HDTV10A Picture very faded
It sound like you have a dark display. Replace Z Sustainer board will fix it.
Feb 15, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio 42" plasma tv model#p42hdtv10a
yes,veryry possible you have a bad transister on the power supply board .best way to fix it is to change the hole board.
Oct 14, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Gateway Plasma 42" TV
my 5 yr. old 50 inch plasma hd that i paid almost $7000 for started flashing for afew sec. when first turned on.progresivly got worse,flashed for about 30 min. then ok until turned off.after about a month power light comes on fans start then trips off. gateway phone 888 737 6949 wants $250 for power supply $330 for video?board $600 plus for other boards no guarantees.i fixed mine by spending $1000 for a new vizio 50 inch plasma hd.if anyone wants a free dead gateway email me,
archie
Mar 02, 2008 | Gateway GTW-P42M303 42 in. Plasma...
Televison & Video Logo
1,446 people viewed this question
Top Televison & Video Experts
Ekse
