Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool In-Door-Ice® Ice Dispensing System
It doesn't dispans ice and ice mixing shaft is not truning. How can I open the face to check for switch and clean sedementaion on water and ice push padels? Thanks
    President:
  • Whirlpool Master
  • 2,651 Answers
The dispenser front "pops" off by inserting a screwdriver under he dispenser front, look closely youll see 2 little slits where ot insert and twist from. as your inserting and twisting would be helpful to be pushing down on the top of the facade.(just plastic tabs holding on care full not to break. its pretty apparent after that. when re-installing Hang over the top and kinda give it a good smack down with the heel of your hand... but honestly before all that look at the wires under the door hinge make sure there are no cut wires. ( a natural pinchpoint created by the hinge mechanism)
Posted on Mar 16, 2008
Ice maker not dispensing, makes ice everything else works fine.
Open the ice storage box...ice will jam up not allowing the ice to drop down the shute.....
Mar 02, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
No water and ice dispensing
most dispensers have a hidden lock button that may be set the lock button is a child safety feature,despite that could be the door switch since they wont dispense with the door open or perhaps could be the switch on the dispenser cradle
Jul 18, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do i access the ice dispencer door in the door? The door is stuck open and freezes up the dispencer.
1. Disconnect the unit from the electrical
supply and wait for 3 to 4 hrs to get ice melted.
2. Pull out and unclip the drip tray on the ice
and water dispenser compartment.
3. Remove the screws from the ice and water
dispenser compartment front panel and
turn it over. The selector switch pack and
dispenser switches are now accessible for
testing.
Jan 29, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
My whirlpool stopped making ice cubes , water dispenser is o.k. and water to ice cube pan (rubber tube) won't stop running (leaking)
You are going to have to check the water solenoid to see if it is operating correctly. The solenoid operates from the AC power through a micro switch on the rotating cam. When the switch operates the solenoid is jerked out and allows water to flow. When the switch opens (timed to fill up the ice tray) spring pressure snaps the solenoid shut blocking the water flow. If the solenoid valve sticks in the open or partially open position, it allows water to leak by.
Jan 09, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Gold Side By Side Ice Dispenser Problems
Instead of what you think the sound is, try and see what is happening when you actuate the ice lever. open freezer door, depress the door light switch, or tape it closed. now actuate the ice dispenser lever, does the flapping door open, that which opens to allow ice from bucket into your glass? Now look at the bucket itself, do you see the gears rotating? remove the bucket from the door, and repeat, do you see the auger shaft rotating?
Either of these are a complex repair, one I would not recommend DIYers to try on their own, for they require taking the door apart, and if not done right, your door may not close properly. Normally I have no problem advising a repair, but there are some i dont, this icemaker system, and compressors.
Visit www.FixMyFridge.net for refrigerator service or to ask general refrigerator questions.
Dec 11, 2009 | Whirlpool GS6NVEXSL Side by Side...
Water dispenser won't work
check the freezer door switch; this is a safety so the ice maker wont come on while the door is open
Oct 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool side by side model # ed25uexhw00
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing. Take all the ice out of the bin and try. Anything? Take the bin out and try. Anything? The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter. If your are, probably bad motor. If not dispenser switch.
Sep 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
WHIRLPOOL ICEMAKER DESPENCER STOPPED WORKING.
It is either the motor going bad or the switch at the ice lever. The little micro switch that is activated by the ice lever is likely held in place by two little, week, plastic pins. They break easily. After one pin breaks, the switch can still be close by the lever, but it is hit and miss. It is a ****** to replace the bracket unless you have some experiance. One other long shot would be the freezer door light switch that shuts power off to the dispenser when the door is open.
Apr 15, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
297 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
