Question about Lindhaus Activa 30-38 Bagged Upright Vacuum
Convertable? I have a new Lindhaus Activa 30 and I want to know if you can purchas optional parts to convert it to do the dryclean function and is it something that can be done at home?
    President:
  • 1,673 Answers
It is a vacuum, you would have to consult where you purchased it, they should know what you add to it.
Posted on Mar 18, 2008
I have a Lindhaus powerhead MOD.PB12e SN123463. The powerhead turns on and the roller starts turning but after a couple of seconds it starts sounding like something is not letting the roller turn properly...
A common problem is for hair to get wrapped around and forced into the end bearings which causes the motor to work harder or drive belt to slip. Cleaning the hair out can be a short term fix but new bearings might be needed. It's also a good idea to replace the drive belt at the same time as the slipping belt is probably not going to perform well even with new bearings.
Mar 03, 2015 | Lindhaus Vacuums
Why does lindhause Activa 30 hose on vacuum comes off
My hose comes off as well. It gets 'unscrewed' over time using it. Simply screw it back in counterclockwise...
Sep 01, 2014 | Lindhaus Activa 30-38 Bagged Upright...
Order part
Duct tape latch. See if there's suction.
Apr 15, 2014 | Lindhaus Vacuums
My Lindhaus Diamante 300 has great suction but clogs
Sounds like you have some form of an obstruction in the hose ( i once found a tooth pick sideways in mine) most models allow for the hose to be disconnected from the vaccum itself, also make sure theres not a setting for attachments also, some models need the suction redirected.
Apr 08, 2010 | Lindhaus Diamante 300 Upright Vacuum
Where to buy bags
You did do a google search on this ... right? And what about the place where you bought the machine? It appears that you MUST go to an authorized dealer for parts and service.
http://www.lindhaususa.com/ Go here and search for a dealer in your area.
or
http://www.lindhaususa.com/dealers.php find a dealer here.
still can't find it ... contact the company http://www.lindhaususa.com/vacuum@lindhaus.it
Sep 21, 2009 | Lindhaus Vacuums
Getting the vacuum to start after replacing the bag
Behind the door and above where the bag is located there should be a piece of plastic, or metal that sticks out, at least in the manual, if the door isn't shut correctly, that piece doesn't push in the switch that is behind there, this is a safety feature built into a lot of vacuums, to keep people from running the vacuum without a bag in it. Most likely your lid just didn't shut completely. Check for that, and get back to me.
Jan 20, 2009 | Lindhaus Activa 30-38 Bagged Upright...
Lindhaus Activa 30 EOS Version
Check the inlet by the brush roll for a clog, also check your hose for a clog. Usually when there is a clog, it is sensing an overfull bag and will shut down to protect the motor. If there are no clogs, then there could be a problem with the circuit board or motor.
Jan 01, 2008 | Lindhaus Activa 30-38 Bagged Upright...
Red light stays on
Most likely the hose or the inlet down by the brush roll has a clog in it. The red light indicates a full bag, but if there is a clog, then it thinks it has a full bag.
Dec 07, 2007 | Lindhaus Activa 30-38 Bagged Upright...
Lindhaus Activa 30-38 Bagged Upright Vacuum Logo
64 people viewed this question
Top Lindhaus Vacuums Experts
JoeVacs
Are you a Lindhaus Vacuum Expert? Answer questions, earn points and help others
