Question about Philips PET824
No Disc message
The player will spin the disc for a couple seconds, saying "loading", then it will stop and say "no disc". Any suggestions?
  • 1 more comment
  • PCOOP Apr 03, 2008
    Thanks for the tip, it did play a cd but wouldn't work on the dvd after trying both......Guess I need to hunt Philips down to fix it. Unfortunately since I bought it online, they pulled a new card saying "we won't warranty items bought online as they may be refurbished". Philips is bunk, what a stupid policy considering that 40% of purchases are made online these days.
  • jrogers9138 Nov 11, 2008
    Shows "loading" -- with no result...does not shut down... just keeps "loading".
  • Anonymous Feb 26, 2009
    Mine does the same thing only the motor doesnt want to work all the time so im not sure what the issue is but i tried all the posts and none of them worked
I had exactly the same problem with my PET824. At some point I found that the player only plays CDs. With DVD it looked like it simply does not detects them as if there were no disk at all.
I tried the two recomendations posted here. Unfortunately I tried them both at the same time so I don't really know which one helped, but now player works fine and reads DVD again, even DVD-RW and DVD-R DL.
First, I moved the whole laser assembly to the most far point away from the center and second I rubbed the lens of the laser with a cotton swab soaked in pure (70%) alcohol, despite how carzy this might sound, but, yes with pure alcohol and these two steps worked like a charm. First thing I noticed that even loadind CD now takes twice less time as it used to be.
The player purchased at the end of 2006 and was in moderate use.
Posted on Jan 11, 2009
  • 476 Answers
Turn off the power.
Open the lid and gently push the laser mechanism to the outermost point of the slot.
Power on and try a disc again.
Also try cleaning the laser lens with a mild foam cleaner and cotton swap. Leave to dry and re-try a disc.
If neither work, then the laser is probably faulty. If the unit will play CDs but not DVDs, then this is a good sign of a faulty laser.
Posted on Mar 17, 2008
Pioneer DVD 717 - Not Loading Discs Whenever I load a disc, the player spins the disc for a moment before slowing down. to a stop. It repeats this around four times in succession before it then opens...
Hi msaslloyd ,
This could be because of a damaged lens , where the dvd player tries to recognize the disc but is unable to do so and then either sends the disc back i.e. the tray opens up or the message no disc loaded is displayed.
I suggest you to :-
  1. Clean the lens with a lens cleaner available in the market and load any disc in the player to check if it's working fine.
  2. Get the lens replaced from the market and the problem should be solved.
Hope this helps ..:)
May 10, 2011 | Pioneer DV-717 DVD Player
My player when loading dvd loads for couple of secs and cuts off
Does the disc spin?
If not you have my problem spindle motor suspected faulty if the disc spins then its not being read, faulty lazer assy Try cleaning the lazer using dry brush disc philips do a good one and also clean the disc you are trying to play if it still doesnt work its a fault
Sep 02, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
I am receiving the message "no valid disc" on the dual screens...
it appears yous direct drive motor is damaged. When a disc does not spin, it will say the same as a bad disc. You can easily get this fixed, but not cost efficient. Better off replacing it the component.
Jul 24, 2009 | kawasaki PVS1965 Portable DVD Player
DVD player will not play disc.
If you are loading a store bought DVD and that it what it say's. The transport needs to be replaced. roughly 150-200. If you are loading "burned" DVD's the format may be wrong and the unit cannot read it. Best suggestion I can give you is to first buy a "Laser Lens Cleaner" on that uses fluid. Any electronics store sells them for 15-20. Run it thru the unit a couple of times then try a clean, store bought DVD. If it plays, problem solved. With your DVD's, if you have any liquid car polish like mother's or meguiars, put a couple drops on the disc and spread around with your finger, let it set a couple then buff off with a microfiber towel. This works wonders for old scratched cd's and dvd's and helps protect new ones from getting scratched. As for the Lens cleaner, run it thru every product you have that uses discs 3 or 4 times a year, it's the best preventative maintance and only maintanance you can do on a CD player DVD or PC. Hope this helps
Jun 24, 2009 | Delphi 10.2" FLIP DOWN MNTR/DVD...
Stopped reading cd's
its means that your CD player cannot read data. actually the problem is in your lens. try to clean frist by cd cleaner disc with liguid and try. same problem change CD OPTICAL LENS.
Jun 07, 2009 | Audio Players & Recorders
Head spins and say "Loading" but then says "No Disc"
I cleaned the lens, but I also tip the play upside down with the disc in it and it seems to work.
May 27, 2009 | Audiovox D1917
Philips PET824 Logo
299 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
