Question about Maytag MMV5000 Microwave Oven
Keypad barely works
The keypad on my microwave is getting worse and worse. My question is should I replace the keypad or the microwave? If I choose to replace the keypad is it something I can do myself? If I replace the microwave, can I find one that will fit in the spot over the range?
  • anne_kynch Mar 30, 2008
    tell me more about your customer service. what would the total cost be for me to have you out to my home to replace the keypad?
  • Anonymous May 28, 2008
    Same problem. Keypad is going bad. Seldom works now. Can I buy a new oven which fits existing brackets? Micro wave is not that old!!!
  • Maytag Master
  • 9,098 Answers
Keypad replacement is something most DIYers can handle okay, or for only $39.95 plus parts, we do them for customers nationwide.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There may also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
  • William Miller
    William Miller Mar 30, 2008
    On-site service is only available in the Central Indiana area.
    Customers normally ship their control panel assemblies here for repairs.
    Assuming you have the Maytag MMV5000, this one is a bit expensive, and the total cost would be $110-115.
    http://www.fixya.com/users/microwavesvc
My start button isn't working....I can press the "popcorn" button and it will automatically turn itself on and cook whatever I have placed in the microwave, but nothing happens when I press the "start"...
If it will start automatically without using the 'start' button, the 'start' button must be bad. If the door sensing switch was bad, it wouldn't start at all. It needs a new keypad. The most common cause of a keypad failure is from spraying a cleaner on it instead of using a just barely damp cloth to clean it. The liquid can run down the front of the laminated keypad and get into the bottom and seep up into the lamination....
Nov 03, 2013 | Jenn-Air JMV9169BAS Convection Microwave...
I have an Emerson 900W Microwave MW8999SB and it will randomly assign DEF1 and the rest of the keypad is difficult or not functioning. None of the quick buttons work, and only the 30-second button works....
Pressing the Clear/Pause button works. Sometimes. Most of the time, about a microsecond after pressing Clear/Pause, it goes right back to def1. Most of the time, pressing ANY button doesn't work. Usually takes me 10 to 20 tries to get anything to work. My microwave is about 3 months old. I will never buy Emerson again.
Sep 27, 2013 | Emerson MW8168B Microwave Oven
JVM2070SK02 keypad inoperable
bad main control board easy enough to replace but can be pretty pricey. worse comes to worse check voltage to board if getting voltage main board bad
Jul 25, 2012 | GE JVM2070 Microwave Oven
GE HVM1540DN1BB over the range microwave. Touchpad will not respond. Unit was purchased in July of 2008.Can it be fixed or should I replace It?
We had this same problem. I went on youtube and there is one link called "Quick Fix for GE Microwave." The guys shows how to take the panel off. You take the connectors off and put the keypad on the table and pull the ribbon tab out of the connector (don't take the connector out of the board, it doesn't some out). Then you put the ribbon tab back into the connector and it works. The ribbon tab just needed to be reseated. The whole thing took about 5 minutes. I was ready to listen to all these other people and go out and buy a new keypad. . .even worse. . I was ready to pay $500 for a new microwave. No way. . it's done. My wife thinks I'm so amazing blah blah.
May 03, 2010 | Whirlpool MH7140XF Microwave Oven
Microwave Oven
I report from owner manual.
F3 means : Short circuit on key panel (your touch pad).
You get F3 error if a shorted key panel is detected for more than 60 seconds.
Solution: . Replace key panel (touch pad).
Try first unpluggign power cord for five minutes.
If you think that the problem may had been caused by water inside the keypad you can try using an hairdryer on the keypad, taking care not to melt the keypad plastic.
If that does not work, then replace the keypad.
You can buy replacements here. or Order GE Microwave Ovens Parts Here
Mar 08, 2009 | GE JVM1630 Microwave Oven
Tricky touch pad on Sharp R530 es microwave oven
There are two options here:
1. Order a new control panel frame which has the keypad, trim piece and door button already installed and swap your control boards into it.
The original part number FPNLCB346MRK0 has been replaced by part # FPNLCB346MRK0B and it runs $58.28 plus shipping.
2. Disassemble your control panel frame, peel off the old keypad and stick a new one on.
Even though the keypad alone runs only $35.66, this job takes a lot of time and labor.
If you (or someone you know) might want to replace just the keypad yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
Whichever option you choose, we have the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it already.
Jan 18, 2009 | Sharp R-530ES Microwave Oven
KEYPAD STICKING AND STOPS WORKING
Obtain a replacment keypad and replace it. The non serviceable contacts inside of the key pad or going bad.
Dec 31, 2008 | KitchenAid KCMS1555RSS Stainless Steel...
Keypad on the microwave doesn't work
well if you find out that your microwave keypad is not working, like those numbers or letters are not working, there's a 16 or 8 plug cords wire attach to the keypad and the motherboard.you need to clean that with normal water temperture.than dry it for about 10-20 minutes.
I garintie you it will work.
Jun 02, 2008 | Microwave Ovens
Night Light
Your Control Key Pad is a circuit with each function and button a switch. The pad on your TV Remote, and Telephone is no different. The Key Pad is failing, It will only get worse. Determine if you can replace the Touch (Key) Pad. Not the Control Circuit, just the Touch Pad. Sometimes you can get it seperate. It connects by a Flex Cable to the Control Circuit.
Jan 28, 2008 | Frigidaire PLMV169DC Microwave Oven
Maytag MMV5000 Microwave Oven Logo
324 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
