Question about Toshiba 24AF45 24" TV
Toshiba 24AF44 Hello, I have a Toshiba 24 TV that I lost a remote too. I purchased a new universal remote, it works and will change channels and volume etc. However, it will not change the input. There is no manual way to change input on this tv and I don't know what to do next.....? Any suggestions?
  • 30 Answers
You need the original remote controller to be able to switch input modes.Universal ones usually don't work. If you don't have the original remote and can't find it ever or if it is too expensive you can buy an rf modulator ( very cheap) and connect your dvd player, game console etc) to the modulator then connect the modulator to your antenna with a coax cable. This worked for me. It placed the connection to channel 4 and other cable channels are still working,
You can buy the RF Modulator from: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=180299245670
Posted on Oct 28, 2008
I lost the remote to this TV as well. I tried two Universal remotes, neither of which would activate the menu window (no matter which buttons were selected). I spoke with a technician at Toshiba who indicated that there is no way to access the menu on this TV without the original remote control. It's simply a design flaw. There is no magical combination of buttons on the TV (volume, channel, etc.) that when pushed will activate the menu screen. You can purchase an original remote on eBay for about $20.
Posted on Oct 20, 2009
  • 34 Answers
Universal remotes will change the input it just may not be an input button. Try a button that says TV/VCR or TV/VIDEO or even COMPONENT SWITCH. If not try using a different code with the universal remote, the one that you picked may not be the most suitable for your TV.
Posted on Mar 16, 2008
My rca remote turns the toshiba tv on but it dont change channels
U are using an RCA remote with Toshiba tv. You are lucky that it even turns the set on. You have different remote frequencies involved and need to use the Tosiba remote or a universal remote that will operate volume, channels and power.
Mar 17, 2015 | RCA Televison & Video
I lost the remote and can no longer change the input. The only buttons on the tv are power, channel up and down, and volume up and down. I have also tried changing channels past 0 and nothing is working. I...
Hello
It will be best for you to buy its original remote control. Universal remotes may also work with it, but some functions may not work properly. You can buy it from the Authorised Service Center for Toshiba at your town. Just give them the exact model number of you TV set [which can be noted at its back side]. They will give you the exact original one.
RCA RCR 311B model universal remote have setup codes for Toshiba. You may also try this remote. The codes are:
1047, 1071, 1103, 1105, 1108, 1159, 1163, 1178, 1188, 1190, 1191, 1196, 1211
I strongly advice you to buy its original one. OK.
Sep 04, 2011 | Toshiba 27AF45 27" TV
I lost my remote and can't change the channel on the control panel. It is on channel 02 and it won't change even when I hit the channel+ or channel- button.
Hello.
Your problem is stuck keys in your T.V. It usually just needs cleaning, BUT it is hard to clean, because you gonna have to open up the whole TV. I advice you just buy a new remote from JVC or just buy a "Universal Remote".
Jul 18, 2011 | JVC AV-32D305 32" TV
Purchased an RCA universal remote (RCRH02B) and the codes listed in instructions don't work. After programing (or trying) the device with all the codes individually, the TV will turn on and off,...
Consider that you may have a bad remote. You never mentioned why you bought a new remote. Did the original remote quit working? If so, the problem may be with the TV.
Jan 04, 2018 | Toshiba 13A24 13" TV
1. the newstar universal tv remote contrlol i bought, cannot change the channel, although i can use the adding/minus the volume. 2. in as much as wanted to use also for te change of channel, i follow...
Unfortunately, universal remotes often do not work as well as the packaging says.... but all hope is not lost.
First, try ALL the programming codes listed for your brand of TV. Often, one will work. Be sure to follow the programming instructions, which usually have you trying the POWER ON/OFF button first after reprogramming.
If that fails, most universal remotes have a "scan" feature that, when you start it, will cycle through every code it has stored. During a "scan" you keep the remote pointed at the set and when the set powers off, you hit the ENTER key (or the key specified in the remote manual) to stop the scan and test the functioning of your remote (channel +/-, VOL +/-, etc.)- it takes a long time and can get frustrating, but keep trying and you should find a set of codes that will operate your TV correctly.
If you have no luck, do not give up hope completely- I would next recommend that you purchase a Philips brand universal remote- this is the brand that I have found to be most flexible.
Mar 02, 2011 | Televison & Video
I tried to program my Toshiba TV Model 27A43 to a new Universal Remote, because the original Toshiba remote was functioning more+more slowly ( I changed batteries on the original Toshiba remote first)...
Yes do a complete new channel scan. Play this like you just got the TV. If you want to buy the OEM factory remote you can most likely get it at the link and avoid all this hassle. Follow the link below. 1 800 Remotes
Mar 28, 2017 | Vacuums
Can't get the channel to change so that the cable works, it's stuck on Channel 4 and needs to be Channel 3
i take it you dont have a remote and your control panel is not working the best fix for this is to go and purchase a cheap universal remote control and program it to your tv this will allow you to change channels
Jan 02, 2011 | Toshiba MD20FL1 20 in. TV/DVD Combo
Hello, I purchased my Toshiba TV 27DF46 at a thrift store and it did not have a remote and I cannot figure out how to get my av ports to work. I have tried changing the channel manually and using my...
There are several different options to solve your problem. You should be able to program your cable box remote to replace many (but probably not all) of the functions of the Toshiba TV remote that you're missing. Read the user manual that came with your cable box remote to find out how to program it to control different types of components. It's not very difficult and that would be your least expensive option. Another suggestion is to buy a "universal replacement remote" that are sold in many electronics stores. Once you program those universal remotes, they will perform most/many of the functions of the original (Toshiba) manufacturer's remote. A "universal replacement remote" can cost anywhere from $20 to well over $100 depending on how many electronic components you want to control. My best suggestion would be to buy a replacement remote that was specifically made for your Toshiba model 27DF46 TV. There are many companies on the Internet which sell those remotes specifically made for your TV. The cost is usually between $25 - $35. One last inexpensive option would be if you already have any other Toshiba components (like a Toshiba DVD player), in many cases, the remotes are nearly identical and will provide most or all of the same functions. I would start by trying whichever option makes the most sense for your particular situation. Good luck.
Aug 11, 2010 | Toshiba 27DF46 27" TV
Toshiba TV 27AF42 purchased 7-2-02 Have cable
It's not the TV. Its the remote. Remote controls don't last for ever. Try a universal remote. Try Radio Shack it should do the job. Do you have a cable converter then ask your cable comapny to give you a new remote.
Mar 18, 2010 | Toshiba 27AF42 27" TV
I have a Toshiba 24af42 with no remote. I am trying to change the input, but without a remote I cannot figure out how to change it. I have tried a universal remote which works for other functions, but not...
Try this website 1-800-remotes Factory original u can buy an original remote,tries Channels up or down couple times u should get in the input 1 or 2.
Oct 22, 2009 | Toshiba 24AF42 24" TV
Toshiba 24AF45 24" TV Logo
2,411 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
