Question about Frigidaire FRS3R5EMB Side by Side Refrigerator
Freezer won't freeze
On my side bt side frigidaire freezer will not freeze and refrigerator is not cold. I checked for dust on the condenser, it really was not dusty, need help thanks, this unit is only year and a half old
Markis
  • 1 more comment
  • sbeery May 17, 2008
    Kitchenaid Superba 42: Freezer won't freeze and refer is not cold as it should be. I cleaned the condensor, does not appear to help.
  • j_h_c2001 Dec 08, 2008
    I have a Frigidaire chest freezer that is 18 months old. Gets cool, but won't freeze anything solid. I can hear the fan running. How do I know if the compressor is working or whether the system has a leak?
  • Ron Coons
    Ron Coons May 11, 2010
    any sounds from the unit while runnning??? sound like its trying to start???. was the compressor hot or at least running when you were back there cleaning coil?
Compressor may be the problem,by pass the thermostate connections & chelk cooling replace if working.some sort of leakage may also be the problem.
Posted on May 19, 2008
SOURCE:
Frigidaire gallery temp is rising. The refrigerator is 2yrs old. Now it is make a buzzing sound. The freezer temp is set at 0 fridge is 33. Everything is defrosting....help
The only thing a customer can check is that the condenser coils are free of dust and that the condenser fan is turning. For everything else you need an engineer to diagnose and fix.
Your fridge is set a bit cold at 33'F which is only 1 degree over freezing. The internal temperature should be read with a fast acting digital thermometer left in the fridge for 5 minutes. 35'F is the optimum. 0'F for your freezer is correct.
Sep 05, 2018 | Frigidaire Refrigerators
My Frigidaire Mod. # FRS6R5ESB0 P/N 218888702 side by side the freezer is cold close to freeze but not freezing, what can I doo, I already clean the coil condenser and the entire back compartment. Thank...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 25, 2010 | Frigidaire FRS3R5EMB Side by Side...
Refrigerator is cold, and freezer is cold but doesn't freeze
Refrigerator
heatman101
Dec 12, 2010 | Frigidaire FRS3R5EMB Side by Side...
Water filter inside fresh food compartment keeps freezing up? Frigidaire brand 3-4 years old. Thanks, Steve.
hello,
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze
Check the cold control, and also the air deflector. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control.
Hope this helpout....
Aug 08, 2010 | Frigidaire FRS6R5EMB Side by Side...
Frigidaire refrigerator does not seem to be cooling or freezing completely. Frigidaire refrigerator does not make any noise and does not seem to be cooling or freezing. I have checked the back of the unit...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
nmnm
Sep 24, 2009 | Frigidaire FRS3R5EMB Side by Side...
Model 532 freezer will not freeze
Check a Condenser, if it dirty and full of dust and lint - clean it with soft brush vacuum, it's behind the grill with Sub-Zero logo on it. Right hand side usually
Jul 13, 2009 | Sub-Zero 690 Side by Side Refrigerator
Freezer freezes up and don't know if there is a reset
sounds like the condenser is bad, feel the copper coils they should be cold and the condenser should be hot/
May 20, 2009 | Frigidaire Gallery GLHT214TJ Top Freezer...
Condenser fan torque question (F'aire side-by-side)
It should not need help getting started and will hurt a little to stop with one finger also it will cause the sides of the frig to get warm maybe even hot around the door try puting a small fan behind the frig with the back panel off till you can replace the fan that will help you know if that is causeing your cooling problem
Mar 30, 2009 | Frigidaire FRS26R4A Side by Side...
Frigidaire upright 13.7 cf
Will it freeze water? The vent coming into the freezer may be blocked. Check that and see. Is the refrigerator keeping those items cool? You may also have a vent blocked by the fan cover (dusty). If all this is right, you may have a freon leak or worse a compressor or evaporator going bad.
Feb 02, 2009 | Frigidaire 13.7 cu. ft. / 388 liter...
is the fan running ion the freezer is the compersser runing and the cond fan >??
May 10, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire FRS3R5EMB Side by Side Refrigerator Logo
563 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
