Creative Labs Nomad Jukebox Zen Xtra MP3 Player Logo
Posted on Mar 16, 2008
My nomad jukebox zen xrtra (creative) isnt starting
When i start it with just the battery, it stays on the eax startup logo, then after a few minutes of weird clicking, it takes me to a menu with this on it:
rescue mode v1.13
boot v1.2, HW v0.0.1
1:clean up
2:format all
3:reload OS
4:reboot
when i choose clean up, nothing happens, when i choose format all or reload os, it says "harddisk problem"
when i have the player hooked up to the computer or into an outlet, it repeats the start-up process described above (without the menu part) over and over until i unplug it.
i tried using the reset button but it does nothing but restart it, which doesnt help me at all. PLEASE! I DONT WANT TO HAVE TO BUY A NEW MP3 PLAYER!!! HELP ME OUT!!!
ps - this problem started when i was listening to a track on it, but it randomly started playing about one second of another song, that was played shortly beforehand, at random times. i soon got annoyed with this so i tried skipping the song to see if that would make it stop, but when i pressed the next button it froze up and nothing worked. i tried turning it off and that wouldnt even work, so i ended up having to just take out the battery and put it back it, but when i did, the whole long wait and useless menu thing happend.
  • 5 more comments
  • tullyb Apr 30, 2008
    I'm having same problems. Reset doesn't solve issue. Buttons sometimes work, sometimes not. Bought as reconditioned item. Can anyone advise if reinstallation of OS works and if so where to download OS.
    Thanks tullyb
  • thatguy5 May 05, 2008
    This has happened to me on two different Zen Xtras. I ended up replacing the first, and now its happened again. I'd love to at least be able to get the music off of it so I don't have to re-build my collection from scratch again.
    D
  • Nettman_s Dec 06, 2008
    Hello , I have the same problem with my zen Xtra. Have you found a soultion?
    Thank you mark
    [email protected]
  • pdmg Dec 07, 2008
    stuck in rescue mode
  • bevwake Dec 10, 2008
    Exactly as described !!!!!
    I've had it for about five years but don't really want to replace it . ANYONE got any ideas ???
  • Anonymous Dec 16, 2008
    not able to listen or hook up to computer
  • mutpuppy2000 Feb 27, 2009
    when i start it with just the battery, it stays on the eax startup logo, then after a few minutes of weird clicking, it takes me to a menu with this on it:
    rescue mode v1.13
    1:clean up
    2:format all
    3:reload OS
    4:reboot
A
Anonymous
Sounds like the hard drive is bad
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 18, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
424
Points
The exact same thing happened to me and i solved it by dropping the unit from about 6 inches onto my desk.
It made a horrible thud butI think it must have had something stuck because now it all works fine again.
Hope it helps
Dave G
40 gb mps nomad creative
When it gets to the EAX screen tap it ******* the right side just above the menu button, wait for the drive to kick in and it should work again.
Creative Nomad Jukebox Zen Extra
Whirring noise = bad, probably needs to be replaced, BUT:
Uninstall everything from your PC, reboot, reinstall driver and the Explorer (I do not use MediaSource, only the Explorer).
If it didn't work out follow these steps:
1. Uninstall Creative Media Source and all related software.
2. Install the driver. In the installation CD the driver is usually in \Drivers\English
3. Turn on the Nomad an connect it to the PC.
4. Install MediaSource(the program requires that you have the nomad connected while installing)
5. Install MediaSource plugin
6. Try transferring files.
If you?re still running into problem know that there are other programs capable of handling MediaSource?s functions, such as - Portable Audio Devices Power Toy , NomadSync, Real player, and there?s also a Zen plugin for the Winamp.
2answers
Buttons won't work
Reset - do the four things in svc mode
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
1helpful
2answers
60GB Nomad Jukebox Zen Xtra stuck in startup loop
mine did the same until i got a new power supply. it requires a 5volt dc pos tip charger with 20 watts. a universal 3-7.5v 2amp charger from radioshack does the trick. make sure the tip is yellow for the charger.
2answers
My Nomad zen xtra 40gb is stock !!!
It sounds like the hard drive may be damaged. Have you tried to put it in recovery mode?
Put a paperclip in the reset hole while holding down the play button until you see the screen go to recovery mode. Then try the format option; this will erase all your files but it will tell you if you need a new hard drive.
Nomad jukebox 40GB
Have you tried pushing the reset button on the side as you power it up?
It's possible that you need to replace the hard drive or reload the firmware. Or both.
3answers
Creative Nomad Jukebox Zen Xtra
First thing i would do is make sure your at the current firmware.
Wont start
try new batteries, does the unit have a reset?
Top Creative Labs Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
