Question about True T-49 Side by Side Refrigerator Commercial
True TS-49 Refrigerator freezing food
I have replaced the thermostat but doesnt seem to have made any difference. While replacing thermostat found frost/ice on evaporator (but only on back side, front of evporator is clear).
Any help would be greatly appreciated.
Thank you.
  • VaBaker May 04, 2008
    Thanks refritech,
    After I replaced the thermostat, I spoke with a tech from True, He told me from my description that it sounded like it was working properly, he said when thermo is set to warmest setting it should cool down to 31-32 degrees, and when in defrost should warm up to about 40-41 degrees. I seems to be doing that now. However, occasionally the temp drops to 28 degrees. The only produce that freezes occasionally now are the lettuce and cukes. so I moved these to a smaller fridge. Not ideal, but can work with it. Im handy but not knowledgable enough to check the defrost timer or thermo... as I dont know where there are. lol I will try to find a schematic and go from there. thanks.
  • Anonymous Jul 17, 2008
    We are having the same problem,except ours is freezing everything,we changed out the thermostat acouple of months ago. Now it froze up again! We turned it to the lowest setting and the next morning it was reading over 80 degree farenheit. Turned power off then back on and it got cold again but is now freezing up again. Now the fan in the kitchen was off and ambient temperature in the kitchen was in the low 90 's.
NEWER T-49 s DO NOT HAVE ANY DEFROST HEATER OR TIMER OR CUTOFF'S All solutions involving repairs on these items are bogus. The defrost occurs when the compressor shuts down normally. During this time,since the fan never stops, it should circulate above freezing air around the coils and a slow defrost may occur. It is a poor system at best, and does not work well if the compressor runs a lot. MY erratic cooling was fixed by removing the copper sleeve and cold control probe from the evaporator(cold coil on top) Polish up the copper tube and the probe, reinsert and bend the copper sleeve very slightly so that it fits snuggly into the evaporator. Mine was very loose and not making good contact with the metal evaporator, giving erratic control of temperature.. Good Luck!!
Posted on Dec 22, 2009
I have had a freezing problem with this unit also. I restricted the air flow on one of the cooling fans in the top of the box and dialed down the thermostat. It now stays in the proper cooling zone. I used a paper plate to cover one of the fan holes and unpluged the one fan motor.
Posted on Oct 23, 2009
    Scholar:
  • 149 Answers
Is it still freezing up? probably your defrost timer or defrost thermostat is going a little bad.
Posted on Apr 20, 2008
  • Alexander  Figueroa
    Alexander Figueroa Apr 21, 2008
    check also the heater element, it can be verified with an voltmeter in the "beeping option"
  • 30 Answers
I would also inspect door gaskets to insure they are in good condition and sealing properly. hot air infiltration could keep a demand on the thermostat and cause it to run to long. also check the mounting of the thermostat sensing bulb, most of the true boxes use thermostats that sense the coil temp, not air. if it is not sensing the coil temp it will cause the thermostat to not function correctly.
Posted on Mar 07, 2009
I also have the same problem on my both the coolers. I bought them used but they are just 3/4 years old and look very new. But it can not control the proper temperature. Sometimes it's freezing and sometimes hot. The thermostat seems to be ok. Where the defrost thermostat is located? Where can I buy one it is faulty.
Thank you
Sunil
Posted on Sep 24, 2008
Temperature setting True tssu-60-16
if you tried to adjust the temperature and the cooler continues to freeze the food then replace the thermostat attached to the control knob. Thermostats fail in different ways
Link=> HERE
APPLIANCE 911
Jul 22, 2016 | True TSSU-60-16-ADA Stainless Steel...
The GDM-41 true cooler is freezing my food what do you guys think I am thinking of replacing the thermostat
Simply turn the temperatue up a couple of points..If it is freezing stuff it is set too cold !
Dec 04, 2013 | True GDM-41 Refrigerator
Our refrigerator is freezing all the food. The temp control is set at 3. Why is this happening?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 13, 2010 | True T-49 Side by Side Refrigerator...
We'd like to stop the True T-49 fans from running all the time
You would have to have your fans power supply wired in series with the thermostat.
Jan 06, 2009 | True T-49 Side by Side Refrigerator...
GE GSS25PGMCC refrigerator freezing food
hello I think that this is what you are looking for . Hope it helps you out with your problem.
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60218.pdf
Thank You for using FixYa
Dec 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Cooling probleums
The thermostat should only control within a specific range of temperatures. I believe your thermostat needs to be replaced.
Nov 22, 2008 | True T-49 Side by Side Refrigerator...
True t-49 refrigerator
Yes it can. You would have to call a service company to recover the refrigerant, remove the oil in the compressor. They would then replace the oil as well as the refrigerant. The metering device would also need to be changed, along with the thermostat.
Aug 17, 2008 | True T-49 Side by Side Refrigerator...
T-49 Relay
hi thanks for the question you gan get the relay at kemet electronics thanks the appliance doc
Jul 30, 2008 | True T-49 Side by Side Refrigerator...
True T-49 Side by Side Refrigerator Commercial Logo
4,387 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
