Admiral washer does not drain or spin
I verified the lid switch with a tester placed the probes and had a open then I pressed the switch and it still remained open I did not hear a buzz from the tester or read any resistance value. Would that mean the switch is bad?
    President:
  • 1,314 Answers
Yep ya got it you can jump it to verify and put it on spin if you want but when its depressed it should close good job one of my teachers once told me when i was all confused about appliances and things find out where the power starts find out where it stops and in-between is your problem
Posted on Mar 16, 2008
Amana NTW475OYQ1no lights or sounds. Verified power @circuit board. Someone closed lid on a shirt earlier that preventing lid to I open.verified switch waz working and the wife did a load of laundry.
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following ... Speed Queen, Amana Whirlpool ..... Lid lock lightflases; no spin cycle.
Amana Washing Machine NTW5400TQ1 Troubleshooting ...
www.repairclinic.com/.../Washing-Machine...-/Amana-Washing-Machin...
Amana Washing Machine NTW5400TQ1 Troubleshooting & Repair Help. Amana Washing Machine problems. Washer won't spin · Washer is making loud noise ...
Jan 16, 2016 | Amana Washing Machines
Admiral top loader no spin cycle
no i would cheak that switch out that u pushing down on mightbe bad try that 1st ok thx nick
Mar 15, 2008 | Admiral AW22 Top Load Washer
Wont drain and spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Pl click if helped.
Apr 17, 2013 | Whirlpool WTW4950XW Washer
Kenmore stylemaster 902202 will not spin, agitate or drain tub spins freely
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. Or
http://www.youtube.com/watch?v=TB_W6sPdzkM
Pl click if helped
Apr 07, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore Washer 70 series Model #110.22722100 won't spin
Click if helped.
Feb 25, 2013 | Washing Machines
Kenmore washer front load 417 wont spin
Click if helped
Feb 18, 2013 | Kenmore 24032\24036 Top Load Washer
My Admiral washer will not spin.
Unplug the washer.
Insert a putty knife between the top lid and the front panel,where the top meets the front. About 2 inches in from each side are 2 clips that must be pressed inward to raise the lid.
Once the lid is raised,remove the 2 wires from the lid switch and jump them together with a small jumper wire.
Plug the washer in again and turn the dial to spin and turn it on.
If it spins,replace the lid switch.
Jan 17, 2010 | Washing Machines
Admiral washer wont spin or drain
Possible lid switch problem, can be shorted out to prove, open the top complete lid for access. To do this insert a flat blade 4" from each side at the front panel between the front panel and lid to release the clips, lid will now lift and switch is on the underside of the lid RH side, short wires and test spin, replace switch if machine runs, do not leave machine with switch shorted and ensure supply is isolated as necessary.
Dec 20, 2009 | Admiral AW22 Top Load Washer
Agitates but no spinning or draining
Check the lid switch for continuity.
Open the control panel, disconnect the lid switch from the top of the cabinet.
Use a volt/ohm meter set for continuity. Insert the probes into the connector attached to the cabinet. With the lid closed it should get a reading. If no reading replace the switch.
While it is open you can make a jumper wire and jump out the lid switch wire going to the timer. Then turn the dial to spin and turn it on. If it spins it verifies a bad lid switch. If not, you have a bad timer.
Apr 29, 2009 | Kenmore 23822 Top Load Washer
Don't spin or drain
Motor is not reversing or going into spin for some reason, could be lid switch, programmer or motor, go for lid switch first - short out to test, but do not use without switch.
Apr 05, 2009 | Admiral AW22 Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
