Question about Microsoft Xbox 360 Console
Purple screen - that reads update failed
It will tell me to update the xbox but when i do this purlpe screen comes on & says update failed, & I tried to put another game in (an older 1) & it comes up as the same friggin purple screen. please help!
  • 4 more comments
  • ryos111 Mar 17, 2008
    I have the same problem now i cant even play cds or dvds
  • Anonymous Apr 13, 2008
    purple screen pops up when i put in a diffrent disc. its says update failed on my xbox 360
  • Anonymous Jul 04, 2008
    purple screen comes up whether hard drive is in or out
  • Whorse Oct 15, 2008
    I have exactly the same issue, Hard drive is perfect, with all the updates on it. I tried it on another console.
    Is there absolutely any way to get past the Purple screen?
  • Anonymous Apr 09, 2009
    I have the purple screen i sent off for a update disc from microsoft
    but it still comes up with the purple screen . Help Me ! please
  • alsiya May 11, 2010
    Solution Link . . . www.MicrosoftXbox360Console.com,
I finally found out how to fix this! go to this website :http://thepiratebay.org/torrent/4801064/XBOX_360_Update_Files and download the torrent. Follow the directions from the second page of this forum: http://360mods.net/index.php?name=Forums&file=viewtopic&t=9796 . all you have to do is copy the $systemupdate folder that you need onto a usb drive and plug it into the 360 then turn on your 360. you can find out what number update you need by the number at the botom of the screen or if your like me and dont have those numbers youll have to go back and forth untill it boots up to the right update. make sure your flash drive is cleared out except the $systemupdate folder. go one at a time until it boots up with that update file.
Posted on Oct 01, 2009
Hi can you please help i'm suffering with the same purple screen i've phoned up xbox support and they said that i have to take it back to where i brought it from,
i was just wondering if any knew how to get rid of the purple screen
thanks
Nick
Posted on May 31, 2008
Tools -> folder option -> view -> advanced settings. showing different stlye,so iam not able to see the show hidden file and folder option so kindly please help any one.
Posted on Mar 17, 2008
    New Friend:
Dont waste time with the sync button... there's what you need: Ask all of your friends for games. Then, one by one, put it in the dvd-rom, and wait, one of them will update your xbox and you'll be happy. Iv'e solved the problem with the game Guilty Gear 2 Overture... =) good luck!
Posted on Jan 29, 2010
After hours of trying to fix the problem myself I found something that worked. Google 360DashUpdates.rar and download it. Then extract the files to your computer. Start with the top one on the list(the one with the largest number which means the newest update) and copy the %SystemUpdate folder to the root of a flash drive or burn it to the root of a CD. Then insert the update date into the system and reboot it. If it is close enough to the update that failed it will ask if you if you want to update. If it does not ask for you to update then try an older update until it asks if you want to update. If you don't have a torrent program and a program to unrar the down then you can get one update to try from Microsoft's website here. http://www.xbox.com/en-US/support/systemuse/xbox360/console/systemupdates.htm
Posted on Oct 18, 2009
I fixed this same problem by having the disk that the update was on in the 360, then on the purple screen i held the sync button (little round button on front of console) and whilst keeping it pressed in i powered off the console, then whilst still holding sync button i powered on the console, seemed to do the trick
Posted on May 04, 2008
SOURCE:
I can't get off update screen for Xbox 360. I have update disk but it won't read it. I also have it on USB. Please help me get off this update screen
Let the Xbox update itself, when the update is done, you will be sent to the Dashboard. :)
But, try to update it via Internet (Xbox Live)
Jan 12, 2013 | Microsoft Xbox 360 White Console
How to fix a failed update in Italian
go to Microsoft's website and click products then click X-Box then put mouse over support and click X-Box 360 then click the third message down enter in you error code if nothing comes up contact Microsoft and tell them your problem.
Jul 31, 2012 | Microsoft Xbox 360 with Kinect Console
My xbox keeps coming up update now but wont do it if u say no it freezes
Check to see if your xbox 360 is connected to the internet. If your xbox is connected to the internet and still is not allowing you to update check your xbox setting. Sometimes your parental control on xbox 360 can stop you from updating your xbox. If all else fails try to take your hard drive off the xbox and reset your console to factory settings
May 29, 2011 | Microsoft Xbox 360 Console
How do I get rid of purple and green wiggly lines? The black screen that appears when switching between channels was green a couple of weeks ago, that problem stopped after I unplugged the set for a while....
You have a bad LCD control board,It overheats and causes colored lines,screen to darken,or the color go floresent. Also check the power supply for bad caps.
when you have it apart.They usualy go bad on these tv's. It will cause the tv to take longer to come on.Or you have to hit the power button several times to get it on.
Oct 26, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Xbox 360 wont load...
cleaning the lens usually helps with this. If you don't have the tools to do it, try using a can of compressed air. If that doesn't work the laser may need to be replaced.
Dec 03, 2008 | Microsoft Xbox® 360 Core System Console
Xbox 360
there was a new update released a few days ago for the xbox 360,it takes around 30-40 min on a 256kbps line..please check your network and download the update..also do not touch the console while its going on..an update may fail if the connection to the internet is faulty..hope it helps!
Nov 21, 2008 | Microsoft Xbox 360 Console
Xbox 360 update problem
well i think that you need to talk to the store where you got it
Nov 03, 2008 | Microsoft Xbox 360 Console
Update Failed Message on Xbox 360
SoulSlinger to_post_off.gif Mar 27 2009, 08:09 PM Post #7
X-S Enthusiast
Group: Members
I had change of heart, the guys over at 360mods prevailed on me to release this for free.
So for all to see , here is how you fix the update failed error in all cases:
The error seems to happen when the 360 is unable to read from the update source during the update. The only time I have actually seen it occur was when updating from a backup, which is a common cause Ive read about. The other common cause is an onset of RROD during the update. Im not sure what causes the hard drive error. Either way, the solution is simply to supply the 360 with the correct update file either on a CD or a USB stick. Now here's the rub, it has to be the exact same update file as the one that failed. Not a problem since I've made a nice torrent file with all of the updates to date here:
Google
The version number is shown at the bottom of the error screen. PV is for previous version and CV for current version. Just put the file matching the current version (the one you are updating to) on a USB stick, (i.e. E:/$SystemUpdate) put it in your 360, and power up. If you have the right one it will finish updating and boot to the dashboard. Voila.
This has worked for me on 7 consoles so far. 3 of them said they couldn't detect the hard drive and the other four the update disc, so this seems to work in all cases. I hope this can help some people out.
Oct 03, 2008 | Microsoft Xbox 360 Console
Xbox 360
raadsim
When any game is put into the console it says that it is an unreadable disc it says that with every game i have.
Mar 25, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
2,519 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
