Question about Dryers
Need to know what the installation instructions for the Maytag Epic Frontload Dryer QS400 Intelldry Sensor is as we are doing the rough in on our new home. Please advise where the Vent is locatated at the back of the dryer. Thankyou
    President:
  • Dryers Master
  • 2,651 Answers
You can visit hte maytag site itsel and down load the installation guide. youll need the model number though not just the type
http://www.maytag.com/support/manuals_literature.jsp
Posted on Mar 16, 2008
SOURCE:
I have a slow drip at the bottom of my front load washer door (Maytag Epic Z). It leaks through the bottom of the door and drips down the front of the washer onto the floor. Has done it since I bought it...
Yes the seal might need replacing. but in my experience a simple strand of hair caught on the seal will make it leak. So i suggest that you try thoroughly cleaning the seal fist. If its needs to replaced, its not that difficult, but its kind of tricky. Check if your machine is still under warranty by contacting the manufacturer. hopefully it is and they will change for you for free. If its not under warranty let me know and i'll try my best to give you detailed instructions on how to change it.
Feb 06, 2011 | Maytag Epic 7.0 Cu. Ft. Super Capacity...
Need instruction on how to install a new boot on maytag epic z washer
The boot will have a retaining wire on both the front panel and plastic tub interfaces. You need to remove the front panel wire first. Simply pull the lip forward until you can see the wire. Use a pliers or screwdriver to remove it. Peel the boot off of the front panel and you can see the attachment to the tub. Same removal technique.
Be very careful when installing the new boot to be sure it is seated fully and correctly all the way around the tub. Reinstall the retaining wire. Same installation technique for the front panel.
Good luck.
Jan 22, 2011 | Maytag EPIC MFW9700S Front Load Washer
I have a Maytag Epic Z. The dryer turns on but with no heat
There are several things that can cause this. 1 st the thermal fuse(white plastic piece with 2 wires attached to it, then the igniter, is it glowing orange when you start the dryer, then the flame sensor located on the side of the burner assembly and finally the gas coils located on the gas valve close to the burner assembly. If the igniter is glowing orange and then going out without ignition change the gas coils, Hope this helps,
Feb 04, 2010 | Maytag EPICz Electric Dryer
I need to change the bellow on my maytag front loader. Do you have any instructions?
The following link explains how to change the bellow on a Maytag Epic:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
Later models of Maytag washers are manufactured by Whirlpool, so these instructions should apply. If you have any questions, please let me know. I hope this helps you.
Sep 02, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag epic frontload dryer won't unlock
Hello, unplug the washer remove the lower front access panel, get to the switch and pull downward on the circullar shaped release tab. Now drain the machine manually, take the filter out of the pump and clean out. reassemble and test. good luck
Dec 09, 2008 | Maytag EPIC MFW9700S Front Load Washer
Dryers Logo
89 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
