Toshiba 61A61 61" Rear Projection Television Logo
Posted on Mar 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba no picture
I have a toshiba projection televison model 61A61 and I just moved cross country, now my tv has sound but no picture. The tv screen remains totally black and I cannot get anything to appear on the tv while using the remote or directly using the tv itslef. no picture from cable or dvd
  • beyng4ever Mar 17, 2008
    so what do I do fix it?
  • Anonymous Mar 12, 2014
    no picture, the screen remains black, even the dvd fails to produce a picture
Anonymous
Level 3:
Guru:
  • Master 1,894 Answers
  • Posted on Mar 17, 2008
Anonymous
Master
Level 3:
Guru:
Answers
1894
Questions
13
Helped
563492
Points
4850
Then your optical section has fault.
  • Anonymous Mar 17, 2008
    ignore my first post. u have got to try few things before that
    First, unplug the tv and connect it directly to the power line,
    bypassing the surge protector to make sure that is not the problem -
    then after you have gotten everything fixed up you can reconnect it. I
    don't trust surge protectors either.
    Second; the firt thing to do whenever the tv acts up is to reset the
    internal software codes that control everything that goes on
    internally. Follow the manual for the reset operation or just unplug
    the power cord for 4 hours or overnight. That will automatically reset
    everything to the factory defualt settings.
    If the reset does not help and you still cannot get the channel to
    change, try using the manual controls on the front panel rather than
    the remote.
    If you still get no picture after the reset, try a vcr or dvd input to see if you can get it with external video input.
    When you say there is no picture, do you mean the screen is totally
    dark, or do you see some raster or flicker or anything coming or
    flashing on the screen? If the screen is totally dark and there is
    nothing on it (you may need to view it in a totally dark room to tell
    if it is really totally dark) then it means you have probalby lost the
    high voltage.
    If there is some evidence of light on the screen, it means the high
    voltage is okey and the set has lost its video; and maybe the tuner or
    front end electronics has all been damaged by the switching transients
    during the power problems.
    The moving it back and forth from the place u live the first time
    might have shook a connection back into place, if none of this works
    you might have to go back to the repair shop. There is very little an
    average homeowner can do to repair electronics.
    if Convergence amp ic bad then try
    http://home.earthlink.net/~oleg.filippov...
    http://cmpalmer.blogspot.com/2006/11/fix...
    http://www.hdtvoice.com/voice/showthread...
    sometimes horizontal output may have blown.
    in this case u will to replace the horizontal IC.
    link for user guide
    Main support number800-457-7777
    thank you
    good luck
3answers
Lines across screen
I think its an electronic interference problem
Toshiba tv 61a61 screen all red
jeffjo7,
Your unit is 10 years old and more than likely needs the drives adjusted on the blue and green guns. I have a tip at http://www.fixya.com/support/r6814105-adjust_screen_drive_crt_projection_tvs
which explains the process to adjust the screen drives for the best picture.
Thanks for using FixYa and for the great rating.
hardrocko
2answers
I have the Toshiba 61A61 TV. I am not sure what exactly happened, but when the TV was on, suddenly the picuter went black. I still receive the normal sound, but can't get any picture (totally black). I...
Check all connections?Unplug,replug the cable box about an hour later let it upgrade it software.The projection lamp has not been replaced in this tv the last 1 1/2 or 2 years?The tv been on and watches at lest 4 or 5 hours a day?Yes,than the projection lamp life is over.Require a new projection lamp.
1helpful
3answers
I believe the blue lamp in my 57H81 is going bad.
You need to replace convergence out chips in your Toshiba 57H81 tv by qualified tech because 3-D look picture in rear projection tv shows some thing wrong with convergence output chips.
Your tv model number shows it is rear projection tv that use 3 tubes to make color picture on front screen where as dlp tv use one lamp as back light source to present picture at front screen that is generated in light engine.
Stay on power light but no light or sound
No picture, no sound and all the fuses are ok, means there are no shorted components in the circuit, more than likely the tv is not generating horizontal drive to produce and feed hv to the crt and no b+ for the audio circuit. The tv is big enough to keep and repair if you are cosidering a repair estimated around 400dlls. I think the problem would be located in the deflection board.
52 inch Toshiba rear projection no picture has sound
You have bad solder connections in the deflection circuit. Call a good TV tech unless you know what you are doing. You could get an electrical shock from a charged capacitor.
1helpful
61A61 TV IS WILL ONLY PICK UP ONE CHANNEL #66 AND NOT CABLE INPUT
Cable companies are slowly but surely reducing the channels you can get without a digital box, which they will supply. You will need to cantact them and rent a HD cable box or converter from them that will work with your displays built-in tuner. However, if your display is HD compatible, then I would just asked your cable company for and non-DVR HD cabe box and connect it to your display with component cables....
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
