Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Wireless camera setup
My wireless 2.4g security camera scrambles my wireless internet connections. What do I do?
    Genius:
  • 3,587 Answers
Hmm...serve bacon with the scrambled Nets?..he..he
did you know that 2.4 Gig is the same frequency as your wireless net? get em away from each other. May need to shield one(yes..copper plates)..
try distance first though
check your computers warranty here 4 FREE
Posted on Mar 16, 2008
SOURCE:
How to use a lw 2410 2,4G wireless mouse with a laptop
Wireless you need to plug in the usb dongle that comes with it. Bluetooth you need to enable bluetooth on laptop and then pair the devices.
Dec 21, 2012 | Computers & Internet
Tip
Setting up Wireless on router and wireless security
For setting up any router you can follow the below simple steps
  1. Connect the router with a power cable and switch on the poser, reset the router with its reset button normally you can find the reset button on the rear side of the router for 30 seconds and then switch off and on the power
  2. After reset conenct the router to any laptop or desktop with a cable and also connect the router to the modem or the internet service provider cable
  3. after all connection lights will come on go to right hand side corner of the computer and check if the network connection is showing connected
  4. Once you are connected with a wired connection open a page of internet explorer and type in router addess normally it will be http://192.168.1.1 or http://192.168.0.1 and then type the username and password default usernames and passwords can be found in router manual.
  5. Once the router setup page is open you can confugure the router easily without the CD setup.
  6. The advantage is you do not have to run the setup CD and you can also do wirless settings for your wireless laptops or devices
  7. Go to the wirless settings page and you can select the wireless on and off or you can setup a wireless security to avoide your router with unauthorized acess
  8. I would recomend always keep the wireless network secured if you are using the router for a home or small office as there can be people who will be using your bandwidth for free without your permission
  9. one more tip i would like to give whenever any kind of setup is required on the router do it by a wired connection only and not thought a wireless pc or laptop as it can disconnect you from the router in between of your setup
  10. WEP is the kind of wireless security which is easy to setup and remember and most wireless cards of laptops and computers support it
All the best with your wireless router configuration and security setup
Regards
Vikram
on Dec 02, 2009 | Computers & Internet
I have a 7 Inch Capacitive Touchscreen Ultra-Thin Tablet PC with HDMI Camera. I am trying to connect to the internet. I have an N300 Router. I keep getting 'authentication problem'. Any sugge
Network Key (WEP, WPA, WPA2 Encryption key)To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
May 30, 2012 | Computers & Internet
How do I set up a security password
Here's a video on how I did it on my F9K1003V1.
Aug 09, 2011 | Belkin Basic Wireless Router
Wireless function on camera does not work. I foll...
SSID is case sensitive. Make sure you select the correct security settings. Wireless Mode has to be Infrastructure. If it is still not working try upgrading to the latest firmware version
May 20, 2010 | TRENDnet SecurView TV-IP121W Day/Night...
Laptop keeps asking for security key, when trying to connect wirelessly . i dont know security key
You need to ask whoever set up the wireless router what the security key is. Apparently, who ever setup the router encrypted the wireless network. Any computer wanting access to the wireless network must have the security key initially entered in for access. If it is your own router, you can access the router and change the security key your self in the wireless setup portion.
Feb 16, 2010 | NetGear WGR614 Wireless Router
New Modem with a router for wireless Laptop
Some routers have a kind of built in firewall. You need to let the router/modem that it is okay for it to let this information pass through it. Here are your instructions
Overview
Follow the steps in this chapter and use the Gateway’s web-based utility to configure the Gateway. This chapter
will describe each web page in the Utility and each page’s key functions. The utility can be accessed via your web
browser through use of a computer connected to the Gateway. For a basic network setup, most users only have to
use the following screens of the Utility:
• Setup. On the Setup screen, enter the settings provided by your ISP.
• Security. Click the Administration tab and then the Security tab. The Gateway’s default username and
password is admin. To secure the Gateway, change the Password from its default.
There are seven main tabs: Setup, Wireless, Security, Access Restrictions, Applications & Gaming, Administration,
and Status. Additional tabs will be available after you click one of the main tabs.
Setup
• Setup. Enter the Internet connection settings on this screen.
Wireless
• Basic Wireless Settings. You can choose your wireless network settings on this screen.
• Wireless Security. This screen allows you to choose your wireless security mode.
• Wireless Network Access. This screen displays your wireless network access list.
• Advanced Wireless Settings. On this screen you can access the advanced wireless features.
• WDS. The wireless distribution system feature is accessed on this screen.
Security
• Firewall. This screen contains filters and the Block WAN Requests feature. Filters block specific internal users
from accessing the Internet and block anonymous Internet requests.
• VPN Passthrough. To enable or disable IPSec and/or PPTP Passthrough, use this screen.
Jan 20, 2009 | Linksys Computers & Internet
No wifi connection
connect by cable long enough to complete the setup
type this address in your browser
http:\\192.168.0.1
which should start the routers webinterface you can navigate thru the Wireless settings ,s et channels etc
and copy them to the pc that you are trying to connect,
WEP - wireless encryption protocol - a method of scrambling transmitted data for security - both ends of the link have to have the same code key or they wont talk to each other
Apr 29, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
How do I secure my dlink wireless connection?
Type 192.168.0.1 (you can type the router address if you have changed) and enter on browser's addressbar. Router's interface will appear.
Click on SETUP and Click on the WIRELESS SETTINGS at left side. on the page you will see the option of WIRELESS SECURITY by drop down menu you can choose the Security mode that you wish. here is the link for the emulator
http://support.dlink.com/emulators/wbr1310_revB/wireless.htm
Please post your question if you need further assistance
Good Luck
Jan 19, 2008 | D-Link 802.11g Wireless Router WBR-1310...
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
46 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
