Connecting an LG TV to my PC
Hi guys, need some assistance please!
Just having some trouble connecting my LG 19LS4D tv to my PC. At the moment I've got my PS2 and freeview tv running from it.
I've also got my pc connected to it; when i turn on the pc, i get up to the screen with the windows xp black screen, but when it switches to my desktop, the screen goes blank and says 'no input'? If i connect my pc to my old monitor and then switch it on, it works fine and if i then take it out of the monitor and plug it into the LG TV, it works too? Any ideas why it would just stop showing the visual lead halfway through start up?
Many thanks!
Sunny
  • 2 more comments
  • sunny_sikha Mar 16, 2008
    well its connected to it now and is working fine?
    if i switch on the computer while it's connected to my old monitor and then switch the cable out of the monitor into the tv it works?
  • KennyDeeee May 28, 2008
    exactly same problem. All works OK with ORION LCD tv/monitor.Tried new graphics driver. If PC boot up on other monitor and then analogue lead moved to LG , it is possible to change resoloutions. Standby allows awake OK but power off results in no graphic output
    Ken.
  • mr 123 Jan 23, 2009
    I have the same problem i sorted it once but it is happening once more dose anyone know what i can do
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    does your laptop have the video output capacity to drive that LG?
Switch to any setting as long as it is only in 60hz and nothing above that the monitor cant handle it
Posted on Sep 11, 2008
    Genius:
  • 1,913 Answers
Dear sir
i think u have screen resolution pro.
change your system resolution to 800x600 .reso.then restart .
i think your problem is solved
Posted on Mar 18, 2008
HI guys my LG tv has optical output but my home theater has Arc output what do I need to make sync. Please help!
If the TV has an HDMI connection you might not need the optical connection. Plug a good quality HDMI connector into your TV and amp and it should pass the TV sound back to your amp in high quality.
Apr 13, 2018 | LG Audio Players & Recorders
Moved to Trinidad with my UK LG TV model number 19LS4D, I am having trouble tuning it to the local channels. Any suggestions please?
The system in the US is different from EU. You might need to get a converter for broadcast signal conversion.
Oct 28, 2013 | LG 32LG30 32 in. LCD HDTV
My LG Plasma TV Model 50PC1DRA displays the following message after powering it up and connecting to cable: "Invalid Format" All of our other in house TVs attached to the same cable are fully...
Hi
Thanks for using FixYa. Invalid format indicates issues with the PC Mode, if the signal is not out of range then check the input source.
Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 30, 2010 | Televison & Video
Switces itself on
known problem with these you need a tech to replace the mainboard
Nov 24, 2009 | Televison & Video
TV shows "No Signal" when hooked to cable. Cable has been tested with another TV and that TV works fine.
hi if you are connecting the cable box through HDMI then you may need to get the lg tech guy's to come out and reprograme the edid data in the HDMI sockets it's a common problem
Feb 25, 2009 | LG 32LG30 32 in. LCD HDTV
The tv code for model 19LS4D so i can use my sky remote rev 6
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0056
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Dec 23, 2008 | LG 19LG30 19 in. LCD HDTV
I am connecting a Technika 1031 to a LG 19LS4D using a good quality scart. I get sound but no picture. Connecting via the Y, Pb/Cb and Pr/Cr ports does nothing. Am I doing something wrong?
Make sure that the proper input is selected on the TV. Also, check to be sure that the correct output is activated on the DVD. I'm not familiar with the Technika brand so verify the output selection in the owner's manual.
If those selections are correct, try connecting to the standard AV input using the Red/White/Yel cable connection.
Dan
Mar 18, 2008 | Televison & Video
Connecting to a P.C
It it really has 11 pins I'm not sure but then my guess is that this is the service port connector which normally should have 9 pins. A vga connector has 15 pins and LG (as far as I know) uses standard 9 pin serial ports for service and plain old dvi or vga ports for connecting a computer.
Please visit Hardware Book for more info on connectors and cables.
Jan 15, 2008 | LG RZ-20LA70 20 in. LCD Television
Computers & Internet Logo
2,375 people viewed this question
Alun Cox
David Payne
David Payne
