Question about Jl Audio 500/1 Car Audio Amplifier
How should I wire my 3 subs to the 500/1 amp???????
How should I wire 3 "12 's to my amp. The subs are all wired together. So there is one speaker wire that supplies power to all 3 subs. Should I have the subs wired this way. Or is there a better way to wire my subs to optimize the power off the 500/1 amp?
  • shawnhop18 Mar 29, 2008
    * Pioneer TS Series 12" Subwoofer
    * Power Handling:
    o 400 Watts RMS
    o 1200 Watts Peak
    * Impedance: 4 ohms
    * IMPP with Aramid Fiber Cone
    * Dual Mass Magnet with Magnet Cover
    * Dual 2-ohm Voice Coil
    * Aramid fiber IMPP composite cone
    * Spring-Compression Binding Posts
    * 3-layer fiber woven radial surround
    * Aluminum voice coil bobbin
    * Integrated single-sided terminals
    * Frequency REsponse: 18 Hz - 500 Hz
    * Sensitivity: 89 dB
    Problem Solver:
  • 8 Answers
GO TO http://www.hifisoundconnection.com FOR A CORRECT ANSWER
Posted on Sep 01, 2012
* Power Handling:
o 400 Watts RMS
o 1200 Watts Peak
* Impedance: 4 ohms
Posted on Mar 29, 2008
First of all how many ohm's are each subwoofer rated at . Are the subwoofers dual voice coil or single voice coil. Once I know that I can help you. I think the JL amp is not recommended below a 2ohm load.
Posted on Mar 17, 2008
Wire 2 sub 4ohm
I am assuming these are subs, you didnt say, but that is my guess. do you want bass, or do you want to take it easy on your amp? do you have a terminal cup on your sub box, or just wires going into the box to the speakers? take it easy route: wire positive from amp to positive of one speaker, negative of amp to negative of the other speaker, with a jumper wire connecting the negative of the first speaker, to the positive of the second.
more bass route: run seperate positive and negative wires to each speaker, making sure to maintain proper polarity.
Oct 21, 2013 | Jl Audio 500/1 Car Audio Amplifier
What is the best way to wire two alpine SWR 1222D subs to a alpine PDX 1000 1
First off excellent choice on audio equipment, i guarantee you won't be disappointed. So your subs are dual coil 2 ohms. So wire each individual sub in series. If you don't know what this means i'll explain. On each sub there are 2 sets of wire terminals. Connect a wire from the one set's - to the other set's +. Do this on both subs and you will have the coils wired in series making each sub 4ohms. Now to hook the subs together you'll need to wire them in parallel. Now since you have your coils in series, on each sub you have one + terminal and one - terminal left. So run a wire from the + terminal remaining on each sub, and run them to your amp. Splice the ends of the two wires together and plug them into the + speaker output of the amp. Connect the two negatives in the same way and plug them into the - port on the amp. You will now have your amp running at its desired 2ohms. When wiring this disconnect the fuse on your amp power wire to avoid short problems. And if you get confused at all, and aren't sure what to do, ask again don't guess, if its done wrong you could severely damage your equipment. Hope this helped, enjoy the bass...
Sep 16, 2009 | Alpine Car Audio & Video
Need wireing diagram for hooking up two as12sq 12-inch square 2
you can run each sub at either 4ohms or 1ohm which means that two of them will run at either 2ohms or .5ohms....be careful how you wire them because most amps cannot handle .5ohms very well and might blow.....to wire them for 2ohms you will need to wire each sub the following way. they have two voice coils make a jumper wire connecting the negative on one coil to the positive on the other coil. what you are left with is a coil with an open positive and the other coil has an open negative. when both subs are wired like this connect the two positive terminals together (1 from each sub) and the two negative terminals together (1 from each sub) now the subs should be wired together at a 2ohm load. run the two positive wires into another combined wire which will run to the positive speaker terminal on the amp. do the same for the negatives
Apr 17, 2009 | Hifonics AS12SQ Car Speaker
Best results
huge shared common space slot loaded box (size depends on sub 10", 12" 15" you need to clarify that please) the amp specs on earthquakes site say the phd5000 is rated at a max output of 5k watts at 1 ohm 3k watts at 2 ohm so, with 3 dvc 2 ohm subs you only have 3 options of which only 2 will be a usable solution:
1. 3- 2ohm dvc series at sub parralel at amp = about 1.33 ohms at the amplifier this is the best option to get the most power to the subs as each sub will produce a 4 ohm load then wire each one to the amp the amp sees 3 4 ohm parralel loads which = 1.33 ohm so based on the amp specs you would be close to 1200 watts per sub.
2. 3- 2ohm dvc wired in series at sub and all 3 subs series wired together very difficult to wireand will give you a 12 ohm load which is next to no power at all (not a viable solution)
3. 2- 2ohm dvc parralel wired to each other and then at amp the amp sees a 1 ohm load and makes 5k watts max but you can only (REREAD THAT LINE! ONLY USE 2 SUBS IN THIS WAY) WHICH GIVES THE MOST POWER BUT ONLY USES 2 SUBS
Jul 09, 2008 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wiring the coils together
For each sub, tie the DVCs in parallel ("+"s together, then "-"s together). This will make the subs look like 2 ohms to the amp. Then, put one sub on each channel of the amp. That will put about 280W rms onto each sub, the max for the amp.
Mar 15, 2008 | Power Acoustik Power-Acoustik FUBAR-12W...
Confused about system
If what you're telling me is correct you're trying to drive a stereo sub -woofer with a mono amplifier. If so, that could be a bad situation for the amp, if the voice coils are not wired together correctly. Before we go too far, I have some questions I need answered.
1. Is the MA unit an M1889i?
2. Do you have the 4 terminals of sub-woofer tied together. For example the 2 positive terminals are tied together & the 2 negative terminals are tied together?
3.How do you supply 12VDC to the amp?
While I'm waiting to hear back from you, I'll try to draw a schematic (wiring diagram) of the way it should be wired for your particular setup that I'll send to you.
Mar 06, 2008 | MA Audio M1889I Car Audio Amplifier
Jl Audio 500/1 Car Audio Amplifier Logo
201 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
hoyzee1
Morne Olivier
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
