Question about Epson Stylus CX6600 All-In-One InkJet Printer
Cx6600 printer problem
Printer only prints blank pages
  • 14 more comments
  • mcgrt Apr 05, 2008
    Only printing blank pages. After installation of new ink cartridges. Tried Cleaning print heads many times. Tried re loading to let the printer charge cartridges. Now it is telling me my black ink is low... I can't be because it won't print.
  • njdave35 Apr 07, 2008
    I am having the same problem.....my cx6600 epson stylus is printing just blank pages. It has full ink and I cleaned the print head, head cleaning squeegie, etc......can someone help me please.....its still new...hardly used. no errors and it does everything but print....full ink and blank pages are printed please email me.... thanks.
  • skor May 03, 2008
    Changed black ink cartridge. Paper runs through but won't print on any of the four colors. I've tried head cleaning, alignment, changing ink cartridges, turning printer off, resetting, nothing works. It worked fine until I changed the ink cartridges. It has not been sitting unused for more than 24 hrs.
  • Anonymous May 04, 2008
    Hello, I am having the same problem, I tried all the general maintenance techniques such as cleaning, realignment, etc. I have changed my cartrdges all 4, but the black is decreasing rapidly, but nothing is printing on the paper. the other inks are decreasing at a slow rate. This is very fustrating because the printer is not very old. I was informed by an employee at STAPLES that it may be clogged. What can I do to unclogged it? Please, need help urgently. Thank you.
    BGJ
  • Anonymous May 26, 2008
    My cx6600 epson printer will not print in any color including black. The levels of ink are slowly disappearing. It is not copy either. I put in all new color and black cartridges. HELP!!!
    BC
  • Anonymous May 28, 2008
    Printer queue says "Paused; default" When I click resume printing nothing prints. Same problem as others have reported. The printer moves the paper through but there is nothing on it, although it will scan. I've done head cleaning and nozzle check, but it has quit printing. I even downloaded another driver.
    I called Apple Care and they believe it is an Epson problem, because we've checked everything else it could be. Nothing is wrong with the computer.
  • Anonymous Jun 19, 2008
    The printer printed ok then after a few hours without use the printer took the paper through, sometimes comes out blank other times prints a few words on the left hand side of the paper, but not black mostly light blue.
    Any help would be appreciated.
  • Anonymous Jun 24, 2008
    my printer has decided not to print in any format all i have had no problems up until recently i needed to copy some docuements but no joy i checked ink levels nozzle check head clean head alignment but still i got no print please can you help me.
  • Anonymous Jul 03, 2008
    Just changed black ink - installed high capacity cartridge. Now mostly blank pages, occasional bit of something. Black ink level going down. Is it evaporating? Or is this a desperate attempt to get Epson margins up? I have reinstalled the software (and did it with the update version of the printer drivers). No change in result. Have also removed and reinstalled the new and expensive cartridge. No change. WHAT'S GOING ON??????
  • catos Sep 04, 2008
    my initial problem started maybe 2 years ago and the printer started not printing with black ink. I did many nozzle checks and print head cleanings and eventually can not even print in color. I replaced all ink cartridges twice and still nothing. Now all I get are blank pages with nozzle checks and everything else. The scanner works and I hate to replace the printer if it is an easy fix. The copier also was working but now no longer works. Epson help desk was useless. Any help would be appreciated.
  • Anonymous Sep 05, 2008
    It won't print anything. I clean it out and did head cleanings and now I can get the yellow to print. It doesn't help me much. Any ideas would be great.
  • Anonymous Sep 21, 2008
    I tried to refill the black cartridge using ink different ink. It causes that my printer stop printing. At the beginning the print start coming out with lines like if I was printing using a notebook paper. However I changed the cartridges and it din't work but the cartridges ran out of ink almost immediately now it doesn't print at all. The paper comes out blank.
  • Anonymous Sep 27, 2008
    My problem started with text having lines in them about every inch or so. I did nozzle check and other fixes still same problem. I can print text using the other colors with no problems. Now, no black ink shows up on the page at all, in pictures or in text and yet my ink black ink cartridge level is going down??
  • Anonymous Oct 09, 2008
    All I did was replace an empty black ink cart and now none of them print -- self test gives a faint, gappy black with some yellow printout. Nozzle check, head clean, nothing helps.
  • copywizrick Nov 10, 2008
    Move printhead to cartridge changing position. Unplug printer.
    Move the white plastic cleaning pad to the right and make sure the hose is connected to the pump. This hose primes/pump the ink into the print head during cleaning and printing . Also, the hose goes to an absorbtion pad on the bottom and if it forms a blockage there, it wont prime the printhead.
    Use a syringe (without needle) to force water through the hose and blow it clear. Reattach hose to pump under white plastic cleaning pad.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    try a test page, without it on computer..
My Epson Stylus CX6600 Printer is printing blank pages. All inks finished about the same time -within days. Once I changed the last one (black), my next 3-4 print jobs were only showing yellow and the printing after that blank.
Posted on Nov 24, 2008
    Scholar:
  • 94 Answers
It sounds that the print head nozzle is clogged. Since head cleaning and replacing ink cartridge wont help. The best solution is to take the unit to service center however if you think buying new printer is more cost effective - I suggest go for new printer. If ever your printer still under warranty. I will call epson and ask for replacement.
Posted on Sep 30, 2008
  • 61 Answers
If you left your printer for two weeks or more without using, the print heads may be stuffiness. In this case (aparently yours cases) you must take your printer to a authorized service, they will can clean (with a proper fluid) or replace the ink heads, if cleaning is not possible.
Posted on May 02, 2008
6ya staff
SOURCE:
Hello my Epson Stylus CX6600 is printing out blank pages, ran nozzle check and Head cleaning, also head allignment, still print blank pages, need help please
if the printers been sitting for some time, the printhead has dried up "not good" printheads generally retail around $100, you can try soaking the bottom of the printhead in metho which may fix some colors but you would be pretty lucky to get all them to work.
Nov 26, 2010 | Epson Stylus CX6600 All-In-One InkJet...
How to change ink cartridges on Epson Stylus CX6600
i just buy new cartridge ink for my epson stylus 4100 and when i print out didnt print its only a blank page what should i do
Dec 04, 2009 | Epson Stylus CX6600 All-In-One InkJet...
My computer was printing fine, but now it prints blank pages on every website I try to print from. All I get is "Page 1 of 1" on the top and the website address on the bottom. Same with the print preview....
You must try to print a test page. If it still prints black pages. Maybe it has changed its configuration. You must configure it first to your desired output.
May 18, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Not printing
try to check if the type are not remove in the cartridge then check if the printer head cable of the print head is ok.. ^^ if not you need to tighten it up.. or maybe the pritner head cable is damaged
Feb 06, 2009 | Epson Stylus CX6600 All-In-One InkJet...
Printer won't print
plzzzzz check whether the ink catridges are compatible to your printer(chk the model number of your ink catridges)
Dec 15, 2008 | Epson Stylus CX6600 All-In-One InkJet...
My cx6600 has new ink cartridges and acts like it is printing but the pages come out blank!
Try taking a new cartridge out and shaking it ( with your finger over the hole that the ink comes out) and then put it back in.  Also make sure that the tape that is over some cartridges' printing area has been removed.
Dec 09, 2008 | Epson Stylus CX6600 All-In-One InkJet...
Printing Blank Pages!
I just got the same problem with real Epson ink. There were some solutions posted under "not printing" that you might try. I haven't yet, but I am going to reload the printer driver tonight.
Dec 18, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Printing blank pages
Check out the online guide and trouble shooting for a solution
The manuals,online guide and trouble shooting sections could help you resolve your problem. Contact support has a chat facility on some pages that may help.
Click this Link
Under Select a Product Range
Choose Stylus CX6600 on the webpage
Under Select an OS
Choose the operating system1.gif on the machine where you will install the printer on the webpage
Click Confirm Selection
The manuals and documentation link will allow you to download manuals that were on your CD ROM
you may want to bookmark the online guide, if present, to help with future problems -- that probably was not on the CD
Click the back button on the browser
click the Drivers and Software Link
This allows you to download software files that were probably on your installation CD
Click the back button on the browser again
Trouble Shooting and Contact Support could be an interesting link in the future too when and if you have problems.
I hope this helps
Nov 30, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson Stylus CX6600 All-In-One InkJet Printer Logo
868 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
