Computer starts but doesn't boot
Computer turns on but will not boot. All I get is black screen on monitor. I hear all fans etc. running. Any idea what it may be and how much it would cost to fix it, or even if its worth fixing?
  • 3 more comments
  • Abhi18 May 20, 2008
    my pc starts but does not boot
    only a blank screen is displayed on the monitor
    i have checked all the internalo and external power connections
    can you please offer me some solutions?
  • byteme813266 May 02, 2009
    my computer starts and loads but then when its supposed to go to the page with all the users, it turns into a blank page with just a mouse showing that i can move, but do nothing else with. help? by the way its a SVA monitor with Dell Microsoft xp cpu too
  • Anonymous May 03, 2009
    my computer seems to have a similar problem, ill turn it on and than the moniter will just remain blank, and i dont even hear it trying to start up, if anyone has any ideas please let me know
  • Kenneth  Keaton
    Kenneth Keaton May 11, 2010
    lets not get too hasty... It can also be a bad memory module(s). It could take some time to find out exactly whats wrong, but if you have time, and another PC to test some parts in it will help. First things first,.. with the computer off,.. pull out and re-seat the memory and try to reboot. If that doesn't work, and you have access to a known working memory module that is compatible ( same type and speed preferably ) remove the modules installed, put in the spare and try and boot. If no boot,.. then you know its probably not memory ( though I still recommend trying the modules in another PC and running memtest+ to test them ( a no-cost program download able from the net ). My main question,.. are you comfortable with opening your computer and getting your hands dirty... I'll help you as much as I can just let me know.
  • Patrick Michaels
    Patrick Michaels May 11, 2010
    well..you get nada? that means your motherboard is shot..those are not too much(100 or so) and powersupply(another 25)..
    you'll need to know what m/b you have, does this computer have a name on it?
    Champion:
  • 209 Answers
Try to uninstall the cord of your monitor going to the cpu this might be loose. if you are using an expansion video card try to remove this and clean this with a pencil eraser. you forgot to specify if you are hearing some beeps upon power on. if there is no beep then the problem is just the connection from your monitor to this videocard(cpu) just try to uninstall then reconnect
Posted on Mar 17, 2008
I've got the same problem, but when it happened the first time, my parents let me open the computer and... well, do whatever I want with it. anyways, I kept many parts intact, and now I tried to make it back together(with a power supply without a cooler)
first time it worked, but after I downloaded and mounted slax(the new os that I thought would be run better than win xp), it just didn't wokr. I took the bios ic, processor, ram and disconnected the hard disk, then put them back together, and nothing. it just spins the cooler and light the leds. since it's a amd k6 II (similar to pentium 2), I can't test the parts on my "good".
Posted on May 03, 2008
No beeps toshiba x200
IF neither your external Monitor or Laptop LCD screen are inactive, this generally relates to the Video Section on the mainboard a being compromised. The best solution is a bench test done by a technical professional to locate the excact cause.
Jan 07, 2014 | Toshiba Satellite X200-AA3 Notebook
HP Pavilion a 1245c won't boot black screen no beeps constant running fan
sound to me like a video problem. no beep codes, you hear the fan going so it must be posting. could you try with other monitor and or cable? is there power to monitor? reseat cable at both ends( monitor+ pc)
Nov 02, 2012 | HP Pavilion a1720n PC Desktop
Dell Latitude D830 running Windows 7. Also running laptop screen plus additional monitor. I was watching a visor from cnbc.com when the addt'l monitor went blank and the laptop screen went a broken...
Hallo there
I hope you have got your screen beack, if not try to restart your computer in safe mode.
The restarting can be done in the following way:
1. Click START, click TURN OFF COMPUTER, and then click RESTART
2. While the computer is starting, press and hold down the F8 key until the Startup Menu appears
3 Use the UP ARROW and DOWN ARROW to select Safe Mode, press ENTER.
Now to the display settings
1 Open Display Properties in Control Panel
2 Click the Settings tab
3 If for some reason you are not in safe mode go through following:
In Colour quality, clock to alower settiing
Move Screen Resolution slider to the left if you want to reducethe size of the desktop
To Refresh frequency click Advanced and check the Adapter and Monitor.
4 After you have made your changes click OK
restart the computer if you are told to do so. But do not do it in safe mode..
Good luck
Kobrun
Feb 29, 2012 | Dell Computers & Internet
After powering on monitor says no sync
I've almost the same problem. When the system turns on the monitor doesn't sync. After a variable trials with down/up the sync is enabled and the computer starts.A very clear event occurs : when the monitor can''t sync ( and system doesn't boot)you can hear very clear a high fan rotation. When I look/hear in the system the Isuspect the cpu fan. The system boots ( monitor syncs) when the fan rotationgoes from high to low. So the system hangs on an internal check on the rotation speed of the cpu fan.I've googled a lot , but until now doesn't find an answer . Possibilties which I think about : replace cpu fan , clean cpu fun ( but it looks clean).I cannot measure the fan rotation speed when the system is hanging. At normal rotation all info can retrieved witth the program cpu-z.Did you already have a solution ?
Dec 07, 2011 | Compaq Presario 5000 PC Desktop
My averatec will not turn on
Open it again and make sure you connect all the devices and such ..It seam to be like a clear case of a disconnected cable ..If the system boot up ..and seam to run ..try to see if the vga secondary monitor brings anything to a screen ..if it does it means you messed up with the monitor connections ..cause you changed the hard disk ..you don't have a operation system to boot into and try to make an idea..but its a start ..
Other things to check is the fan connections and cables ..
If the screen is totally blank I think is like I said just a bad connection to the monitor or a damaged cable in the process of opening it .In any other case you would have at least a warning on screen even without hard disk it should boot to BIOS ..
Dec 07, 2011 | Averatec Computers & Internet
Black Screen Compaq Presario
Do you see the BIOS splash screen or anything?
Try booting into safe mode by pressing F* as soon as you power on the computer. If the monitor works, then it is a bad driver. Roll back to a previous restore point, boot to last known good coonfiguration. Last Known good configuration is available from the same as the safe mode screen.
If this is helpful, please comment and rate. Have any other questions, please let me know.
Oz
Feb 12, 2010 | HP Compaq Presario SR2010NX PC Desktop
Gateway FPD1760TFT LCD monitor
Problem
1. turn on computer
2. monitor receives signal, it looks like its working
3. it goes through some steps and then the monitor says "no signal" and kind of stays in limbo with fans running, etc.
Solution
One possibility is that computer is looking for drivers for you video card. It could be hung up looking in the wrong places. Remove all peripheral hard drives and memory sticks. Try again.
Jan 12, 2009 | Gateway FPD1760 17" LCD Monitor
Monitor black screen prob
disconnect the monitor from the back of the system and see if u see the colour scheme or anything if u do see something that means monitor fine ... problem with system
Sep 19, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Monitor goes to sleep and computer will not boot
If your monitor goes to sleep, how do you know it got to window xp screen ?
Sound like your stuck in a loop (bad boot sector). You might have to reinstall windows again.
May 06, 2008 | Computers & Internet
Black screen
Does your computer appear to be booting?
Do you head any startup noises, or the startup sounds you hear when Windows loads?
In no, have your computer checked.
If yes, make sure your cables are all snug. Other than that, it depends on how into "fixing it yourself" you are.
Give this a try:
Open the unit and check to see if any of the capacitors in the power supply or other boards look domed or vented on the top.
Replace any capacitors accordingly. Use the same value capacitors. Most often, 1000uF 16V or 25V, 470uF at 16 or 25V, 220uF at 16V or 25V.
If this doesn’t solve the problem, try checking the surface-mount transistors on the inverter board that run the lights. Some times these transistors go bad. Check the area for any cracked or overheated ceramic or mylar capacitors.
You'll need a soldering iron, solder, solder ****** and some idea of how soldering and desoldering work.
Mar 27, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
1,801 people viewed this question
Alun Cox
David Payne
David Payne
