Question about Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
Fisher & paykal soft touch dishwasher leakage
We have leakage out of both bottom sides of our dishwasher it. What could be the problem.?
    President:
  • Fisher and P... Master
  • 2,651 Answers
Could be a multitude of issues causing water to leak, from misloading dishwasher to a faulty water valve. theres a pretty good trouble shooter/ tech sheet located on inside back wall behind the lower drawer
Posted on Mar 16, 2008
E15 showing on Bosch dishwasher. How to clear?
The overflow switch has been activated.
It means that its a internal leakage.
Unscrew the side panels or frontpanel under the door and dry out the water with a towel and test the machine.
Check for leakage.
Feb 07, 2016 | Bosch Dishwashers
ESL63010 Electolux - Dishwasher keeps beeping in a cycle of 3 beeps and 3 flashes of the 'end' light (flood warning). Waterleaks from the waste connection to D/W. How do I change the hose? Thanks.
You have inlet hose and drain hose so it is possible to water leakage on both. The easiest access to both hose is from bottom of dishwasher.
  • Remove the bottom panel
  • Remove the inner filters
  • Remove any residual water from the sump by
    suction, so that it does not flow into the tub and the
    pressure switch tubes, then lay the appliance on its
  • Unscrew and remove the regulation screw from the
    rear foot (built-in versions only).
  • Remove the screws which secure the bottom panel
    to the base (three screws)
  • Release the built-in retaining elements placed on
    the right and rear side: and remove the bottom
    panel by sliding to the right.
  • You are able now to access any bottom parts
Dado
Oct 06, 2015 | Dishwashers
How to fix anti flood error on F60860
Error "i30" means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
When we talk about AEG dishwasher, drain pump works even the power is turned off (must be connected to the wall outlet, otherwise anti-flooding system will not work).
Remedy: you should first remove the water from the bottom of the dishwasher and determine leakage.
If you work around the dishwasher, you always take care that appliance must be disconnected from the power supply.
Dado
Sep 28, 2014 | AEG 24 in. Favorit 60870M Free-standing...
The anti-flood system has been triggered on ELECTROLUX ESF 656 how can I fix it?
The anti-flood system has been triggered means that water remains in base because leakage or overflow. In this case, in order to prevent flooding, drain pump running continuously.
Dado
Jul 22, 2014 | Electrolux Dishwashers
Heavy light flashing
Heavy Light flashing indicates leakage error.
The leakage sensor on the bottom cover of the unit is detecting water in the bottom of the dishwasher. Possible parts that could be the issue are as follows: Hose Connections, sump and tub assembly, drain pump or just simply the main PCB.
tip the unit in its back and remove the bottom cover. disconnect the leakage sensor and inspect the inside of the unit carefully for ANY water leaks. Most of the time its a mouse chewing holes in the tubing for water. Otherwise check carefully and you will see the leak.
Mar 23, 2014 | Samsung DW80F600 24" Black Built-In...
Fisher and paykal DD. Top drawer stuck on Eco and fast wash. Buttons not responding to touch.
If this is part of warranty repair then the technician should be asked to come back and fix. Try to turn off mains power and then use a clean damp cloth and run on the program selection panel on top of drawer lid. But most likely some dirt on the underside of the panel. Need to take controller out and clean it.
Feb 28, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher Paykal 602 dishwasher - top drawer won't power on
Most likely the thermal fuse (inside heater assembly) is blown.
Not easy to repair. Need to replace the whole heater at the base of drawer.
Mar 28, 2013 | Fisher and Paykel Dishwashers
How to reset a fisher paykal
THere is no specific instruction for reset of the dishdrawer.
Once you turn the mains power off and back on there is not much you can do. The problems using occur if there is a faulty sensor which tells the diswasher controller not to proceed. You will need to a bit more specific on the type of problem you are having so that the right solution can be proposed.
Jan 28, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Leaking water on the right hand side
Does it seem to be coming from the door it self or from underneath the unit?
If it's coming from the door, check the seal or maybe replace it. It's easy enough and cheap.
(disconnect power before proceeding to the next step)
If it's coming from underneath the unit, first start a cycle to drain it then stop it. Pull the unit out and flip it to its side(have a couple towels ready), then remove the bottom cover and check hoses connects or any signs of leakage.
Feb 23, 2011 | LG 24 in. LDF7810 Built-in Dishwasher
Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher Logo
183 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
