Question about GE JVM1440 Microwave Oven
Surface Light and Vent Fan Not Working
In REGARDS TO THIS SUGGESTION:
You can fix it without the aid of a repairman. Simply unplug the microwave and remove the outer casing. There should be a few screws around the bottom edge and back panel. Once you have the unit open, look for where the power cord comes in. There should be a circuit board with a fuse mounted to it. This is your input line filter. The fuse should be a 20 amp appliance fuse that you can pick up at any hardware store (Lowe's and Home Depot both carry them). DO NOT op test with the outer casing removed. Potentials of about 14,000 volts are present in the high voltage network of a microwave oven. Close the unit up BEFORE you power it back up. Let me know if this helps.
TRIED THIS ON MY UNIT - SAME DESCRIPTION ON PROBLEM - Microwave surface light and vent fan won't work after trying to replace light bulb. Hate to have to call repairman when cost of repair could be half the price of unit. I replaced the only fuse I could find - was in front / top of unit.
GE web site only shows one fuse to replace so I assumed this was the one. No luck - any chance there is another fuse in back. This unit is mounted and difficult to get to anything else. Prior to removing I would like to verify another fuse?
  • blakeh Mar 18, 2008
    Model # JVM1440. Checked with GE wiring diagram - only saw one fuse. Will have to look at back like the other suggestion you made on similar model. I was changing the bulb and it broke off while unscrewing. Couldn't remember whether I did while plugged in or not?
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    You can check geappliances.com for your model microwave to see if they have any documentation. Look under "Use and Care Manuals" in the Search Window and type in your FULL model number. Also, there's normally a wiring diagram located behind the front panel or vent grill somwhere that can assist you. In my experience with microwave ovens, there's usually an input line fuse and a thermal cut-out located on or near the magnetron, and an additonal thermal cut-out (or thermostat) located somewhere above the the oven cavity. Any of these components could potentially cause the same symptoms depending on how the oven is wired. Unfortunately, you will probably have to unmounted the oven to get to any of the internal components. Did you short something out when you replaced the bulb? (i.e., the socket wires may have twisted together, or shorted against the chassis). Just wondering what may have caused the problem you are having...
  • GE Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
If your fuse is out, the oven will be totally dead.
Not sure what country the poster was from who mentioned that microwaves have or develop 14,000 volts inside...
Here is the US, microwaves only develop about 4,000V DC, not 14,000. Still plenty of voltage and current to be instantly lethal.
That's why I always refer folks to our critical safety information.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 31, 2008
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: JVM1460 surface light problem
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Feel free to contact me directly for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 02, 2008
Microwave off but light and fan stay on. Open door turns fan off but light stays on.
Try a reset, unplugging for 10 minutes and plug back in.
If this does not fix it, it has a bad wire, switch or circuit board and is not worth fixing unless you know a good,cheap repairman.
press the helpful button
Jan 13, 2016 | Microwave Ovens
Mmv5165bas vent fan will not stop running
Check to see if there's a relay providing power to the fan. If there is, the contacts might be sticking in the closed position. Assuming that this is an over-the-range unit, disconnecting the vent fan completely might not be a good idea as heat/steam from foods cooking on the range would more likely damage the microwave.
Apr 29, 2014 | Microwave Ovens
GE Spacemaker XL1800 JVM1850CH01 vent fan won't turn on
Unplug for about 5 minutes and allow to reset. If the problem persist, you might want to try replacing the control panel (the one that have all the numbers and timers). Good Luck!
Jan 13, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Ge jvm1650sh01 surface light doesnt work/ vent
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
This can often also affect the exhaust fan, cooling fan, turntable, and/or inside light operation, too.
Details of our service are at our Web site, along with a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly with your brand, full model number and symptoms.
William E. Miller
prototech@usa.net
May 06, 2010 | GE JVM1650 1000 Watts Microwave Oven
GE Microwave oven vent fan not working
You are correct the fan motor is either stuck or needs replaced.
There is no way to do this without removing the entire microwave. In case your not familiar with how microwaves work, there is a capacitor that is very large inside and can hold a charge even after it is unplugged for up to 24 hours, please take action to prevent getting shocked.
Sep 11, 2009 | GE JVM1750SMSS Microwave Oven
I replaced the light bulbs but they still do not come on and the vent fan will not come on either?
the fan and the surface lights are run through the control via the touch pad. if you tried to replace the bulbs without unplugging the unit 1st you probably shorted the board. this can be checked by lowering the touch control panel by first removing the vent above it to access the panel screw. at this point you can observe the control for burn marks
May 17, 2009 | Hotpoint RVM1325WW Microwave Oven
GE spacemaker microwave model #JVM1650SH
Allways unplug when your working inside a microwave, you will most likely have to replace the bulb again and also the fan, or anything else that is damaged, you will need to inspect the microwave for broken parts.
Il get you a few links to repair parts.
Sep 27, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Surface Light & Vent Fan Won't Work
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide for $39.95 postpaid.
Mar 17, 2008 | GE JVM1440 Microwave Oven
GE JVM1440 Spacesaver Microwave
Aug 11, 2007 | GE JVM1440 Microwave Oven
GE JVM1440 Microwave Oven Logo
128 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
