Question about Microwave Ovens
GE Microwave JES1334WD Code -P3-
GE Microwave JES1334WD started showing a code -P3- after use this morning. Unplugged for 10 minutes then plugged in. All lights on panel came on then it beeped loudly several times and showed code -P3- again. Owner's manual does not show any codes. The door is firmly closed. The 3-prong plug is in a 3-hole receptacle; no 3-prong to 2-prong adapter is being used. When the panel first lights up there is a CODE on the top line of items. How do you get into the codes? What does a -P3- mean? Thanks for your help. BJ
  • bjg512 Mar 18, 2008
    You're correct - it's a -F3- code. You're comments are very detailed and I appreciate you're taking the time to try to help with this problem. I've tried other electrical plugs in various rooms; same results.
    What causes a 'shorted keypad'? There were two ceiling fans running and 2 clocks plugged in - even the toaster oven and computer were unplugged at the time this happened. No lights or timers were being used.
    Thanks. BJ
    New Friend:
Salut je ve enter a la programme de inspeak
Posted on Jan 23, 2010
  • Microwave Ovens Master
  • 9,174 Answers
Are you sure it's not F3? That would be a shorted keypad ("membrane panel").
That's usually not too big a job for a DIYer, but if you'd like, we can do that for $39.95 plus parts.
If you or someone you know decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
One good test is (with power unplugged) to unplug the keypad, then plug the oven back in and see if the error code shows up.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a very helpful "mini-manual" hidden inside the unit behind the control panel. It's very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 16, 2008
  • William Miller
    William Miller Mar 16, 2008
    P3 may be a defect in the temperature sensor, and this would only apply to a model with convection cooking, which I believe model JES1334 does not have. If I'm wrong, please reply back.
SOURCE:
Has a code F3.
f3 error code is for bad panel control and your panel control needs to be replace
Feb 01, 2014 | GE Advantium 120 Convection/Microwave Oven
My GE Microwave JES1344SK is showing the code -F3- on the digital screen and it beep three times every 30 second, the microwave won't start and any of the fuctions is working I need some help on t
An F3 code means that the touch pad has a short. The touch pad needs to be replaced. If you purchased the microwave new, get your receipt and the unit serial number and contact GE for the repair (1-800-GE-CARES). See http://repair.geappliances.com/ to find a repair center near you. There is a one-year parts and labor warranty on this part. You will need to get the unit to the GE Repair center at your own expense. (I'm assuming that the unit wasn't shorted by a lightning strike or other disaster.)
I hope this helps.
Jan 02, 2012 | GE JES1344SK Microwave Oven
Spacesaver microwave F3
Unplug the unit for 1 minute to clear the ECU.
re-plug, and re-try.
Thanks
Oct 25, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave/convection oven (a GE unit model JES1290SK) started beeping every few seconds and displaying F6 on the control panel. I unplugged it and waited several minutes and when plugged in it displays...
The technical sheets in my files do not list F6 on the error code chart for GE microwaves.
Generally, these are the error codes possible on GE microwaves:
F1 open thermal sensor (convection models)
F2 shorted thermal sensor (convection models)
F3 key panel shorted for more than 60 seconds
F4 open humidity sensor
F5 shorted humidity sensor
There should be a "mini-manual" (technical sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Jan 15, 2011 | GE JES1290 Convection/Microwave Oven
GE countertop microwave shows "F3" on display, won't work
F3 on a GE means you have a shorted membrane keypad.
There are two ways to fix this model, either replace the membrane keypad which is a lot of work (handy guide with pictures) or to replace the complete controller.
It's probably not going to be economical even to repair it yourself if you or a friend want to. It depends on the model:
JES1334WD001
JES1334WD01
JES1334WD02
JES1334WD03
JES1334WD04
I looked up parts prices for the -02 verison.
ref # 38 part number WB27X10554 membrane keypad $69.71 here (compared to $112.50 direct from GE!)
ref # 42 part number WB07X11076 complete controller assembly $131.01 here (compared to $196.25 direct from GE!)
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
Jun 02, 2010 | GE Microwave Ovens
Our GE Spacemaker XL 1800 microwave's controls are locked
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Jan 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool Microwave Hood Combination MH3184XPS-0 (October 2004), for no reason at all, this morning keeps beeping and running the power setting down from 10 to 1, and just keeps doing it in rapid sequence....
Ours just started doing this exact same thing this past Friday - 12/11/09. What's going on? The cook power just starts beeping all by itself and going from 10 down to 1 over and over again. It may stop momentarily, but then starts again within a minute or so - it's constant until we unplug it. We plug it back in and within a few minutes it starts doing it again. What gives?
Dec 08, 2009 | Whirlpool MH3184XP Microwave Oven
After an electric storm our microwave started beeping..we unplugged and turned off the electricity, but it still persists..is there a fuse or something that needs replacing?
It may need a good reset - by being unplugged for a few minutes then plugged back in.
Otherwise, to allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, your symptoms, as well as the answers to these questions:
- Is the display normal?
- Is there any error code on the display?
- Does the oven respond to a key press?
- Does the oven work otherwise?
Nov 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Beeping and P3 shows
I would assume that trouble code is F3?
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
If the oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
William E. Miller
[email protected]
Dec 27, 2008 | GE JVM1440 Microwave Oven
Microwave Ovens Logo
581 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
