Question about Kitchen Ranges
Saeco Primea RIng - Cycle interrupted - only a few drops come out
We got a new Saeco Primea Ring. it worked fine for two days but now, when I select any coffee ( e.g. expresso), the machine starts brewing, then it displays 'cycle interrupted'; then 'boiler filling, press OK'; and then when i press OK a few drips are released and thats it. in the manual there is no mention of 'cycle interrupted'.
Thanks
  • Anonymous Sep 22, 2008
    SAme proble. Pleasee help
  • Anonymous Mar 20, 2009
    I have the same problem. An electrisian told me that the voltage needed to run the machine is too high.
    Maybe we need to upgrade our outlets.
    New Friend:
Have the same problem. spent a fortune and replaced nearly everything inside via 3 different repairers. called a recommended repairer in Qld and they refuse to work on this model and to get rid of it. Nothing seems to fix it. works for one day on weak setting then same again. waste of money. have you found a solution that works? will be setting fire in the backyard to mine and posting on facebook to get point across to Saeco in coming weeks. good luck with yours! cheers.
Posted on Apr 09, 2015
    New Friend:
Please, Clean brew unit with only hot water not cold water and set the rinse cycle everytime machine power " On".
Posted on Aug 07, 2013
Hi
Have you found a solution yet?....we have the exact same problem....
Posted on Jun 24, 2008
  • Yasemine J. Jul 09, 2012
    I have the same problem. Have you fixed and solve your problem?
  • Daeyoung Kim Aug 07, 2013
    Somebody said the solution is clean brew unit with hot water and set the rinse cycle everytime power "on".
Hi, I have a Saeco Primea Touch Plus, in the display it says error 5. What ca I do? Regards, staffan
I had that error too, the very first day after i received my Saeco Primea Cappuccino Touch Plus from Germany. The curiosity is that the machine was able to prepare a cuple of cups and suddently died with 5 in screen. Going to the service, they said that error 5 is about a lack of pression in pipes, probably due to the unprotected transport to Romania. I don't know if they fixed alsi some jonctions, but i had to pay for few rings. Everything took a day in service, but now is working fine. Hope it was usefull and my english enough inteligible.
Apr 17, 2011 | Saeco Primea Cappuccino Touch Plus Coffee...
Push ok to start boiler
Try opening the steam valve before pressing ok.
This will let water into the boiler before the heat element comes on.
Apr 23, 2009 | Saeco Incanto Classic Espresso Machine
Saeco Primea new machine - slow dripping
look in manuel how to ajust the coffee grinder its grind the coffee to fine when you ajust the leveler of coffee move it only when the grinder work do a few ajustment it will be fine pierre
Dec 25, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Ring stuck on warming up
Hi
I had the same problem and could solve it but i had take the machine apart.
Under boiler you have 2 thermo fuses that can be resetted. After reset i have checked if boiler get 220volt, It did for a short while but the fuses goes off again.
That means boiler is ok, it gets hot but fuses goes of due to temperature reach over 170 degrees celcius. That means that the power is olways on to the heater and doesnt stop to heat.
In diagnostic i could see that the temperature sensor does show the high temperature. That means that temp. sensor is ok which leads to the controller of the power to boiler. On the board i found big heatsink and a triac atached to it. I soldered it out and measure that it was spoiled.
Ordered new one for 3 euro. Soldered new one on the board and the problem was solved.
Original was BTA16-700CW but they didnt have it so i replaced it with BTA16-600CW, difference is that original one can handle 700volt the new one 600, but there is only 220volt it will controll anyway so that was ok.
I atach a picture.
Regards, Pawel
Nov 18, 2008 | Saeco Vienna Espresso Machine
Machine won't stop descaling cycle
MAKE SURE YOU DO NOT SHUT DOWN YOUR ESPRESSO MACHINE WHILE IN THIS MODE OR IT WILL INTERRUPT THE CYCLE. BE SURE TO CAREFULLY UNDERSTAND WHAT THE MACHINE IS ASKING FOR AND USING THE MANUAL MAY HELP YOU WITH THIS PROBLEM. WE HAVE NOT SEEN ANY OF THE PROBLEM YOU ARE SUGGESTING, BUT THERE IS ALWAYS A FIRST. IF YOU NEED SUPPORT AND YOUR MACHINE IS LESS THAN 1 YEAR OLD CONTACT SAECO AT 800-933-7876.
IF YOUR PRIMEA IS OLDER THAN ONE YEAR YOU CAN CONTACT CERINI COFFEE @ 718-584-6120 OR VISIT OUR WEBSITE AT WWW.CERINICOFFEE.COM
Oct 30, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco Primea Cappuccino Ring--stuck on "boiler filling" mode!
Hello, I had the same problem, therefore the machine has gone to a repair centre. The problem is caused by a mechanical switch in the machine, that doesn't work properly. To repair it you've to open the machine completely, but that’s not easy. Because there is nothing broken you’ll should have warranty because it is a production failure. The solution in my case was to heat up the switch and push it a little together so that the contact works properly. It is the switch that you hear when you turn on the machine.
Oct 29, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Saeco primea Ring
What i know there will not be any dvd or cd, it´s only on paper:-(
/Mirran
Sep 03, 2008 | Saeco Primea Cappuccino Touch Plus Coffee...
Kitchen Ranges Logo
453 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
