1992 Honda Accord Logo
Posted on Apr 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can't get interior dash lights or tail lights to work,i have pulled the fuses and checked them, but they were not blown. My headlights, turn signals, and brake lights work but dash lights and tail lights will not
Johnny Brown
Level 3:
  • Honda Master 5,763 Answers
  • Posted on Apr 05, 2010
Johnny    Brown
Honda Master
Level 3:
Answers
5763
Questions
0
Helped
3164183
Points
20432
You do have a blown fuse, this car has 2 to 3 fuseboxs, the fuse that holds the dash and park lights is located in the under the hood fusebox, its fuse # 8, heres a diagram of the fusebox in the engine compartment under the hood, hope this helps,can't get interior dash lights or tail lights to - 36e8e5a.gif
1984 Chevy Suburban tail lights not working
Check the tail light bulbs, check to make sure the dash lighting switch is turned up but not turned so far up that the interior lights come on when the door is closed.
2answers
Tail lights, parking lights and dashboard lights on 2004 grand marquis are inoperative. Headlights, turn-signal lights, brake lights, hazard lights, back-up lights all work
Tail lights, parking lights and dash lights are all on the same circuit...I'd go to the fuse panel under the dash and check the fuse for those lights....usually referred to as accessory lighting in the owners manual and is usually a 10A fuse.
Hope this helps...
10helpful
2answers
Interior dash and running lights dont work but my signal and brake lights work else works
Look at fuse #18, a 15 amp fuse, in the fuse block. This fuse powers both the tail lights and instrument cluster lights. Usually both of these light systems are powered by the same fuse so when your cluster isn't lit up you'll know right away that your tail lights aren't working as it's not safe to drive without tail lights. Your brake, turn, and head lamps are powered by different circuits. Hope this helps and good luck!
1helpful
Headlights and door locks not working
Fuse is probably blown out. Replace fuses for respective functions. Find the fuse box: might be in engine near battery or below steering wheel. open top and check for blown fuses. Try replacing if blown fuses are found. If all fuses are OK then it is very unlikely that all the bulbs are blown.
Tail lights and dash lights not working
there are a few fuses under the hood be sure to check fuses again at dash they could look good but not be and if one was blown it could have blown as soon as you turned them on again that would indicate a short. it could be the switch also if it is the pull type try pulling it slowly to see if they come on and turning it like to dim the dash lights. if that makes them come on you need a new switch sometimes it will work sometimes not
No tail lights, cabover lights, or park lights
relay? or the switch it self mine had that problem but the headlights didnt work
3helpful
2answers
Electrical problem
I just had the same issues. No headlights, interior lights, power door locks, radio controls on steering wheel, or dash lights. Pulled every fuse in cab and under hood, not a one was bad. I disconnected the battery terminals for a few minutes. When I reconnected them every thing was working.
Top Honda Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Honda Expert? Answer questions, earn points and help others
