I cant get my asrockk7s8x motherboard usb2 connections to work,if iplug more than my usb keyboard in the others work but my mouse n keyboard freezez
    Sergeant:
  • 349 Answers
You need to flash the bios with the latest bios for your motherboard this is the asrock website
http://www.asrock.com/index.asp
good luck
Terry
Posted on Mar 18, 2008
SOURCE:
Problem with mouse usb
It sounds to me like your USB mouse is not USB2 compatible. Use it while it is connected to the USB3 port. Did it at one time work in the USB2 port?
Mar 19, 2014 | Computers & Internet
Mouse & keyboard not working
You're "stuck" -- if the circuitry for the PS/2 keyboard and mouse is not working, and if it does not recognize a USB keyboard, the motherboard must be replaced (by an identical moetherboard, if you can find one, or a "newer/better" motherboard that takes the same CPU and RAM as your current motherboard).
Jul 30, 2010 | MSI PM8M-V Motherboard
My mouse does not work. I originally could not turn the pc on for approximately 1 week. I took it in for repair , they could not find the problem. When I returned home and repluged all the wires the...
Are you using an USB mouse? If so you may like to try another USB port or there might be some wire to the USB port not plugged right. You can check the printing on the motherboard to see how it should be plugged. (There is several wires for each USB port with a certain order into an plug on the motherboard when the USB port is not on the motherboard). You can check the power and make sure it is connected well and enough for everything. Other options will be to use other mouse like wireless mouse or PS/2 to USB converter to make a PS/2 mouse an USB mouse or vice versa. Checking motherboard and measuring every voltage could be very complicated.
Jul 24, 2010 | HP Pavilion dv1600 Keyboard - 412374-001
I replaced my hard drive in my hp pavilion desktop a1520n windows loads and then reads that i will have to register my copy of windows But my keyboard and usb ports dont have power so i cant do a...
A lot depends on where the keyboard and mouse are plugged in. I have seen in the past that the USB in the back works better than the front. Are these the original keyboard and mouse? If not, use the original until after Windows loads the desktop.
Mar 21, 2010 | HP P2360AA Keyboard/Mouse
USB Keyboard will not access BIOS.
Hi there.
Get the PS/2 keyboard and go back into the bios, make sure all the USB controllers are set to "enabled", save the changes and exit the bios, the computer will restart and your USB keyboard should now work and you will be able to access the bios using the USB keyboard.
Good luck and thanks for using FixYa!!
Apr 29, 2009 | Computers & Internet
I cant get any mouse to work on my dell laptop.
see the very first thing is that what u can try is that try and connect the same mouse that u had and that had worked and if works then the prob is with the mouse that u have right now and if that also doesnt work then the usb port on the laptop has gone bad and u need to replace the motherboard of the computer but before replacing the motherboard try and connect some other usb device on the same usb port.........
Jan 25, 2009 | KEIO PS2 Optical Scroll Mouse
USB system is not working
nope..you can try to boot from an installtion cd..but without HI options(Human Interface) you may find it's locked..sounds a lot like the Motherboard went south.
You could try to reseat the memory, but that's a low probability approach to this sort of problem
Mar 30, 2008 | Acer Aspire 5100 Notebook
Bios not accessable
yes cant use reg keybord or buy one new one
Jan 25, 2008 | Intel D865GVHZ Motherboard
USB2 high speed not recognize
It sounds like your Windows XP might be missing the USB2 drivers. Try going here http://www.windowsmarketplace.com/ and download the driver needed and see if that fixes your issue.
Sep 27, 2006 | ASUS P5LD2-VM Motherboard
Computers & Internet Logo
Ekse
Alun Cox
