Question about Samsung PCL545R 54" Rear Projection Television
SAMSUNG HDTV MODEL NO. PCL545R
My tv shut down after being on for about 2 hours, then about every 15 minutes.
  • misspeaches Aug 12, 2008
    My Name is Mavis, I have the Samsung PCL545R 54inch Rear Projection TV. I purchased it in October 2001 brand new, I even got the 5year service plan, now that the service has exprired it will not turn on. I was watching it about 3 weeks ago for about 4 hours and it just suddenly shut off !!! I tried to turn it back on and nothing!!! the little Timer light will not go out and the TV will not turn on. I never watch this TV much,but when I did I have never had a problem with it. Can you PLEASE HELP ME!!! I also have a 55 inch Mitsubishi that did the same thing, but the timer light would just flash this went on for about 3 months. Then all of a sudden the Green timer light stopped flashing and now the TV works Perfectly. I don't think that I will be so lucky with My Samsung. Please can you tell me what to do or who to call. Thanks, Mavis Moore ... ATL GA
    Still need a solution
  • Griff327 Oct 20, 2008
    I have the same problem the TV was working fine when we turned it off and would not turn on the next day
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 92 Answers
Do you see any deteriation of picture quality before shut down ? This could be a number of diff problems. Need more info
Craig www.classtorations.com
Posted on Jun 10, 2008
I have a samsung tv model #hln4365w. it turns on but the lamp light blinks and cycles through about 3 times, then the three lights come on including tempature and all shuts down. Is this the sign to...
The projection lamp has not been replaced like 1 1/2 or 2 years and tv on and used like 4 or 5 hours a day on this tv?yes,than the projection lamp life is over.Require a new projection lamp.
Sep 13, 2010 | Samsung HLN4365W 43" Rear Projection...
Samsung PCL545R 54 in. Rear Projection Television
Ur tv have a problems known as a convergence problems,it dead.The tv covergence board must have it 2 STK Convergence ICS and some or all resistors be rreplaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 05, 2010 | Samsung PCL545R 54" Rear Projection...
I have a '03 model Samsung HLN5065W TV that after approx 1 hour, part of the images start turning white. If I shut it off, for only 1-2 minutes, the picture is good for another 15-20 minutes.Occasionally,...
Look on your Power supply board ,it will be on left hand side,Bad Capacitors 330uf 10v 220uf 10v 1000uf 16v if you see any that are swollen,or Puffed up on Top they are Bad replace them and order you another Lamp, I got Mine on Ebay for $85.00 Look under Electronics
Encompass Parts Distribution will have part number on their website just type in your model number and it will list Parts and Prices 1-800-638-3328
Apr 24, 2010 | Samsung HLN5065W 50" Rear Projection...
The TV will just shut down at anytime. It may be after 10 minutes or 2 Hours.
ok This could be a power supply problem you can also check you ballast or either like I told you before could be a power supply issue
Regards
Jan 07, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
I have a samsung projection tv model PCL545r. Turns on then off.
Ur tv leaking coolant,burn parts?Take to shop for clean hazzard materials,change what cause the burn parts by the chemicals.
Nov 23, 2009 | Samsung PCL545R 54" Rear Projection...
TV shut off after 10 min.
it souds like the cooling fans arent working correctly. if the tv is staying on long enough to warm up and then shutting down i would look at the cooling fans
Jan 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Samsung PCL545R Projection TV
Pull out the plug for the TV and leave it out for one hour at least.  Plug it back in and it should be ok.  It will re set itself.
Sep 30, 2008 | Samsung PCL545R 54" Rear Projection...
SAMSUNG TV MODEL HLR5067W
Sounds like the lamp to me. The projection lamps get hotter as they age and the TVs have a sensor to monitor the temp and shutdown the TV if it get too high
Projection TV makers charge an arm and a leg for their replacement lamps. They make it easy to do but as a result the custom lamp assy is expensive. The trick is to buy just the bulb for your model TV from any number of us aftermarket sources at a fraction of the lamp price and install it in the old lamp yourself. Really easy.
Jan 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Tv shuts down
does the main board have the flyback on it? if so the yokes or CRTs can be intermittently shorting which in turn triggers your shut-down.
turning it off or unplugging just resets the shut down circuit.
Sep 04, 2007 | Samsung HL-R4266W 42" HDTV-Ready...
Samsung PCL545R 54" Rear Projection Television Logo
88 people viewed this question
Jerry Greenberg
Jerry Greenberg
