Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
Toshiba model tz50v61 convergence
Can not get the x or crosshairs on screen to adjust red and blue and green
  • cudd1es May 05, 2008
    Convergence has some how gone way out of adjustment from one day to the next. Please assist on the adjustment procedure. The fine adjustment on the TV is of no help, I need a course adjustment.
    Thanking you in advance
    Paul
I am not getting sound out of tv toshiba tz50v61
Posted on Nov 01, 2008
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
Need to repleace convergence ic # stk392-110 or stk392-160 on hitachi brand
Posted on May 03, 2008
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    The color on my rear projection TV is a little off. I tried to fix it by pressing the 'test' button below the screen. I can move the red crosshair perfectly on top of the set green one, but the blue...
    Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
    Common Problem #1) Convergence has gone out
    Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
    This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
    Common Symptoms include....
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
    Here are some pics of convergence problems.
    69189a5.pngSOLUTION #1
    For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
    Common Problem #2) CRT Fluid is Cloudy
    Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
    Picture of a set that needs the fluid changed.
    TV set after fluid change
    69189a5.pngSOLUTION
    You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
    Jan 29, 2011 | Mitsubishi WS-65711 65" Rear Projection...
    Need code to enter on remote to engage multipoint convergence adjustments.Need save proceedure after adjustments are made & exit proceedure for RCA Projection TV Model # HD52W59, ITC 222A
    To get the code to enter on your remote to engage multipoint convergence adjustments, you need to contact the rca customer care for that, you get them your model number and they will get your code for you.
    To process and save the adjustment made, follow the steps below;
    1. Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
    2. Enter the menu on your TV. Use the remote control and bring up the menu.
    3. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
    4. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
    5. Press "Enter." A crosshair pattern will appear on your screen.
    6. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
    7. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
    8. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
    9. Repeat these steps for all colors.
    Take care
    Jul 06, 2010 | Televison & Video
    I have a Philips 51PW9303 Rear Projection TV that had blue shadows around the sides of the screen and now has a green and red bowed line at bottom. Does I need a convergence board to solve this?
    If the following doesn't work the tubes could be at the end of life:
    Adjusting convergence:
    Note: For best results, the Projection TV needs to be turned on for 15 minutes or longer before adjusting the picture tubes (convergence).
    To adjust the convergence of the picture tubes:
    1. Press the 'MENU/SELECT' button on the remote.
    2. Press CURSOR RIGHT to enter the PICTURE menu.
    3. Use CURSOR DOWN and RIGHT to select and enter MANUAL CONVERGE.
    4. Press CURSOR RIGHT to select CONVERGE RED or press CURSOR RIGHT and DOWN to select CONVERGE BLUE.
    5. A crosshair will be shown on the screen. If there is any red or blue fringe around the crosshair, use CURSOR RIGHT, LEFT, UP, DOWN to try and merge the fringe colors with the crosshair.
    6. Press the 'MENU/SELECT' button to return to MANUAL CONVERGE menu.
    7. Press the 'EXIT' button to exit the menu.
    If you are satisfied with the convergence you may stop now. Otherwise, you can continue and adjust the convergence more using mult ipoint convergence.
    To Adjust multipoint convergence:
    2. Use CURSOR RIGHT to enter the PICTURE menu.
    3. Use CURSOR DOWN and RIGHT on the cursor ring to select and enter MANUAL CONVERGE.
    4. Press CURSOR RIGHT and DOWN on the cursor ring to select MULTIPOINT RED or MULTIPOINT BLUE.
    5. A grid of crosshairs will appear on the screen. If there is any red or blue fringe around any of them, press CURSOR RIGHT to enter NAVIGATE mode.
    6. Use CURSOR RIGHT, LEFT, UP, and DOWN to move to a crosshair that has a color outline.
    7. Press the 'EXIT' button to enter ADJUST mode.
    8. Use CURSOR RIGHT, LEFT, UP, and DOWN to merge the color with the crosshair.
    9. Press the 'STATUS/EXIT' button to return to NAVIGATE mode. Repeat as necessary.
    10. Press the 'MENU' button to return to the MANUAL CONVERGE menu.
    11. Press CURSOR DOWN until SAVE MULTIPOINT is selected.
    12. Press CURSOR RIGHT to save the multipoint settings.
    13. Press the 'EXIT' button to exit the menu.
    Apr 03, 2010 | Philips 51PW9303 51" Rear Projection...
    Toshiba big screen Model TZ50V60 Convergence Issue-Chips Replaced
    These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
    Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
    Here are some of the most common problems with these sets...
    Yours may have one or more of the following symptoms
    • Screen Looks 3-D
    • Colors wont align
    • Screen may look distorted or warped
    • No Audio/Video - makes a chirping sound.
    Problem #2
    Another common problem is dull or washed out video.
    Your TV may have one or more of the following symptoms....
    • Dull looking picture
    • White looking picture
    • Halos around objects
    • Red/Orange looking picture
    You can see some more examples and find a fix here
    bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
    Mar 29, 2010 | Toshiba TZ50V61 50" Rear Projection...
    How do you set convergence
    What is your Make and Model number?
    Mar 18, 2010 | Televison & Video
    Blue Convergence
    Blue convergence IC is bad, but change both as red wont be far behind they are cheap about 10.00 ea at the following link.
    http://electronix.com/
    Jan 14, 2008 | Toshiba TN55X81 55" Rear Projection...
    Fine tuning grid on my Samsung HDTV with remote.(BP59-00048)
    To adjust manual convergence on your projection TV, follow theses steps:
    1. Turn your TV on.
    2. Let it warm up for 30 minutes.
    3. Press the Menu button on your remote. The Main menu appears.
    4. Use your remote to select Function, and then press the joystick.
    5. Select Convergence, and then press the joystick. The Manual Convergence screen appears.
    6. Select Red, and then press the joystick. A series of crosshairs appears on the screen.
    7. Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have. Note: You must do the outside crosshairs first.
    1. In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair. Note: Make the single horizontal line as white as possible.
    1. In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair. Note: Make the single vertical line as white as possible.
    1. Repeat for all outside crosshairs, and then for the inside crosshair.
    2. Return to the Manual Convergence Screen, and select Blue, and then press the joystick.
    3. Repeat Steps 7 through 10 for Blue.
    4. Press the Menu button on your remote to exit.
    Important: The directions above work for most Samsung Rear Projection TVs. Yours may be different. For exact directions to perform manual convergence, see your user's manual. If you don't have your user's manual on hand, click HERE to view your manual on line.
    If you cannot get your Projection TV to converge, it may need to be serviced. To arrange a service appointment, call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your TV's model number and serial number on hand when you call.
    Jan 05, 2008 | Samsung BP59-00016A Remote Control
    Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
    136 people viewed this question
    Top Toshiba Televison & Video Experts
    Jaime Hernandez
    Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
