Colour prints not satisfactory
I have replaced the colour ink cartridges in my HP Photosmart 8450 printer ( the black cartridge was o.k., I believe) but my colour prints are coming out incorrectly - i.e. overexposed or lacking saturation.
I have been told to direct the computer to clean the printer heads but cannot find this tab or page. I am using Windows Vista. Is this what I should be doing? And if so, how do I access this command?
    President:
  • 778 Answers
D_foofat,
This link will take you to instructions on cleaning your Cartridge Print Head: http://h10061.www1.hp.com/ccsearch/search?method=viewDocument&redirUrl=http%3A%2F%2Fh10025.www1.hp.com%2Fewfrf%2Fwc%2Fdocument%3Fdocname%3Dc00285228%26cc%3Dus%26lc%3Den%26dlc%3Den%26product%3D402150%26dlc%3Den%26lang%3Den&docId=document%28c00285228%29&uqry=&cqry=clean+printhead&ctry=us&dlc=en&lang=en&qry=clean+print+head
I hope it helps, and Good luck.
Posted on Mar 18, 2008
SOURCE:
B210 Photosmart Plus has HPcoloured cartridges in but is now not printing successfully. Background colour is lavender
Hey, i'm going to mentioned some steps here, follow these as it is:
1. Use Genuine Ink Cartridges
2. Cross Check Estimated Ink Levels
3. Replace All Low or Empty HP Ink Cartridges
4. Check for all Ink Cartridges are properly vented and seated correctly
5. Clean the print-head
Now Start your HP Printer again, i hope, i works fine, to know more, dial my toll-free number +1 (833) 493-0111, Regards
Apr 08, 2017 | Computers & Internet
Printer Photosmart 8450. Using HP black cartridge. Received message saying the printer did not recognize the cartridge because it was not HP. Removed it and tried several times to print. Gave up and...
Regarding your HP94 black ink cartridge error problem and inability to print to your HP PS 8450 printer, this type of problem is probably an internal micro-electronic failure inside the HP94 ink cartridge.
To determine which cartridge is causing the issue and/or to confirm an electrical problem with one of the ink cartridges (or possibly both), perform both the Internal Self-Test page along with the Pen Electrical tests (diagnostics) to evaluate the electrical condition of both ink cartridges....
Please first verify the age of the ink cartridge(s)....look at imprinted date on front (or back) of ink cartridge. If this 'warranty expiration date' has expired, then potential cartridge failures can occur due to internal corrosion, etc.
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Print Self-Test Page:
1. Press CANCEL and SAVE simultaneously (SAVE is the left-most button before POWER on/off.)
2. Using left/right arrow keys, navigate to 'pen electrical test'.
3. Select Enter to print test - evaluate nozzle test pattern.
-- If the printer prints the self test page then this demonstrates the printer is generally functional and that the problem is likely with one of the ink cartridges. Please note this is a 'forced' service test...the printer will attempt to print the test page whether the cartridges are good or bad. If the Self-Test page can be successfully printed but regular/normal printing cannot, then one of the ink cartridges is likely internally damaged. Remove and replace suspect cartridge to confirm.
C. Perform Cartridge Diagnostics tests using either C.1 or C.2 procedure below (varies by printer model):
C.1. Tap 41/43 Diagnostics Test:
1. To enter the Manufacturing Tests menu, press the 3 small, round buttons on the front panel simultaneously for >5secs: 'OK', 'CANCEL', & 'SELECT PHOTOS' (or 'Print Photos')
2. Using left/right arrow keys, navigate to Special Reports (or System Menu). Select Enter.
3. Navigate to 'print-mech button tap' menu.
4. Select Ok ('code = 0' will be displayed); click and hold Right Arrow until 'code = 41' (or attempt 'code = 43' if nothing prints using '41') is displayed.
5. Select Ok. Within one minute the Tap 41 (or 43) diagnostic test pattern should be initiated and print. Refer to video to help evaluate test pattern. Refer to 2nd video for guidance on how to read the diagnostic test pattern: http://inkjet411.com/?page_id=1741
NOTE 1: A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. For reference only, refer to the following HP Deskjet video which shows how to read the HP 93-97 ink cartridge diagnostic test print: http://inkjet411.com/?page_id=1741 (see 2nd video)
C.2. Pen Electrical / Error Bypass Procedure:
2. Using left/right arrow keys, navigate to Reports Menu (or System Menu). Select 'pen electrical test'.
3. Select Level 1, 2, or 3. Enter to print test - evaluate nozzle electrical test print.
NOTE 2: Pen recovery level 1, 2 or 3 clears cartridge errors, unblocking the printer to permit you to print the TEST PAGE with the normal MENU / TOOLS /PRINT TEST PAGE choice to aid in printer evaluation.
NOTE 3: Cartridge Error Bypass Message (Emergency Printing only): The Pen Recovery Level 1 clears cartridge errors and permits you to print the TEST PAGE with the normal MENU / TOOLS / PRINT TEST PAGE choice.
For additional information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (error bypass/printer reset methods, etc.), please visit Inkjet411:
http://www.inkjet411.com
Aug 03, 2013 | HP Photosmart 8450 InkJet Printer
I have loaded a colour cartridge a and a black cartridge into my 8450 printer and now all I get is the 05f37c2b error code apear on the screen
Please try the following:
Remove the cartridges that you just replaced. Ensure that they are compatible with your HP 8450 printer. Make sure that none of the electrical contacts on the printer or cartridges are damaged and that there is no obstruction in the cartridge port. Turn printer main power off, and then back on with the cover closed. If the error code is now gone, open the cover and install the new cartridges as described in the manual. Also, did you remove the protective nozzle covers from the cartridges?
Good luck,
GaugeMan
Mar 06, 2011 | HP Photosmart 8450 InkJet Printer
My printer screen says
The ink is contained in a cartridge.
Note that "backup" printing mode mixes colours, to produce "black", because the "black" ink-cartridge has failed.
So, replace the BLACK ink-cartridge.
Jan 05, 2010 | HP Photosmart 8150 InkJet Printer
Photosmart C5280. Instructions on photo cartridge 348 say remove both black and colour cartridges, then install photo cartridge in right hand cartridge holder. Printer screen then tells me to install...
Your printer uses the following cartridges:
HP 74 - Black ink
HP 75 - Cyan, Magenta, and Yellow ink
HP 99 - Photo Black, Light Cyan, and Light Magenta
You need Photo Black, Cyan, Magenta, Yellow, Light Cyan, and Light Magenta to print photos. To accomplish this you install the HP 99 photo cartridge where your HP 74 black cartridge usually goes and you keep the HP 75 color cartridge where it's at. I don't know why your printer told you to remove both cartridges, then reinstall the HP 75 color cartridge.
Oct 10, 2009 | HP Photosmart C5280 InkJet Printer
Colour cartridge missing but I only want to print
No you cannot. Each one of your cartridges is smart chipped. When this cartridge registers as empty it acts as an on/off switch thus turning the printer off.'
You need to replace the empty cartridge in order to print.
Go printer settings and check option to print only black.
Jul 30, 2009 | HP Photosmart 3210 Printer
HP7660 Photosmart Printer
It comes with HP #57 (C6657 A)—Tri-color print cartridge and HP #56 (C6656A)—Black print cartridge and the 56 must always be in there (the black one) but acceptable replacements for the color one are as follows: HP #58 (C6658A)—Photo print cartridge I suggest for the best photos use 58 and 56.
Feb 28, 2009 | HP PhotoSmart 7660 InkJet Printer
Hp Photosmart 3110
I have changed the BLACK cartridge ( as suggested ) but still cannpt print or move breyond the PROBLEM Note that comes up to CHANGE the Yellow and Black Cartridge - I cannot SCAN or COPY leave alone PRINT - please suggest a solution - Thanks ,
Adrian
May 14, 2008 | HP PSC 2210 All-In-One InkJet Printer
Open Questions:
Computers & Internet Logo
76 people viewed this question
Ekse
Alun Cox
