Polaroid PDX-0073 7 LCD Portable DVD Player
Put in a DVD and display reads No Disc.
  • Anonymous Jun 16, 2008
    polaroid PDX 0073 dvd player refuses to recognize display reads "No Disc".
    I had gotten it to play a few times after this message first began appearing a few days ago but now all discs get the same message.regaurdless of type DVD, DVD-r, DVD+r Pal, NTSC etc.
  • Anonymous Sep 19, 2008
    gee i have this same proble times two. After hurricane gustov both mine say no disc. have tried the alcohol on the eye trickon both,have tried the new disc reloading trick as well as the disconnect recon.trick all to no avail,have three batteries and would like to keep being able to use them,as i live in hurricane area ,what model number would enable me to use my batteries? thanks a bunch
  • 3 Answers
Hello
I had that problem, the problem is that where you put the disc (the black Circle) tends to get a bit loose so it moves downwards.
so the distance between the lens and the under surface of the DVD / CD is reduce, so the beam is NOT return to the lens.
The way I fix it is by pulling the black circle EXTREMELY carefully and SLOWLY while you are turning it.
Once is out, with a toothpick or a needle put a small amount of crazy glue in the inner walls of the hole that is in the center ( where the pole of the rotor goes in) this way the hole is reduce.
Wait till it dries, then gently put it back in, it will be a tight fit, IT MOST NOT GO ALL THE WAY IN!!!
By this i mean that you will see the pole of the rotor go into the hole, but it most not reach all the way, it should be below the surface. The distance between the end of the pole and the surface of the black circle should be THE THICKNESS OF THE BLACK CIRCLE.
The way to know that the distance is right, put in a CD and play some songs, then try it with a DVD.
If it reads no disc it means you inserted the disc to much, pull it out a bit, then try again.
Once it reads both CD and DVD, fill in the hole with a drop of crazy glue, this way the black disc will not move anymore.
One more thing, I do not recommend to use alcohol in the lens, 'cause some lenses are now made of polymers non resistant to abrasive, instead use a cue-tip (cottonete, little pole with cotton to clean your ear) moistened with bottle water or distiled water.
Note MOISTENED not soaked or wet.
Hope it works for you.
Best Regards
Luis.
Posted on Dec 29, 2008
SOURCE:
After i put the dvd in it says loading for a long period of time then a screen comes up and gives me the options of Config, DVDROM and fscommand..i try to go through each one and they get me no where but...
Sounds like the DVD is not video but a ROM disc. VD's can store hundreds of times more data than a CSD Rom and that's why they are used for this purpose. Put it in a computer DVD drive and see what is on it.
Mar 18, 2011 | Polaroid PDX-0073C 7 in. Portable DVD...
Need to know where to get a new ac adaptor and car adapteer for it
Radio Shack has all sorts of power bricks and universal adapters you can probably put something together from what they offer.
Jun 09, 2010 | Polaroid PDX-0073S Portable DVD Player
Where can i purchase power supply cord with ac adapter.
Try encompassparts dot com. Not sure for that type. pacparts dot com, shopjimmy dot com.
Apr 19, 2010 | Polaroid Portable DVD Player PDM-0722
Polaroid Portable DVD player PDX-0758 reads bad disc for all dvds
the only way is cleaning the optic reader.Just wet in alcohol a swab -almost dry- and clean it.If this does not fix the problem,you may have to replace it.
Feb 15, 2010 | Polaroid Portable DVD Player PDM-0822BD
Dvd not playing
2008 EXCHANGE MODELSNO PARTS FOR SERVICE
Aug 20, 2009 | Polaroid PDX-0073S Portable DVD Player
My Polaroid DVD player has been used very little. I charged the battery; put a dvd in and it says "Loading" and never starts playing the movie.
Sounds as if the EYE is dirty. Look closely at the spindle (cd mounts on) and try to locate the glass eye. Swab with alcohol gently, I mean gently.
If still bad, then the eye transport mechanism needs to be replaced. Not hard couple of screws and flex cable, look for part number and then go to matelectronics.com good luck, be safe..
Mar 11, 2009 | Polaroid PDX-0073S Portable DVD Player
Polaroid Model pdm 2727 2 7inch Wal Mart Purchase $185.00 (HELP PLEASE)
You might try gently cleaning the laser eye with soft dry Q-tip. Other wise the laser will probably need replacing. I repair and sell portable DVD players.
May 15, 2008 | Polaroid 7" Two-Screen Portable DVD Player
POlaroid portable dvd player BT-6002
The laser that reads the dvd needs re-calibrating.
Apr 28, 2008 | Televison & Video
Polaroid PDM-0711 DVD player won't play DVD's but still plays CD's
I've got the same problem, I turn my player on it's side until it reads the disc. more of a band-aid solution.
Mar 28, 2008 | Polaroid 7'' Portable DVD Player
Cd not reading
Hello
Best Regards
Luis.
Dec 18, 2007 | Televison & Video
Televison & Video Logo
545 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
