Easy Transfer cable issue
I would like to connect an XP laptop to a Windows 98 Laptop, but don't have the software to connect using the Easy transfer cable. Help please.
You can download "Windows Easy Transfer" for free from Microsoft or from most manufacturers of "Easy Transfer Cables". Good luck, the software is ****.
Posted on Apr 03, 2008
    Genius:
  • 3,587 Answers
Hmmm..the xp sp 2 has the file transfer option. but don't believe it goes back beyond 2000. You may need to backup and restore this one..check here for a free 2 Gig online backup optioin
Posted on Mar 16, 2008
6ya staff
SOURCE:
Help for easy transfer cable
If both computers are connected to your network, you can easily enable sharing of the drive(s) on your XP computer, then connect to it from the Windows 8 computer and transfer the files over the network.
Aug 06, 2014 | Belkin Easy-Transfer Cable for Windows XP...
I just purchased a new laptop that has windows 7. How do I transfer my accounts and files from my old one that uses windows xp?
From the windows 7 computer, Start, Accessories,System Tools, Windows Easy Transfer. Follow the onscreen instruction. Note both system must be on the same network.
Aug 08, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Dynex Easy Transfer XP to Windows 7 not working
Remove old drive from computer and install in new computer using ide ribbon. It will connect as a secondary unit and you can then using windows explorer transfer any data on old drive to new one.
Jun 19, 2017 | Dynex Computers & Internet
Old pc w/disk drive laptop no disk drive.
If both Pc's support the cable and software The cable which I recall was a null modem cable, then yes if your laptop has a serial interface.
Please rate my help++++Thanks for using FIXYA
May 04, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Purchased a belkin easy transfer cable. When
One of the most common problems is the computer's operating system not recognizing the cable's drivers. This is most common with non-English operating systems. The quickest solution is to download the most recent driver.
If the Easy Transfer Cable isn't working properly, you can try a few things to fix the problem. Make sure that you have installed the Easy Transfer Cable drivers on your old computer with the CD that is included in the cable package. If you did not do this, close Windows Easy Transfer, insert the CD that came with the Easy Transfer Cable into your old computer, and then follow the instructions on the screen. When this is complete, begin the transfer process again.
USB ports might be another cause of the problem. When Windows Easy Transfer asks you to connect your computers with the Easy Transfer Cable, try plugging the cable into other USB ports on your computers.
A more complex problem involves the F5U409 USB PDA Adapter (The USB/Serial Portable Adapter) not installing properly. If the driver is unzipping, but the unit is not working, you need to manually update the drivers. They should all unzip to a file called F5U109 in the C: drive of your computer. Point to this file through the Device Manager to update.
Hope it helps.
Mar 21, 2010 | Belkin Easy-Transfer Cable for Windows XP...
I bought a new laptop from Dell. My old on is a desktop from Dell. I have a Belkin transfer cable. It is asking for a transfer key number. what is that????????
Please note that your cable will support below givne O/S check at your end.
One destination PC running Windows 7 (32- or 64-bit) and available USB port
One source PC running Windows® XP (32- or 64-bit) or Windows Vista® (32- or 64-bit) and available USB port
For Example two Pcs 1 is Xp and other pcs is Windows 7, then try to connect between both .
Another one more option is there for transfering the data between two systems either laptop or Desktop by a cross cable (LAN CABLE), buy a cross cable from shop and insert into RJ45 Socket (i.e lan socket) the try to transfer the datas.
If this answer is helpful, please rate....
Feb 27, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Belkin esy transfer cable problem?
Check the easy transfer details on the link below:
http://techtake.net/2009/08/12/windows-easy-transfer-windows-7/
http://techtake.net/2009/08/12/can-i-upgrade-from-windows-xp-to-windows-7/
This may not be a direct solution, but will help you identify the problem.
I hope this helps.
Aug 26, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Instalation problem
1st step:Install lan driver in both laptops from there own methere bord cd.
2nd step:Connect both laptop vis lan wire.
3rd step:Goto startmenu--->Control Panel--->Network Connections.there is a item whose name Local Area Connection
4th step: Right click on Local Area Connection.select properties from menu.
5th step:select General tab,see there is a level name by "The connection uses the following item :".scroll and select Iternet protocol (TCP/IP) and press properties button
6th step:Select Use the following IP address,put ther IP address.its like 192.168.0.1(IP address) and subnet mask is 255.255.255.0 and press ok.after thene press close button.
i think after that work,
but note that ip address are diffrent in both lapto.
Mar 30, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Usb transfer files doesn't work
this cable is design to transfer files from xp to vista or vista to vista.
but you can try by installing the software on both the pcs and tranfer the files hope it will work
Mar 23, 2009 | Compaq Computers & Internet
Connectivity problem with Belkin Easy Transfer Cable with XP and Vista. Presumably, software is installed on both machines (installed F5U258 driver on the XP machine, and was pre-installed on the Vista...
Hi..Start the file transfer on your old pc.When you get the screen to choose the option of using the transfer cable,select it..On your new pc click Start>accessories>System tools and then windows easy transfer..Follow on screen prompts and away you go..Just transfered some hol pics to my new vista machine
Feb 18, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Open Questions:
Computers & Internet Logo
90 people viewed this question
Ekse
Marvin
Marvin
