Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Help Just Changed Bulb & Still Get same error RED LAMP light. I have pressed reset many times & unpluged many times - still no change. Is there a different reset procedure or is there a failure
  • Mitsubishi Master
  • 8,617 Answers
Capacitors C9A37 and C9A38 are both 3300ufs @ 10 volts on the PWB is what causes this. replace those caps . be fair warned this is do able if you are dilligent and have a good service manual. This is a difficult chassis to service, very time consuming . I have been repairing TVs for 25 plus years and I did the same model today and took 4 hrs to disassemble, do repair and reassemble. but thats whats causing the trouble almost 95% sure of it.If you need more info let me know.
Posted on Mar 19, 2008
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
My 73" mitsubishi dlp WD-73827 turns off and has a red status light blinking. I have replaced the bulb and the heat sensor... any answer to what else could be the problem?
It is helpful to have the sequence of the blinking red light. This may help:
MODELS: WD-52627 / 52628 / 62627 / 62628 / 62827 / 62927 / 73727 / 73827 / 73927
Page 43
3. Error Code Operational Check
Note: The TV must be in "Shut Down" and not have been switched Off, to perform the Error Code Operational
Check. When the TV is switched Off, the code automatically resets to "12" No Error.
Pressing the front panel "DEVICE" and "MENU" buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must be used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED will flash two times, pause, and then flash three times.
4. Error Codes
The Error Code designations indicating malfunction, or no malfunction, are listed below:
POWER
LED
STATUS
LED
LAMP
LED
Power
Status Condition
Off Yellow Off Low
Power Excess heat. Check Lamp Filter
Off or On Off Yellow No
change
120w usage time over 7000 Hrs.
150W usage time over 3500 Hrs.
Off Off Blinks
Yellow
Low
Power Lamp Cover open
Off Blinks
Yellow Off " Filter Cover Open
Off Off Red Stby Lamp did not turn On
Off Blinks
Red Off Low
Power Fan Stopped
Off Red Off " Circuit failure (short or DVI
connector unplugged)
Abnormal LED Indications
Error Codes "DEVICE" & "MENU"
Error Codes Description
12 No error detected
22 Recovery from Reset
32 Lamp cover is Open
34 Lamp abnormality
35 DM Fan failed (Chassis Fan)
36 Exhaust or Lamp Ballast Fan failed
37 DMD Engine Fan failed
38 Lamp temperature abnormally high. Remove Lamp to check filter.
39 DMD temperature abnormally high
41 Short is detected (Standby Power Supplies)
42 Lamp Fan failed
44 DVI cable between Format and Engine disconnected
46 DMD Temp. Sensor not detected (check DT connector))
47 DM Temperature too high
48 Engine power supply short detected
51 Speaker Drive circuit short detected
52 HDD excess temperature (V30+ & V31 only)
55 HDD Fan Stopped (V30+ & V31 onlyt)
Jul 18, 2014 | Mitsubishi WD Televison & Video
What does it means of 6 seconds red light interval of my NEC MT1050 projector,and how will I fix it to come back to life?
Holding down the "OFF" key on the remote control for 30 seconds
to reset the lamp timer
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Jun 13, 2014 | NEC MT850, MT1050, MT1055, MT1056...
Status light blinks seven times
the lamp timer is failing
lamp timer chip is on the lamp housing,is a little chip
you need to reset the timer chip by using a Programmer
select a date of 0 hour..
Our company supply this chip with 0 hours USD15
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Jan 31, 2014 | NEC MultiSync MT1065 Multimedia Projector
My model is WD 62525 have sound but no picture. For serveral weeks the tv would come on with blinking yellow light and then red lamp light would come on. We would unplug and wait a couple minutes and plug...
Hi , make sure you put the cover back on so it can press the switch to let the tv know door has been shut and will allow to light bulb.Also when putting a new bulb in the ballast, which is the board that powers the lamp, sometimes its not able to provide enough power to light it up because it was used to provide a lesser voltage on the old lamp.Make sure you reset the lamp timer I dont know the exact code for it but u can search it on your manual.Hve a blessed weekend!
Apr 22, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have a 57" mitsubishi
You probably have a bad lamp again I hate to say. These lamp are so critical when being moved. If after you atttempt to power on TV then red light shows, press menu+input on the front panel and hold for 5 seconds. Front timer LED will blink a 2 digit error code five times then stop. Code 34 and 66 are lamp errors, and if you read code 66 the lamp is broken. Good luck
Bill W
integrityhomeworx.com
Mar 09, 2011 | Mitsubishi WD-57733 57" HDTV
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Apr 14, 2010 | NEC VT470 Multimedia Projector
I have a kdf-50e2000. when i turn on the power the green light comes on then goes off and red light comes on blinks 3 times on power and screen stays black. changed lamp and reinstalled(just bulb). picture...
Check the lamp door switch. This switch is really cheaply made. The switch is not available. short rhe wires to fix the problem. then never change the lamp witout unplugging the ac power in the future.
Oct 30, 2009 | Televison & Video
Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Apr 15, 2008 | Sharp Notevision PG-B10S Multimedia...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
60 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
