Question about JVC AV-48WP30 48" Rear Projection Television
Jvc av-48wp30 convergence problem
I have a red convergence issue with my av-48wp30. i see that there are numerous postings about bad stk392-110's......i replaced both and turned on the set only to find absolutely no change on my screen. after closer scrutinization, i noticed a smoked resistor, number r846.....which is marked 1.5 ohms (J)......after a trip to radio shack, i was unable to find a 1.5 ohm resistor.....anyone else have similar problems? where can i order one of these and what is the part number? also, how do i enter the service mode to adjust convergence? i know how to do it with the remote, is there another way? oh yeah, one more question.......what is the white button on the convergence board for?...thanks for any help!
  • pcfemt Apr 16, 2008
    thanks for the advice........i found a website that listed the part numbers and the schematic, went to parts.com and ordered the correct resistor, installed it and the tv works great! i'm thinking the resistor was blown when the original ic blew and i missed it when diagnosing........thanks!
  • jbmoore531 Jun 18, 2008
    I have a similar problem that I think will be the same. We came home from vacation to find that our 48 inch JVC I Art Television is bowing at the top creating a green and purple color over much of the picture screen. The tv is five years old. I have been reading the information online and have contacted a repair center who said it is most likely a convergence problem. I am, as you read this, trying hard to find a picture schematic of the inside of the tv to attempt a repair. I have placed a service call and am waiting for a time for the tech to come out and advise me of the actual problem.
  • 58 Answers
1. if the 1.5 ohm resistor was open, then you may have fried your new convergence ic's. Sorry
2. bettween a 1.5 - 1.9 ohm resistor will work
3. press sleep button, set to 30
hold down video status button and press display on remote
select convergence from the new menu and hit OK.
Do fix the convergence before you try to align the convergence or it will look horrible after you get the circuit fixed and will be harder to align.
The white button is there because the DCU (digital convergence unit) can be erased by holding that button and turning the set on.
I WOULD NOT RECOMEND THAT AT ALL!!!!!!!!!!!
Hope this Helps.
Posted on Apr 02, 2008
Jvc av-48wp30 blue to align convergence
Tv colors R,G,B don't alignment any colors.Tv have a convergence problems,it dead.Tv convergence board require changes 2 STK convergence ICS and some or all it resitors to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 11, 2010 | JVC AV-48WP30 48" Rear Projection...
On our JVC AV-48WP30 48in, red shadows
some how the convergence ckt went bad,common problem to pj televisions.
Mar 19, 2010 | JVC AV-48WP30 48" Rear Projection...
HI, my JVC AV-48wp30 has the same symptoms as other posts here. Powers on with no screen, HV, and no CRT heater coils light up. Thumping sound in speakers, and then shuts off. Blue light flashes. ...
take off the front panel and unplug the convergance board up front just behinf panel if the set now comes on replace your con amps if not you have a power supply issue more than likly the con amps are bad
Nov 20, 2009 | JVC AV-48WP30 48" Rear Projection...
I had a convergence problem on my JVC AV-48WP30, and followed the instructions posted by SD Tech. I used STK-392-150 chips and I replaced 1 burned out resistor that had no bands, but was marked 1.8 ohm J...
Yes, it does not happen often but you may have installed or got a new chip that is bad--you did apply heat sink compound to the new chips?
Check all the resistors carefully when you do this and double check all the soldering you do.
Let me know if you need help.
Rate this solution as I DO THIS HERE FOR FREE.
SD TECH
Nov 09, 2009 | JVC AV-48WP30 48" Rear Projection...
Av-48wp30
If the convergence Ics and resistors are good its most likely related to the velocity boards that are attached to the Red CRT convergence yoke. Its the small board about half way up the neck of the CRT. If you need one let me know as I have a source for JVC boards for that model.
Jun 28, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP34 convergence issue
Chances are there are other resistors open
Jun 01, 2008 | JVC AV-48WP30 48" Rear Projection...
Suddenly, the screen shows double images on letters and numbers plus red/greenish like shadows on characters.
Youre convergence Ics need to be replaced. post the model number of your set and I will post the STK number that you need and a link where you can get new replacement ICs
May 25, 2008 | JVC AV-48WP30 48" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
964 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
