Question about Motorola Mobility RAZR V3
Bluetooth linkage issue
I got a bluetooth headset off my friend but can't get it to work with my razr phone without a security code. Can someone please tell me a code to use?
Unless your friend changed something, the default code is 0000.
Posted on Mar 17, 2008
My wife and I have identical Samsung GT S5230 phones. Both will pair with my Kia Ceed bluetooth. The head unit will accept 5 devices but both will not connect with the unit at the same time meaning we...
the issue with Bluetooth connections is that with two headsets and two phones, you have to have your firmware set up to handle ONLY ONE set per phone. This means that if you set it to ONLY accept YOUR headset on your phone, it should work regardless of any other Bluetooth capable devices in range. If there are two possible devices in range and the phone is set to accept either one, it does not know where to send the signal -- and as a security feature, it turns the Bluetooth off so in a crowd no one can use your phone, or listen in on your conversations.
Setting your Bluetooth to accept only one device (being your headset) should allow you to work in the car next to your wife, but will also limit you on which headset you can use -- if you accidentally grab your wife's headset as you are out the door on your way to work, it will not function until you open the channel again. I am not even sure if every Bluetooth capable phone has a function to limit their connectivity, but if this issue is bothering you a lot it might be worth a look in your Bluetooth settings).
Just as a test, and because it sparked my curiosity, I recommend trying this:
Be out of range for your wife's headset and make a phone call on your headset to someone who is willing to hold on the line while you do this. Then, while you are connected with your Bluetooth to your friend, sit in your car with your wife and her phone and Bluetooth. The connection to the headset on your phone should be locked in place from the beginning of the phone call, and so it should not cut out when your wife's Bluetooth headset comes into range of your phone. While this conversation with your friend is still going on on your headset, have your wife make a call on her headset if she can. Because there is only one Bluetooth device available (since yours is in use) she should be able to make the connection with her phone, in spite of it being in proximity to yours. Finally ... hang up your phone, and have your wife do the same. With both phones inactive, try placing a call from the Bluetooth on one of the phones -- the system may set your headset as the default device for your phone, and your wife's would do the same, and the issue should be rectified.
I make no guarantees that this will work ... I am not all that familiar with the complexities of the Bluetooth wireless system and whether or not you can set the system this way, but it is worth a shot. The system may be designed to prevent this type of back door approach, but it would seem reasonable that it could work. Best of luck to you!
May 26, 2011 | Car Audio & Video
My bluetooth on my Razr doesn't work.
it is just because u have either turned off ur visibility to others so thats why u cant find them ...or the second cause can be that remove all the paired blutooth devices from ur phone ,,,may be it then start working ,,, thx
Jun 08, 2017 | Motorola Mobility Razor Behind-the-Head...
Unpairing bluetooth headset without mobile???
You may be having compatibility issue instead of what you suspect may be wrong with both your phone and the Bluetooth headset your friend gave you.
Well, there is no such thing as a Bluetooth headset being permanently locked in to a phone.
As long as there is an open 'visible' Bluetooth connection option and there are devices in range ready to pair, the process to pair starts.
Whenever there are incompatibility issues, pairing two devices using Bluetooth becomes a hassle.
Oct 11, 2017 | Nokia N76 Cellular Phone
Bluetooth not powering up
Try this ::
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life. 2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is sually provided by the Bluetooth device manufacturer, not the RAZR. Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
PLEASE DONT FORGET TO RATE THIS RESOLUTION.
Nov 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
NEED TO RESET
try pairing and entering the code 0000
Dec 27, 2007 | Motorola Mobility H300 Wireless Headset
I can't get my phone to connect with other peoples
I assume you are trying to connect to another phone via Bluetooth. It would help quite a bit to know what kind of phone you are trying to connect to, but here is what you need to have configured on your phone for Bluetooth file transfers:
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer, not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
4. You can now "Copy" media files to the phones nearby that you have connected to. Copy is an option while browsing through the files.
Dec 14, 2007 | Motorola Mobility RAZR V3
Can't connect with other peoples phone
Pairing a Jabra 250 headset with my new motorazr2
Here is what you need to have configured on your phone for Bluetooth connections:
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer (in the manual), not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
Motorola Mobility RAZR V3 Logo
50 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
