Question about GE DCVH515GF Gas Dryer
G.E. Dryer Model # DVBH512EFOWW Serial #DL800541A
I had a power surge and now my dryer is showing e61 and will do nothing when I push buttons. I have turned the breaker on and off and that will not reset it. Is there anything I can do to restart it without calling a repair service?
  • vagnoalves Oct 30, 2008
    E61
  • Anonymous Dec 03, 2008
    e61 code on ge dryer
  • 116 Answers
SOURCE: dryer internal breaker trips
If you are using dryer sheets in the machine the filter screen may be plugged and will have to be cleaned. You can check it by placing a bit of water on the screen if it beads and does not flow through then the screen is indeed plugged reducing air flow. There could be lint and build up in the dryer's internal ducting and sensors, the machine will have to be disassembled for a complete cleaning this will also reduce air flow and cause the machine to heat abnormally.
Posted on Mar 11, 2007
  • 67 Answers
SOURCE: GE Dryer error code E61
I cant remember what e61 stands for off the top of my head but if u unplug the dryer take the top off you should find the tech sheet in it and it will have a list of error codes and faults if u find that write back with what e61 means if im not mistaken and i might be off of memory i think it had something to do with the control board
Posted on Mar 22, 2007
Washer_tech
  • 164 Answers
SOURCE: Dryer won't Start
the problem might be the start switch itself. if the switch is going bad it could have either a carbon buildup on the contacs preventing it from starting (unlikely) or the contacs are wearing out and it is more hit or miss if it will start. as time goes on the problem will get wose
Posted on Nov 01, 2007
SOURCE: Whirlpool Electric Dryer Won't Start
Your dryer has a non-resettable "thermal safety fuse" part number 3392519 which stops the machine dead when the temperature near the heater gets too high. Typically a restricted vent system causes this so you definitely want to check that before replacing it. A failed control thermostat can also cause this so check the operating temp too.
Posted on Dec 30, 2007
  • 50 Answers
SOURCE: no power
check the door switch which will not let dryer run if it is not depressed. a lot of times the holder for the door switch breaks. look for switch bracket holder with door open depress button and see if you hear a click. probably switch holder is broke. remove with power shut off
Posted on Feb 06, 2009
Hi there my name is Larry from Mich ,I have a estate electric dryer model Tesco640po serial ms0808710 ,I had a power surge and the dryer quit working it does turn on but only stays on if I hold the start...
The key is "Power Surge" you have no idea what got burnt. I've never heard of the brand is it expensive. Might need to get a replacement.
May 20, 2014 | Dryers
Gas dryer will not start. Model MGDB850WR0 maytag bravo gas dryer serial MY3101043 purchased 2009. lights and display come on, push buttons give tones, but nothing happens when you push start. Display...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 08, 2011 | Maytag Dryers
I have a Whirlpool Dryer Electric Model #LER2614EWO Serial # MF2511530. When you push the button to turn it on it won't turn on. You set the timer for 30 minutes, push the button and nothing happens. Can...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Sep 13, 2010 | Whirlpool Dryers
GEW9878LW Electric Dryer: Whirpool Dryer - Model # GEW9878PWO - Serial # MS4...
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
May 18, 2010 | Whirlpool GEW9878LW Electric Dryer
Error E61 appears on digital screen. dryer does
I was told it was main computer board. Ours got the code when we had power surge.. Not sure how yours happen
Nov 17, 2009 | GE DCVH515GF Gas Dryer
My maytag neptune dryer has the start button flashing but when push it nothing happens. I unplugged it and it is stil flashing when plug back in.
Did you have any power surges latley? Sounds like the control board is faulty. I think this model has a control board in the top counsel. Hopefully this helps
Jul 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Push the start button and nothing happens - no noise nothing.
check both thermal fueses, door switch, power relay, timer contacts if good, replace motor, do you have 220 volts at plug
Jun 26, 2009 | Kenmore 62602 Electric Dryer
Dryer will not run
dryer starts sometimes if you hold in button. frigidaire gallery series model # GLEQ942CSO. serial # XD350164472. flat panel control board.
Mar 31, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Open Questions:
GE DCVH515GF Gas Dryer Logo
76 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
