Question about HP Photosmart C6180 All-In-One InkJet Printer
I need a new port
How can I add a new port to my printer (properties page) - I have an IP address of 192.168.0.4 but the only ports currently available are for my old router (192.168.2.2)
    Problem Solver:
  • 6 Answers
Even better.
Right click inside your Printer and Faxes folder and go to Server Properties ...then click on Ports....slecet the old port and then click configure port and then chnage the Ip address to the correct one and click apply
Posted on May 27, 2008
    Guru:
  • 79 Answers
1. Click Start menu, go to Printers and Faxes.
2. Right click on your printer driver icon and select Properties. Go to Ports tab. Click on Add Port.
3. Select Standard TCP/IP Port. Click New Port. Click Next.
4. Input the IP address of your printer. Click Next. (Port name ll be automatically updated)
5. Click OK. Click Next. Click Finish. Click Close. You will be back to the Ports tab.
6. Click on apply and try to print
Njoy :-)
Posted on May 25, 2008
    Genius:
  • 3,587 Answers
Remove old router software, and it should open that port..then start from the beginning on installation of new router, then connect your printer.
check your computers warranty here 4 FREE
Posted on Mar 16, 2008
Why does my hp envy 5535 stops in middle of print job
Please try following the steps below and let me know if that may help:
  1. Open the HP Envy 5535 software, then click the Printer Home Page (EWS) link.
  2. Click the Network tab.
  3. Click Networking , and then click Network Address (IP) .
  4. Click Manual IP , and then click Suggest a Manual IP Address . A manual IP address, Subnet Mask, and Default Gateway displays.
  5. Be sure to take a note of the IP address and Confirm the changes, then close the EWS page.
  6. From the HP Envy 5535 sotfware click the Utilities tab, then click on Update IP Address.
  7. Type the manually configured IP address, click on Save and confirm.
  8. Open the control panel and go to Devices and Printers.
  9. Right click the HP Envy 5535 icon and select Printer Properties.
  10. Open the Ports tab.
  11. Click teh Add Port button, select Standard TCP/IP and click on New Port.
  12. Follow the steps by typing the manually configured IP address and confirm the changes.
Read More... HP Printer Support
Thanks,
Jul 23, 2014 | HP ENVY 5535 E-ALL-IN-ONE PRINTER
How connect a tcp ip printer.
Hi Kumar,
You can modify or change port in the printer driver to connect it through LAN cable. Please notice whether you use static or dynamic ip address. Please follow below step.
In the following step we will modify your existing USB connection. Check it out!
Step:
  • Open printer driver list.
  • Right click on the printer drive name (e.g Canon IR2270).
  • Select Properties.
  • Click Ports tab.
  • Click Add Port, then select Standard TCP/IP Port.
  • Click New Port.
  • Click Next on add port wizard menu.
  • Type IP Address (for static ip setting) or Printer Name (DHCP), then click Next (computer will search the printer).
  • When the printer has been found, finish the wizard.
  • Close Add Port menu.
  • Now you have new port represented by IP Address or Printer Name (with checked box active) in port list .
  • Click Apply.
Bingo! Now your printer ready to print via LAN. Sometimes printing right after setting this new port not always succeed. Don't be panic. Restart both of printer and the computer.
Next time you want to connect the printer via USB port so you change port back to USB. Just simply check on the check box next to USB Port in port list and click apply. You may need to restart both printer and computer too :)
Have a nice day!
Printer Clinic
Jan 13, 2014 | Canon iR2270
Close ink cover
From Brother website/help
Click the Add Port... button.
Select the Standard TCP/IP Port option and click
New Port. The
Welcome to the Add Standard TCP/IP
Printer Wizard appears.
Click Next.
In the Printer Name or IP address area enter the node name
of the
Brother device as it is printed on the network configuration page.
An
example node name could be: "BRN_34FDAA".
As you enter the node name, the Port Name box will be
automatically updated.
Click the Next button.
Click the Finish button.
Click the Close button on the original Printer Ports
screen.
Click the Close button to return to the original properties
screen.
Click the Apply button and then the OK
button.
Now try to print a test page.
This worked great for me!
Nov 18, 2012 | Brother MFC255CW All-in-One InkJet Printer
How do I convert my C6180 all in one printer from offline to online status using a HP Pavillion dv9000?
Take out the Network Confirguration page from the printer.
To get the page.
Press the setup button.
Go to Network Setup>>>View Network Settings>>Network Configuration page. Press OK to get it printed.
Note down the IP address of the printer.
Then Go to The Printers folder under Control Panel.
Make right click on the printer icon and select Properties or printer properties in case of windows 7.
Go to Ports tab.
Click on Add a Port. Select Create a new port and select Standard TCP/IP
Enter the IP address that you have noted down from the Cofiguration Page.
And complete the Add a port wizard.
Then restart the printer.
. If you are using a DSL router, then enter Manual IP to the Printer.
Make sure it is different from the IP of other devices on network.
You must have default gateway, subnet mask information about the network.
To get the details.
Open Command Prompt on your computer from All Programs>>Accessories.
Enter ipconfig and press enter.
Then note down the IP address, default gateway and subnet mask.
To enter the manual IP to the printer, Press setup button. Go to Network Setup. Select Advance Settings>>>>IP Settings>>>manual IP.
Enter Ip address of priner as 192.168.001.023.
The default gateway must be 192.168.1.1, make sure that first 3 set of numbers are same. like 192.168.1, last 3 should be different from the computer's one.
Enter the same default gateway and same subnet mask
And after adding the manual IP, use ADD a Port option. Restart the printer and then check the status.
To make sure, make a right click on the printer icon and select Use Printer Online.
Apr 29, 2010 | HP Photosmart C6180 All-In-One InkJet...
My print server is working with a Epson DX4400. It is all setup correctly (according to Netgear) but when I print wirelessly, it only prints half the test page and then the printer stops with an error...
U need to manually add the Printer ports ..
Install the printer driver to the computer first and make sure that we are able to print directly. Follow the steps below after putting the printer and computer back to your network.
  1. Click on Start, then Control Panel, then Printers and Faxes. Right click on the Printer and select Properties.
  2. On the printer properties window, select Ports tab and click on Add Port.
  3. Select Standard TCP/IP Port and click on New Port
  4. This will bring the Add Standard TCP/IP Printer Port Wizard, click Next
  5. In the field for Printer Name or IP Address, type the IP address of the print server and click Next
  6. Select Custom and click Settings button
  7. Under Protocol field, select LPR. For Queue Name, type P1 depending on what print server port is the printer connected to.
  8. Click Ok, then Next, and Finish.
And this will resolve the issue
Feb 06, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
I get an error message saying the printer is offline. It is connected through a router wich is broadcasting fine.
Hi
To resolve the issue which says "Printer Offline" we need to Add a Port.
So I request you to perform below steps.
1. Print a network configuration page from the printer front panel.
A. Press the Setup button.
B. Press the arrow buttons to select Network and then press OK .
C. Press the arrow buttons to select Print Network Configuration Page and then press OK. The Network Configuration Page prints.
2. Note the IP address on the printer.
3. Please open the printers folder located in the control panel
4. Right click on the icon and select properties
5. Select ports tab and click on create new Port button.
6. Select the Ports tab, and then click Add Port. Select the standard TCP/IP Port and create a new port. Type the IP address of the Printer and proceed with the onscreen instructions.
Now try printing.
I am sure this will resolve the issue.
Thanks,
Roger
Oct 10, 2009 | HP Photosmart C6280 Printer
Canon mp620 not connecting to my wifi laptop
This could happen if the port that you are using is not the right one.
When you are using a printer wireless, you need to use the Standard TCP/IP port, to setup a printer port, do the following
Right click on printer icon, select properties
Click on Add port, select new port
Enter the IP address of the printer, this can be obtained by printing the settings page from the printer.
Note: please setup a static IP for your printer, else everytime you restart you may endup with a new IP
Let me know if this works,
Jul 29, 2009 | Canon PIXMA MP620 All-In-One InkJet...
Can't print from Quickbooks Pro 2008 to HP 6500 All in one
You can install Deskjet 990c drivers to print from Quick Books
We need IP address of printer for this.
Please perform following steps to get IP address of printer.
On printer press Setup >>>> select Network >>>> select View Network Settings >>>> select Print Network Configuration Page >>>> press OK >>>> this will print network configuration page >>>> note down the IP address of printer showing on this page
Now you need to install Deskjet 990c driver
On computer click Start >>>> Control Panel >>>> Printers or Printers and Faxes
Click "add a printer"
Select local printer (uncheck automatically detect my plug and play printer) click next
Select LPT-1 port and click next
select manufacturer as HP and printer as deskjet 990c and click next
make printer name as Deskjet 990c and click next
Use as default click next
Do not share click next
Select "no" to test page and click next
This will show a new icon of deskjet 990c in printers window.
Right click on Deskjet 990c >>>> click Properties >>>> click Ports
click "add a port"
select "standard tcp/ip port" and "new port"
type IP address of printer in the column of printer name
type IP_IP address of printer in column of port name
device type "generic network card"
Complete the process by clicking next/ok/finish
Try to print from quickbooks by using Deskjet 990c icon
Wish for all success..
Harpreet_351
Jul 15, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Take Off Sleep Mode
(same response posted in another thread)
The issue is NOT the sleep mode)/
My first solotution was to reinstall the printer as a new printer. But that is uncessary. The fix is as easy as changing the IP address the in Port.
The problem is the the IP address for your wirelss is not static. and when it changes, the printer does not recognize the new IP address. When this occurs. go the the printer folder ( in the control panel) and click on 'add new priter'. Then select 'add a network wirless printer . NO NEED TO INSTALL THE PRINTER...you just want to see the IP address.
Note the IP address.
GO to the printer, click on the right mouse and select 'properties'
Click on Port
You will see the current port already highlighted.
Click on ' configure port' and change the IP address under "printer name or IP address.
Click OK.
Problem solved
Good luck.
DeniseA
Feb 25, 2009 | Brother Multi-Function Center MFC-240C...
Printer online then offline
Click on Port
Click OK.
Problem solved
Good luck.
DeniseA
Mar 01, 2008 | Brother MFC 420CN All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
178 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
