Sony DVP-NS77H No outout
The player responds to all commands , and appears to be playing, but I can 't get output on either HDMI or standard hookup (red, white and yellow). I have done everything the manual recommends. I am trying to play into a Sony KDL-32S3000. via one of the HDMI inputs. All I get on the screen is "signal not supported". Have also tried it on an older TV set through the standard RCA plug hookup and get nothing.
  • shipmate Mar 16, 2008
    Thanks. I am going directly from the player to the TV. No AV receiver. Do I have to connect player through the cable box?
I had the same problem unitl I read the manual a little more carefully.
I found that ALL connections through my AV receiver had to be identical. I was using component connections with analog connections.
Since I switched to all HDMI connections (cable box to AV receiver, DVD to AV receiver and AV receiver to TV) all is fine.
Hope this helps.
Posted on Mar 16, 2008
Formats for dvp-ns70h
selectable 720p/1080i output via HDMI digital interface (separate adapter available for TVs with DVI input)
selectable progressive-scan mode for smoother video with HD-compatible TVs (via the component video output)
optical and coaxial digital outputs for Dolby Digital/DTS /PCM
  • 1 set of audio/video outputs (composite, S-video, 480i/480p component video, and HDMI)
  • plays DVD-Video discs, DVD-Rs & DVD-RWs, and DVD+Rs & DVD+RWs
  • plays CDs, CD-Rs & CD-RWs, and MP3 CDs
  • plays digital picture CDs (JPEG)
  • remote control (multibrand for TVs)
  • 108MHz/12-bit video DAC
  • 192kHz/24-bit audio DAC
Oct 14, 2012 | Sony DVP-NS70H DVD Player
Tray locked on sony dvp-ns77h dvd player
If the Sony DVP-NS77H DVD player displays "TRAY LOCKED" and you can't eject a disc or open the tray, try the following - First turn the unit off. Then, while holding down the eject, play and stop buttons simultaneously (on the front of the DVD player), turn the unit on with the '/O button (also on the front of the player). This released the locked tray for me.
Aug 18, 2011 | Sony DVP-NS77H/S DVD Player
Can a Sony DVP-NS710H work with a non-HDTV? I have an older TV model (2001) and need a new DVD player. I am looking at this Sony model and would like to purchase.
yes, you must have at your tv one of this plugs: Connector Type Sony DVP-NS710H 1 x Composite video output ( RCA phono ) - Rear , 1 x HDMI output ( 19 pin HDMI Type A ) - Rear , 1 x Component video output ( RCA phono x 3 ) - Rear , 1 x Audio line-out ( RCA phono x 2 ) - Rear , 1 x Digital audio output (coaxial) ( RCA phono ) - Rear on your tv the connector is input.
Feb 14, 2010 | Televison & Video
DVP-NS77H will not work
You need to make sure that you change the input on the TV. It is most likely AUX1 or video input 1. Look on you TV remote for a button that says "input" or "source". Make sure your DVD player is on, press press play, then hit the input or souce button on the remote.
Dec 23, 2008 | Sony DVP-NS57P
Hdmi output
There is a firmware update available from sony that appears to address this problem. Go to sony and do a search for the model number dvp-cx995v. I have not tried it myslft but the write seems to address your problem.
May 04, 2008 | Sony DVP-CX995V Multi-disc DVD Player
Malata DVP 892 hookup problems
I had the similar problem at first. You need to use another disc before you can configure the video output. Make sure you enable the HDMI output.
Apr 21, 2008 | Wanlida Group Wanlida/Malata Combination...
Sony DVP-CX995V will not play through the hdmi output
There is supposed to be a firmware fix for that from sony.
Feb 08, 2008 | Sony DVP-CX995V Multi-disc DVD Player
Televison & Video Logo
183 people viewed this question
Top Televison & Video Experts
Electro Med Services...
