Question about BenQ MP610 Multimedia Projector
Green light flashing and then shuts down
When I press power on the green light starts flashing for like 1 minute then it turns in to a flashing orange light for one more minute then the projector shuts down and the red light on LAP goes on and the projector restarts with the same process but without the red light going on,
I got a new lap but the same thing happens
What can I do to fix this problem??
Gary
  • smcgx4 Mar 13, 2009
    Start up problems SOMETIMES. I have less than 700 lamp hours but suddenly the unit wont start; when I press power it flashes green th elamp flickers faintly and then power light turns orange. After about a minute the lamp light comes on.
    Tried againa few days later and it worked fine again. The next day didn't work, a few days later worked again. So the lamps fine but Idon;t know what the problem is.
  • 563 Answers
Hi Gary
Have you resetted the lamp timer ? It must be done when a new lamp is inserted into the unit.
You can reset the lamp timer by holding the up arrow key on the Projector in until a online message appears. Then just follow the on-screen instructions.
If the problem persists , you will have to replace the Ballast wich is the lamp's power supply.
Posted on Mar 25, 2008
    New Friend:
Hi I just fixed that problem last night open the unit carefully there is a ribbon that connects the main board to the control buttons I removed the top and removed and reinstalled all of the connectors and removed and reinstalled the lamp turns on every time now no more problem :0)
Posted on Aug 23, 2013
My panasonic pt-521cx16 starts, green light flashes, then shuts itself off again
Have you even replaced the bulb / lamp on this TV - other than the green light - did they turn solid red / orange at any point? My initial thought is you need to replace the bulb.
Jan 22, 2018 | Panasonic PT-52LCX66 Projection Television
Orange light flashes 5 times then green flashes once then repeat Can't get printer to do anything else. Have unpluged it for ten minutes no luck Have removed print head and replaced it, no luck....
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.For printer
Mar 22, 2011 | Canon BubbleJet i560 InkJet Printer
Canon I850 won't print , it has a green light for about 2 seconds then flashes a yellow light for about 6 seconds
Hi there
This is only a try it may do it but I not know,
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i850)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
Jan 19, 2010 | Canon i850 InkJet Photo Printer
Light flashing green and yellow will not print
Hi this is only a try it may work
2. Release RESUME
0 presses - green - Test print (or exit service mode on i960)
Jan 14, 2010 | Canon i850 InkJet Photo Printer
The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
Operator Error Canon i850 printer
2. Release RESUME
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
Dec 09, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i950 flashing orange green orange green
2. Release RESUME
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i950)
Aug 22, 2008 | Canon i950 InkJet Photo Printer
Canon i950 will not reset counter for waste tank full.....
For Canon i850, i950, S600
2. release RESUME
3. press RESUME twice, then release POWER
Jun 04, 2008 | Canon I990 InkJet Photo Printer
Printer Problem
This was not the sollution for my pinter..
My Magneta is half full and my error led is also blinking 15 times
I found this service manual for the IP4200 but this methode also doen not solve my error led..
Is their someone who has the sollution for this strange error?
1) With the printer power turned off, while pressing
the Resume/Cancel button, press and hold the Power
button. (DO NOT release the buttons. The Power LED
lights in green to indicate that a function is
selectable.)
2) While holding the Power button, release the
resume/Cancel button. (DO NOT release the Power
button.)
3) While holding the Power button, press the
Resume/Cancel button 2 times, and then release both
the Power and Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the Alarm and
Power
LEDs light alternately, Alarm in orange and Power
in
green, starting with Alarm LED.)
4) When the Power LED lights in green, press the
Resume/Cancel button the specified number of
time(s)
setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is
not installed, the carriage returns and locks in the
home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
>>>>>>>>THIS ONE
4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
5 times Orange (Alarm) Destination settings After
entering the destination settings mode, press the
Resume/Cancel button the specified number of time(s)
to select the destination. For detail, see
"Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning
(Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used
in servicing.
15 times Orange (Alarm) Return to the menu selection
Time(s) LED indication Destination CD / DVD print
0 times Green (Power) No change of the destination
1 time Orange (Alarm) Japan Supported
2 times Green (Power) Korea Not supported
3 times Orange (Alarm) US Not supported
4 times Green (Power) Europe Supported
5 times Orange (Alarm) Australia Supported
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
BenQ MP610 Multimedia Projector Logo
1,514 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
