Question about Samsung Refrigerators
My samsung RS21DCSV isn't working after electric triped. I have lights but no temperature in fridge or freezer. On the digital display there is a very small line flashing but nothing else. please help!!
    New Friend:
Hi, i had this same problem, it was like it for days,started to think , S$$T i need a new fridge, then in a missery i lent against the fridge, and lent on the the buttons, it bleaped at me and it come back on, anyway , the buttons i held were the power freezer and pwer cool buttons together,, just hold them in , and walla!!!! shes alive lol
Posted on May 10, 2010
    Producer:
    Uploaded 30 video answers.
  • 117 Answers
Sounds like you have this fault ......
Posted on Sep 16, 2010
  • pellumb memoci Oct 07, 2019
    I have the same problem how i can fix? Healp me please
SOURCE:
The temp says 14 and 8 but should be -21 and 3? Can anyone help
Controlling the Freezer temperature
The freezer temperature can be set between -14°C (8°F) and -25?C (-14°F) to suit your particular needs. Press the freezer button repeatedly until the desired temperature is shown in the temperature display. Keep in mind that foods like ice cream may melt at -16?C (4°F). The temperature display will move sequentially from -14°C (8°F) and -25?C (-14°F). When the display reaches -14?C (8°F), it will begin again at -25?C (-14°F). Five seconds after the new temperature is set the display will again show the actual current
freezer temperature. However, this number will change as the Freezer adjusts to the new temperature. The top and bottom guards in the freezer of this model are the two star sections, so the
temperature in two star sections are slightly higher than other freezer compartment.
Controlling the Fridge temperature
The refrigerator temperature can be set between 7?C (45°F) and 1?C (34°F) to suit your particular needs. Press the fridge button repeatedly until the desired temperature is shown in the
temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the fridge button to set your desired temperature. After a few seconds, the Fridge will
begin tracking towards the newly set temperature. This will be reflected in the digital display. The temperature of the freezer or the refrigerator may rise from opening the doors too frequently, or if a large amount of warm or hot food is placed in either side. This may cause the digital display to blink. Once the freezer and refrigerator return to their normal set temperatures the blinking will stop.
If the blinking continues, you may need to "reset" the refrigerator. Try unplugging the appliance, wait about 10 minutes and then plug back in.
The refrigerator does not work at all or it does not chill sufficiently.
• Check that the power plug is properly connected.
• Is the temperature control on the display panel set to the correct
temperature? Try setting it to a lower temperature.
• Is the refrigerator in direct sunlight or located too near a heat source?
• Is the back of the refrigerator too close to the wall and therefore keeping air from circulating?
Dado
Jul 19, 2015 | Samsung RSA1UTMG American-Style Manhattan...
Samsung fridge freezer SR2028CVW not cooling or freezing
If you have used it since 2004, it probably is worn out.
May 02, 2017 | Samsung Refrigerators
I dont now how to set temperature for samsung rsh1nhmh . All the light in the house vent off and the plugs . Now on the frige screen is only a flashing light. Nothing else
The refrigerator temperature can be set between 7?C (46°F) and 1?C (34°F) to suit your particular needs. Press the Fridge button repeatedly until the desired temperature is shown in the temperature display. The temperature control process for the Fridge works just like the Freezer process. Press the Fridge button to set your desired temperature. After a few seconds, the Fridge will begin tracking towards the newly set temperature. This will be reflected in the digital display.
http://safemanuals.com/314159.php?k=2f8f21dfdc6e62cb4825d07d38bad88d&ID=471000&q=SAMSUNG%20RSH1NHMH
Nov 18, 2010 | Samsung Refrigerators
My samsung american style fridge freezer RS21DCSV will not re-start after the power was off the light comes on but the control panel will not work
you may need to just unplug this unit for 5-10 mins
for some reason samsungs have a way of getting lost in the program, usually hapens durring a powersurge or power draw, of whatever kind,,,,
anyway sometime this "repair" will clear the eprom and you should be all set....
Oct 27, 2009 | Samsung RS2578BB Side by Side Refrigerator
Samsung side-by-side fridge freezer model RS21DCSV. Freezer is fine. Temperature keeps changing in fridge varying from 5-14 degrees and water has stopped coming out of dispenser. Have checked and...
these side by sides use an auger motor in the fridge to open and close according to the temp demand. If its eratic, either the auger is icing up at the outlet possibly due to product being to close to the outlet. On occation i have had to replace them due to being faulty.(to check, adjust the temp. and notice if there is any change on the auger.)
Sep 17, 2009 | Samsung RS2556 Side by Side Refrigerator
Water dipenser
The instruction book suggests this could be because the freezer temperature is set too low. Mine is set at -20C. It says the water line can freeze stopping water flow. Try reducing the temperature.
Sep 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung twin cooling fridge/freezer model Rs21dcsv Fridge temp control led display digit flashing and fridge not at right tempreture
My husband removed the covers inside the fridge which contain the lights and the cooling fan. The problem was the icing up of the cooling fan (which circulates the cold air) preventing it from rotating also the drain hole at the bottom of the fan was also iced up.
The fridge was switched off at the wall socket whilst working on it. After removing the panel containing the fan and unplugging the connection take the panel outside. A hair dryer was used to thaw out the ice. The drain hole was made slightly bigger to hopefully prevent this happening again.
When panel is screwed back in fridge make sure the black sealing tape is in position also take care not to damage cooling pipes which are attached to the evaporator unit. Defrosting a couple of times a year might prevent this happening again. It seems to be a design problem which im sure the makers will be aware of and modify future appliances. Q Will the makers repair this problem free of charge even if the warranty has expired !?
Jul 31, 2008 | Refrigerators
Refrigerators Logo
934 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
