The SV266A has a VIA Rhine network chip and you can find the drivers at http://www.viaarena.com
You need to give a few more details in order for me to assist you properly. With the details you've given I can give you some suggestions for solving the problem:
#1 - Ensure your network drivers are installed. If not either install from your cd (if it supports vista) or you will need to download the new drivers from syntax.
#2 - If you are getting a "network is unplugged" or similar message then the problem lies in your network cable or hub/switch.
#3 - If your ethernet shows as being connected but you cannot see internet or other pcs you need to look at your network settings, particularly IP Address and make it match your current network's settings.
