Question about Texas Instruments TI-83 Plus Calculator
TI-83 Plus silver edition won't turn on.
My daughter's calculator is not turning on. The message "low battery please replace" did appear, but we didn't replace the batteries until maybe a month later. We've changed the AAA batteries and the backup Lithium battery and still the calculator won't respond. Is there anyway to fix this problem? Thanks!
  • 2 more comments
  • Anonymous Mar 17, 2008
    won't come with new batteries
  • pip247 Apr 01, 2008
    My TI-83 Plus Silver Edition wouldn't turn on properly either. The batteries are good. I got a black screen out of the blue for the first time last week. Actually it wasn't totally black. It was mottled. And when I held it at an angle I could actually see some of the menu items when I pressed "2nd +" except there was also gobbledygook, pixel art and the menu seemed to be all mixed up. So I tried to reset it following some advice I saw on a website to no avail. What I did to it was take out the batteries, including the Lithium, let it sit overnight, then put the batteries back in while holding down the clear key and then continuing to hold the CLEAR key when I pushed the ON key. For an hour or so I got nothing. Seemed like there just was no juice. And after a while I pressed ON again and it suddenly went back to the black screen or a rapidly flashing screen. BTW I also tried the reset procedure (taking out the batteries, waiting, and then putting back in the batteries,) with the DEL key held and then pushing the ON button. No better for me. But you may want to try this.
    My experience indicates that the calculator needs to charge up to operate once you put in batteries. So you may just need to be patient after putting in batteries and come back and try to turn it on later. Of course make sure it's not the screen being too dim: use 2nd up-arrow repeatedly.
    On the other hand, I wasn't successful in my attempts so maybe this is all a waste of time. Maybe these problems are beyond repair. But if there are ideas I'd like to know!
  • longs Apr 04, 2008
    I have the same problem has this person does. I was using my calculator a while ago and it told me low battery so recently i changed them out with brand new ones and not it wont turn on at all. Can you please tell me how to fix this problem.
  • cyndyj Dec 02, 2008
    TI 83 with new batteries in it won't power up at all. Tried to turn on and hold down the up arrow after pushing 2nd... no luck.
  • 3,037 Answers
The screen may be at the lowest dim setting, try turning it on, then pressing the 2nd key and then hold the up key and see if anything appears, if not let me know and I will try to figure out something else, I own a 83, 84, and 89 so it shouldn't be too hard to figure out
Posted on Mar 23, 2008
3 Suggested Answers
  • 102366 Answers
SOURCE: Do i need both the back up lithium battery and the
The calculator can work with just the AAA batteries. But, without the backup battery, you'll lose all the contents of memory when the AAAs die. The backup battery is intended to keep the contents refreshed while you replace the AAAs.
Posted on Feb 06, 2010
doron_c21
  • 387 Answers
SOURCE: ti 83 plus calculator -
Hi
try to clean the ram
Mode Alpha S - enter enter
let it run for a while this will clear the ram
if it will not help it could be a problem with the Driver of the Screen its an Hardware Problem
let me know if you want to fix the problem
ecrdn@yahoo.com
Jack
Posted on Dec 25, 2010
My ti 83 will turn on when i press the clear thing but when i try to put something in nothing happens
Hi imagenius1,
You need to free up some memory. Try clearing your RAM memory. Your calculator should operate properly afterward.
Press [2nd] [MEM] [7] [1] [2]
If the steps above did not reset the memory to your Ti 83 family calculator try the procedures below.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1).
  1. Try a new set of AAA batteries.
  2. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message.
  1. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  2. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
  3. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
  4. If the above process did not reset your calculator. Try re-doing (Procedure 1) and, extend the time in step 4, by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
(Procedure 2).
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
  2. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
Jan 06, 2011 | Texas Instruments TI-83 Plus Calculator
My ti 83 calculator turns on but nothing shows
TI calculators have an annoying habit of dimming the screen, especially when the batteries are changed, so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
May 20, 2010 | Texas Instruments TI-83 Plus Silver...
Every time I turn on the calculator, it gives me this message: Waiting... Please install operating system now after a while, the screen changes to: ERROR! Press any key to turn unit off. Then turn unit...
Read the following from the TI knowledge Base. Hope it helps
Reinstalling the OS fot the TI84Plus
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating the operating system on a calculator with low batteries. Users will need to use the TI Connectivity cable and the TI Connect to send the operating system to the calculator. Make sure to have the latest version of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
Oct 28, 2009 | Texas Instruments TI-84 Plus Silver...
My TI-84 Plus Silver edition will not turn on. I have tried new batteries and everything, but it just does not turn on. Is there a way to reset it or something although the calculator does not turn on?
Here it is from the horse's mouth (TI Knowledge base)
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a lossof applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed bypressing and releasing the up arrow; repeat as necessary. To adjust orlighten the display, use the down arrow.
  3. Remove one of theAAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. Thecalculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83-family or Ti84 Plus family to reinstall the calculator operating system (see below.)
  5. Removeall of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn thecalculator on. Adjust the contrast if necessary.
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating theoperating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect software to send theoperating system to the calculator. Make sure to have the latestversion of TI Connect installed on the computer.
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
Hope it helps.
Oct 21, 2009 | Texas Instruments TI-84 Plus Silver...
TI 84 won't turn on. New batteries installed. TI Connect recognizes device and I installed new OS. Brightness is not the issue. Any suggestions? This is one of student's calculators. Thank you.
Sorry, answer was posted as a clarification request.
  4. Removeone of the AAA batteries. Press and hold the [DEL] key. While holding[DEL], reinsert the AAA battery and then turn the calculator on. Thecalculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system (see below.)
Hope it helps.
Oct 19, 2009 | Texas Instruments TI-84 Plus Silver...
Ti-83 plus silver edition. calc won't turn on.
Well, if screen shows the RAM CLEARED message, that means your calculator is working. Just press the [CLEAR] key, message will be erased and you are ready to crunch numbers.
Hope it helps.
Oct 09, 2009 | Texas Instruments TI-83 Plus Silver...
TI-83 Plus Silver Edition problem
These instructions are from education.ti.org, and worked for me.
1) Take out one of the AAA batteries
2) Hold down the CLEAR button
3) Put the AAA battery back in while still holding down the CLEAR button
4) Let go of the CLEAR button and turn the calculator ON
5) Press CLEAR to get rid of the error message.
Then you should be good! All the applications on my calculator were still intact, so despite the error message, the RAM was never actually cleared.
Oct 20, 2008 | Texas Instruments TI-83 Plus Calculator
Use a paperclip (tiny hole on back of caculator) and reset.
JC
Sep 16, 2008 | Texas Instruments Office Equipment &...
TI-83 silver edition programs lost
You need to reinstall the OS software, you will need a cable and download it off of the website
May 11, 2008 | Texas Instruments TI-83 Plus Silver...
No Power
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
Sep 04, 2007 | Texas Instruments TI-83 Plus Silver...
Texas Instruments TI-83 Plus Calculator Logo
589 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
