Question about Samsung SC-D353 Mini DV Digital Camcorder
No display I have a display in the few finder but no display on the LED screen. The screen is white with fine vertical stripes . Can you please help me. Thank you .
    President:
  • 4,402 Answers
Push the "EASY Q" button. After a few minutes it popped up and started working again. Problem is, after 5 minutes it went to black again
surgery that it had a bad CCD and possibly the CCD control board. In any case you can find both at tigerdirect.partsearch.com with part# AD97-08366A. This is the CCD and Board assembly and is around $56.00. If you think that you might just need the Control Board then its part# is AD97-08367A and is around $19.00. In any case neither operation requires any soldering as the ribbon cables just unclip from their sockets. *Before proceeding with this surgery make sure that you take note to where all the screws you remove go back. Also be sure to remove all screws completely.
Step 1 (Front Cover Removal): Remove battery then remove top silver screw just in front of the "nite pix" switch. Then lift the DVI cover to locate and remove the second silver screw. Then, with the camera lens and light facing you roll the front cover to the right(it can only really roll one way) while pulling the front cover at the same time. Its held in by a clip. When its free disconnect the light connector if it hasn't already come off during the front cover removal.
Step 2 (Splitting the Case): Remove five(5) silver screws from the bottom. If you count them there are a total of eight(8) so remove all EXCEPT the one screw at the tripod boss AND the two screws on the tape door. Next, proceed to remove the two black screws located in the battery tray in the back. Then flip the camera so you are looking at the hand strap, DVI cover, etc... Locate the two black screws by the "Slow Shutter" switch and remove. Next, flip up the eye piece and remove only the right screw. *Be sure to remove this screw completely because it is held in place by a threaded stud plate and it could fall out and bounce into that other dimension where all important little things go. The case should now be ready to split. Gently work the case in two and pay attention to the ribbon cables as you separate the two halves.
Step 3 (CCD and Board removal) The CCD and Control Board are removed as one unit. Remove all ribbon cables attached to the board. If the ribbon cable socket has a long brown bar across the top flip it up and remove the cable. If it has two brown buttons on the left and right of it then pull each button out and remove cable. *Take note to the orientation of the cable in the socket ie up or down. Unplug any remaining power wire sockets on the board. The board itself is held in by two(2) screws. Locate and remove these screws and lift the CCD and Control Board Unit out.
CONGRADULATIONS !
For installation, read these instructions backwards.
good luck
please mark the post with a fixya
Posted on Mar 17, 2008
Black Vertical Stripe Our Hitachi plasma TV has just started displaying a vertical black stripe about three inches wide right down the middle of the screen. This stripe comes and goes every hour or so,...
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Feb 03, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
NP50 has white vertical stripe down left side of screen
Display is faulty, I would say. Prove it with an external screen.
Mar 06, 2014 | NEC Office Equipment & Supplies
Display issues
no photo posted, of bad screen, why? why make help blind?
the display LCD is bad.
or is the 2008 , solderballs Nvidia chip failure.
if the screen fails in BIOS (press f10 or ESC to enter setup
an fails under boot CD linux or any kind the screen is bad
test with big battery out, always. run on AC power only to test.
do the funny LINES change if you gently twist screen case?
i see reviews on this LT back to 2009
the vista review page on its support pages is stamped 2008
oops !
the BIOS screens are here. hit ESC then F10
dv7-1245dx
this is called hp setup, its BIOS.
if these screens look bad, bingo for bad screen LCD or the GPU.
http://h10032.www1.hp.com/ctg/Manual/c01662442
Jan 01, 2018 | HP Pavilion dv7-1245dx Notebook
Hi, my motorola slvr l7 has felt on the floor. Since that it has one third (in vertical) of the display just full of thiny stripes (white and grey).. the rest of it still produce the different immages, but...
For fixing this problem you need to replace the LCD of your Moto. Buy the new LCD and get an T6 screwdriver, as for Nokia screws. This is not very difficulty to replace.
May 25, 2011 | Motorola Mobility SLVR L7 Cellular Phone
Zenith P42W34P Plasma Display Panel
Hello, My name is Dave and I can help you fix your Plasma TV. Do you have Black vertical 1.5 inch line or lines on your screen that come and go? Then give me a call. Please feel free to give me a call @ 1-503-432-9904 or message me at pleasefixitdave@yahoo.com
Thank you!
Dave,
Nov 20, 2008 | Akai PDP-4247 Television
ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
Samsung Digital Cam SCD6040 sound problem
I HAVE A SAMSUNG MINI DV DIGITAL CAMCORDER MODEL SC-D353 NTSC.
THE LCD SCREEN IS NOT DISPLAYING. ONLY A WHITE SCREEN WITH VERTICAL STRIPES.
NO PICTURE DISPLAY IN 'CAMERA' MODE OR 'PLAYER' MODE. BUT THE VIEW FINDER IS WORKING.
DO NOT KNOW WHAT IS THE PROBLEM?
HAS LCD SCREEN GONE BAD. IF SO WHO DO I CONTACT. I LIVE IN SILVER SPRING MARYLAND USA
PLEASE HELP
LAKSHMI SHYAMSUNDER
EMAIL: lshyamsunder @ yahoo.com
Tel # 301-649-1371
Sep 07, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Samsung SC-D353 Mini DV Digital Camcorder Logo
139 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
