Question about Motorola Mobility RAZR V3x Cellular Phone
How do I change the settings for Speed Dial #1?
I'd like to use Speed Dial #1 to retrieve my voice mail messages on my work phone which obviously is not my cell phone, but I have not been able to find a way to do that . . . is it possible?
  • 24 Answers
Speed is is 5hit
Posted on Mar 25, 2008
SOURCE:
Voicemail number changed on samsung galaxy and can not check voicemail now
Voice mails are set up from the phone company. Your phone has no control over the voice mailing service other than assigning a speed dial to it. You should call your phone company on their customer service number and they will tell your the number to call for setting up your voice mail box.
Mar 11, 2014 | Cell Phones
My voicemail has been set up, but it will not answer calls.. it rings and then rolls back into the main message for the office
Set your Call Forward Busy/No Answer to go to voice mail ext. as follows: Lift the handset, dial 4 then 3 followed by the voice mail ext. (the number you dial to retrieve voicemail messages). Hang up.
Jul 26, 2011 | NEC Electra Elite 32D-1 Corded Phone
NEED TO SET UP MY VOICE MAIL
Hi,If your account is enabled for voice mail, you can receive voice messages in your Inbox and also in a text message on your mobile phone. Both the message in your Inbox and the text message will include a preview of the voice message in text.
How do I set up voice mail?
1. Go to https://outlook.com to sign in to your mailbox, go to Options > Voice Mail tab, and then click Set Up Now.
2. When you set up your voice mail:
* You'll register your mobile phone number.
* Text messaging is set up. You can choose to be notified in a text message that you have voice mail or have missed a call.
* Call forwarding is set up so that your mobile provider forwards calls you receive to your voice mail. So if you don't answer your phone, your phone is busy, or you're unreachable or unavailable, the caller will be sent to your voice mail. After your personal greeting is played, the caller can leave a voice message for you.
* You can test whether your voice mail has been set up correctly by dialing your mobile phone number from your mobile phone. This verifies that call forwarding is correctly set up with your mobile provider.
How do I change my voice mail after I've set it up?
After you've finished setting up voice mail, you may want to:
* Change the mobile provider's voice mail number so you can use the key your provider has reserved for accessing voice mail to access your voice mail. For details about how to do this, see Changing the Number You Call to Access Your Voice Mail.
* Create a contact on your mobile phone. For details about how to do this, see Create a Contact for Voice Mail.
* Assign a speed dial key to the contact you create for Outlook Web App voice mail. For details about how to do this, see Set Up Speed Dialing for Voice Mail.
What else do I need to know?
* The voice mail service is available only to certain customers in certain regions. If you can use voice mail, you'll see a welcome message in your Inbox telling you how to set up voice mail for your account.
Thanks for using fixya...
Jan 20, 2011 | Cell Phones
Using speed dial with an LG Neon
if you already have contacts in your phone book and you have follow the set up info given...its just like retrieving your voice mail you normally would press the number "1" key...lets give it a test run press the number 5 key down for a second or two and release...it should be dialing whoever is in the the #5 spot...you just place your first speed dial....try it again lets call that number 9 ...note you can always change the positions (callers) in your speed dial..just simply go to the phone book to who you want to replace (eg.you want replace Debbie #4, go to Sam... options/speed dial/ #4 this will over ride who is in that position)
Jul 03, 2010 | LG Cell Phones
Why can"t retrieve my voice mails?
Is voice Mailbox setup? Have you enabled voice messages in menu. Should be able to press and hold 1 to connect to your voice mailbox...that phone number is automatically programmed on speed dial, key 1
Mar 02, 2010 | Nokia 2610 Cellular Phone
Can't retrieve voice-mail?
Most voice mail services require you to dial your own # to retrieve VM. Mine does not require me to use my area code. Yours may or may not (depending on your service provider). You may need a passcode to get into it the first time (maybe not). Your passcode will either be - the last four digits of your SS# or a four digit passcode that will be listed on your monthly bill. However, once you are in you can change your preferences. You can even set it so that you don't need a passcode at all when calling from that #. Only problem with setting it that way is you can't check your messages when calling from any other #.
Hope this info was helpful. Good Luck!
Jan 29, 2010 | Vtech CS5111-2 Twin Phone
Setting up voicemail on sch-u340 phone..cannot read buttons on manual to set up..
Check out this link below to download a PDF manual, software, and more for your phone. Just copy and paste into your browser.
http://www.samsung.com/us/consumer/mobile/mobile-phones/more-carriers/SCH-U340ZBAUSC/index.idx?pagetype=prd_detail&tab=support
Setting Up Your Voice Mail from page 10 in your manual:
Voice mail allows callers to leave voice messages, which can be retrieved any time.
Note: Once your voice mail account has been set up, you can use the Voice Mail folder (under the Message menu) to view details of voice messages in your voice mail box.
1. In idle mode, press and hold the key or dial your own mobile number
to dial voice mail.
2. Follow the prompts in the new user tutorial to setup your mail box.
Listen to voice mail
to dial voice mail. After connecting, you will hear your voice greeting.
2. Interrupt your greeting by pressing .
3. You are then prompted to enter your password.
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Oct 16, 2009 | Samsung SCH-u340 Cellular Phone
I cannot retrive my voice mail messages from my sciphone i68+
If you have voice mail on a land line as opposed to your cellular phone, you shouldn't have an icon on your cellular phone to retrieve any but the voice mail on your cellular account. If there is a special phone number that you call to retrieve your land line voice mail, then dial it, and enter whatever codes are required to retrieve your land line voice mail.
Apr 25, 2009 | Dual Electronics CECT P168 Cellular Phone
Vu 204..new phone, speed dial does not work, goes to verizon wireless message which says call cannot be completed as dialed. Checked numbers they are OK, also happens which #1 for speed dial of *86 which...
I had the same problem and found that the speed dial feature in "settings" is not turned on by default even though voice mail number is pre-programed into the speed speed list. Go to "Settings & Tools/Call Settings/One Touch Dial" and turn the option on.
Cheers,
Don Devine
Mar 30, 2009 | Motorola Mobility VU204 Cell Phone
Wrong Voice Mail number programmed into Speed Dial "1" Key
You can not remove it; But you can change it
Follow the steps :-
>Menu
 >Messaging
   >Voice Messages
     >Voice Mailbox NO.(CHange it)
Sep 06, 2008 | Nokia 3110 Cellular Phone
Motorola Mobility RAZR V3x Cellular Phone Logo
129 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
