Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Ir devices is there any kind of light which would trigger a ir beak beam sensor if so what kind of light thanks
  • timothb Mar 17, 2008
    sorry i meant to write break beam sensor and could it be triggered with light instead of a solid object
  • 1,512 Answers
Infra red light is present all about us. It is generated by most types pf artificial lighting, and also by the sun. If yo have an infra red beam that is misfiring, it probably relates to some reflected light from a fast moving source that is triggering your beam. Hope this helps, not really sure what a beak beam is... guessed it was a typo. Give me a bit more about your problem if i ahve not helped thus far
regards
Graeme
Posted on Mar 17, 2008
  • Graeme Ross
    Graeme Ross Mar 21, 2008
    No, the beam must be interrupted by a solid object that blocks it from reaching the sensor. In saying that,they are not infallible, and sometimes, particularly high levels of reflected light like the afternoon sun bouncing off a passing car may trigger the sensor also by overloading it temporarily. You can often adjust this out with a sensitivity adjustment on the sensor. Good luck, hope this information has helped. Feel free to ask more questions if you wish.
    regards
    Graeme
Why does my garage door close and then go back up?
This will happen if the IR sensor are sensing an obstruction while the door is closing OR if the IR sensors are defective. As a first option, check to see if any object is stuck to the door (possibly low down) that is triggering the IR sensor.
Hope this is helpful, if it was please click the 'Helpful' button below. Good luck
Mar 09, 2016 | liftmaster Lift Master 377LM 376LM 315 MHz...
Canon ir 2570 error code 7356
The printer knows if it needs paper by a sensor. Usually this is is a light beam across the paper supply. Both ends, the light and the sensor can get covered in dust and may need to be cleaned
Apr 27, 2014 | Office Equipment & Supplies
How to replace an ir sensor in a phillips tv model 52pfl3603d/f7
IR sensors are tough devices firts make sure that your remote control is working view its ir led light using your phone camera you should see it flashing..another test is puting it near an AM radio ,you will hear an interference when you push any key. then the crystal is all right.Replacing the IR sensor means you really have to unsolder it from the circuit board and fing a replacement..I hope its just one of those cold solder ang not the IR sensor..Good luck.
Dec 19, 2012 | Televison & Video
Westinghouse tv turns off with rmote but cannot be turned on unless button on tv itself is used
How old are the batteries in the remotes? The on/off signal from the remote is the same. There is some lattitude in the IR reciever module for what it accepts. Low battereis may be shifting the signal's frequency or light intensity enough for it to not be recognized.
If sunlight is failing on the sensor or the remote's IR emitter, that can cause interference. Other IR devices can also interfere with the IR signal such as a "Remote Extender" being used for something else.
It may sound odd, but if your remote was working one day and not the next- was the room rearranged? If so, look around for possible sources of interference blocking the beam from the remote, or shining or reflecting light onto the IR reciever module in the set.
Dec 30, 2011 | Westinghouse Televison & Video
My Channel Plus 3445 has quit sending IR remote control signals to remote equipment. I have tried a new IR emitter. No luck. How can I troubleshoot the system or emitter?
Presumably you'd open up the remote and test it with a volt/ohm meter, but you'll need the device's schematic for that.
A quick way to ensure the remote is working: Look through the viewfinder of a camcorder while it is aimed at the remote'd emitter. You'll be able to view the IR beam to ensure that all buttons work -- and to an extent you can view the beam's strength.
Nov 23, 2011 | Channel Plus Televison & Video
Check track light and abs light came on
you need a new wheel sensor, the device that tells your beaks that your car is slipping. it will cost about 300, take the car to midas, and ask them to check your wheel sensors.
Oct 24, 2009 | 1999 Lincoln Town Car
Installed a new ink cartridge and the display mentions cover open when it is closed.
never let a machine defeat you
there's a sensor in the printer that checks ink levels. the sensor uses a beam of light to check; if the light bounces back, the machine assumes there is ink in the cart and continues to operate. If the light is not bounced back, the machine assumes that the cart is empty and starts beeping or displaying an error message. on a refill the ink is not "packed in" like it is on a new factory one. so take black electrical tape and tape it around the spine and the outline of the cartridge to make it ALL BLACK with no transparencies, which causes the light to beam back (sensor then triggers error message)
tricking the machine into thinking the cartridge is full defeats it.
Apr 18, 2009 | Lexmark X3470 All-In-One InkJet Printer
Beam
Reset both devices and make sure the IR ports are alinged together so that they are in direct contact with eatchother.
The IR should work 0-10 meters id suggest 20cents from eatchother.
Mar 17, 2008 | Palm Treo 755p Smartphone
Remote won't work
you can build a ir sensore box find parts at radioshack or you could open your remote clean contacs with mild soap and water nothing else and do not use any thing that may scratch then check to see if your (leds) light emiting diodes are broken of the pc board
Feb 06, 2007 | Toshiba MV19N2 19 in. TV/VCR Combo
Hx 2415 Beam receive and transmit
No, you won't see an indicator light. make sure that the IR ports are pointed at each other - they are in different places on different Ipaqs.
Sep 08, 2005 | HP iPAQ HX2415 Pocket PC
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
64 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
