Question about HP Compaq Presario V2000 Notebook
Line in center of screen
There is a thin white line in the center of my screen. How do I get rid of it?
    Sergeant:
    Champion:
  • 256 Answers
Hi
You need to replace it, problem with the screen. (http://www.pchub.com/uph/)
Thanks
Posted on Mar 16, 2008
    Genius:
  • 3,587 Answers
6ya staff
SOURCE:
I have a thin, red, vertical line in the center of my 50" 1080p 60Hz LED HDTV. How can I get rid of it?
Check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 24, 2015 | Televison & Video
Thin white line on right side of tv intermittent
The only easy hope here is centering is off just slightly to the left and the line etc will show on certain scenes and or channels.
Not sure if this set has a centering in customer menu or maybe in the tech menu---a call to sharp might answer this for you.
Aug 28, 2012 | Sharp LC-32SB24U 32 in. LCD TV
How do i get rid of a dark thin line going across my lap top ???
That cannot be repaired as the screen on your notebook has layers and between those layers gas is compressed within thin columns. In your case your screen got a minute leak in one of the columns and now that column is unable to produce image. Hence, It can't be repaired. You have to change the entire screen.
May 20, 2010 | Compaq Presario M2000 Notebook
Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
Jun 01, 2009 | Televison & Video
Thin white line
I think you have a power supply problem and that one of the supply lines is down it will need a technician to solve this problem.
SUPER8
Jan 02, 2009 | Philips Magnavox 27MS343S 27" TV
Help with my acer peace of s___
Looks like a faulty screen as other guy said in other post :(
Dec 13, 2007 | Acer Aspire 3100-1405 Notebook
Thin white line (hoz) across screen (gets on my freaking nerves) this is after i bought it DOA and had to use mini PE to get hard drive to work and then loaded VISTA 5 times and finly it loaded without a...
A Few things you can try,
Updateing Graphics Drivers, Check Connections, Adjust resolution and refresh rate, Connect to another monitor to rule out GPU and Software issues.
Thin horizonal line in middle on dark screen
The several thin white lines at the top of the screen is the warning that the vertical output IC is not getting the boost voltage it needs to run correctly. The IC cannot operate for long like that and shorts out inside, which is when the vertical collapses altogether and you get the thin white line through the center of the screen. The good news for your son is that he had nothing to do with that, and it has nothing to do with the cable F connector. The set needs to be serviced by an experienced tech who will restore the boost supply and replace the vertical output IC, and when I do that I charge $75 but techs in your area will vary, so be sure to ask around.
Jul 26, 2007 | GE 24GP653 24" TV
HP Compaq Presario V2000 Notebook Logo
62 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
