Question about Minolta EP1030/1030F CS/PRO Copier
F3 error Please, how i will resolve tthis problem. My copier show F3 and stop to copy
  • 3 Answers
There should be any cover oppen close care fully or check your door sensors Than reset your machine
vip_umer4u@yahoo.com +966 557695755
Posted on Oct 24, 2008
How to resolve error 5 in printer canon pixma mp198
Please follow the below mentioned steps to Reset Canon Pixma MPC190 Printers.
1.Enter the service mode SERVICE MODE - pressing buttons Menu, Copy, Scan, Copy, Copy
2.Choose TEST MODE.
3.Select 8 PRINTER TEST TEST MODE.
4.Choose 3, EEPROM CLEAR
5.Select 0, INK COUNT
6.Press the Set button.
7.Click Stop / Reset button (return to item 3), and again press the ON / OFF
This should resolve the problem. For any further assistance please reply back.
Apr 17, 2011 | Office Equipment & Supplies
I have purchased machine Aficio 410C. Ones the main power is on it shows error SC542. It should not be solved. Once we clear the error code also. After few seconds it shows same error. Please help us.
Press the keys in this order.
Press Clear all, ( yellow button) then 107, then press and hold the red stop button until the screen changes and displays COPY SP, etc. Press the COPY SP box, once the screen changes again, shut the machine off, then back on. That should reset the code.
If it continues to come up, you will need to replace the hot roll thermistors.
But if it hasnt been used in a while that SP reset should resolve it.
Let me know if this helps please.
Feb 02, 2011 | Ricoh Aficio 1035 Copier
When tryingt to turn oven on it beeps and shows F3? andoven won't turn on .Not sure of model, But stove is at least * years old.
Hi
Thanks for using FixYa. Error F3 in your range/oven indicates oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks Rylee
Oct 26, 2010 | Frigidaire FGFB75D Gas Kitchen Range
Whirlpool electric range timer constantly beeps and displays E2-F3 I don't even use the oven I just want beeping to stop I press STOP which changes display back to clock, but soon it returns to E2-F3...
Hi
Error F3-E2 in your Whirlpool oven means oven too hot and to resolve this issue you'll have to replace the oven temp. sensor (probe). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 06, 2010 | Whirlpool GS475LEKS Gas Kitchen Range
F3 error (sensor replaced) kenmore stove Oven reaches proper temp then about 15 minutes after starting beeper goes off and error code f3 appears
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then check the wire harness connecting the control & sensor (as you have already replaced the sensor) however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks Rylee
Oct 05, 2010 | Kenmore Kitchen Ranges
Crosley wall oven CRB271 F3 shows on readout what does this mean?
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you'll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 14, 2010 | Ovens
Oven does not unlock control panel shows f3
Hi
Thanks for using FixYa. Error F3 in your range/oven indicates oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 26, 2010 | KitchenAid Ovens
My canon photocopier IR2016J show error code E007. Advise me on how to resolve it or reset it
my canon photocopier IR2016J show error download and stop averthing no any function. Please advise me on how to resolve it or reset it.
Lachuo
Aug 10, 2010 | Office Equipment & Supplies
F3 E1 error code
Hi
Thanks for using FixYa. Error F3-E1 in your kitchen aid means that the oven temperature sensor has shorted and to resolved this issue you’ll have to replace the oven temperature sensor. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 05, 2010 | KitchenAid KGRT607 Gas Kitchen Range
170 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
